POV-Ray : Newsgroups : povray.off-topic : Haskell raving Server Time
2 Jul 2026 01:43:51 EDT (-0400)
  Haskell raving (Message 33 to 42 of 92)
Subject: Re: Haskell raving
Date: 1 Nov 2007 02:34:35
Message: <4729818b$1@news.povray.org>
>  But in this case the data is one big string?
>  Someone else said that string are actually linked lists of characters
> where each character is garbage-collected. This must require humongous
> amounts of memory, especially considering that one character would only
> require 1 byte...
Yeah, it does take a lot, and it uses unicode for characters too,
I think I heard it takes about 12 bytes per character that way.
It's perty bad on big files.
You can use the ByteString module though, it uses a single byte
value for a character, and passes pointers and stuff around behind
the scenes to avoid duplicating stuff that doesn't need to be.
A ByteString is sort of a list of pointers to C style strings, but
with all the pointers hidden.
Date: 1 Nov 2007 07:57:55
Message: <4729cd53@news.povray.org>
  But hey, that's the fad in modern programming: Memory usage and speed
are irrelevant. Processors are getting faster and memory amounts are
doubling every couple of years, so who cares if something like a string
takes 12 times as much memory as it could?
Date: 1 Nov 2007 08:00:48
Message: <4729ce00@news.povray.org>
Orchid XP v7 <voi### [at] devnull> wrote:
> Warp wrote:
> >   That didn't really answer the question of whether it is able to drop
> > the parts which are no longer used.
> Garbage collection.
> In Haskell, a "string" is a linked-list of characters. Let go of the
> pointer to the start of the list and all elements up to the first one
> you've still got a pointer to will be collected and freed.
  Btw, what does it do if you jump to the beginning of the string after
it has been garbage-collected? (After all, from the programmer's point
of view it's one single string, so you should be able to read it from
whatever point you like, shouldn't you?)
Date: 1 Nov 2007 11:00:49
Message: <4729f831$1@news.povray.org>
Tim Attwood nous apporta ses lumieres en ce 2007/11/01 03:34:
>> require 1 byte...
It's about 12 BITS per characters, on average, not BYTES! That's useing UTF8
encoding. About 16 BITS per characters if using UTF16 encoding.
UTF8 is only 7 BITS per characters if you stick to only standard ASCII
characters set, but it gets bigger if you also use extended ASCII or characters
from foreign alphabets.
You know you have been raytracing for too long when the animation you
render will be finished after yourself.
Urs Holzer
Date: 1 Nov 2007 12:44:00
Message: <472a1060$1@news.povray.org>
It won't get GCed if it's possible to jump to the beginning.
If it's that, and not a "linked list of characters" (from the
programmer's point of view), then it won't get GCed until you're done
with it.
Probably not a good way to process big files, tho, just as it's not a
good idea in C. :-)
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 1 Nov 2007 12:46:22
Message: <472a10ee$1@news.povray.org>
Depends on the size of the string, really. If my 100-byte string holding
an email address turns into 1200 bytes, I'm not really going to worry
about it much. :-)  Agreed, really big strings where you're actually
starting to cause significant paging can be a problem, but you're really
just hitting the wall earlier in Haskell than in other impelmentation.
Date: 1 Nov 2007 13:40:34
Message: <472a1da2@news.povray.org>
  Except that if each single character is indeed garbage-collected, that
requires quite a lot of memory per character (compared to the size of the
character).
Date: 1 Nov 2007 13:57:08
Message: <472a2184$1@news.povray.org>
>   I shudder thinking how much memory that must require...
It's fine for "small" strings. For "large" strings, it's really
sub-optimal in space and time.
This is why the "ByteString" library was developed. It can present a
string-style interface, yet every character consumes only 1 byte of
storage (plus a little overhead for the array itself).
In the most efficient variant, the string is actually a linked list of
array chunks. That means you can do fast concatinate (just link some
chunks together), fast substring extraction (just point to the ends, no
data is copied), and GC can free individual chunks of data. And yet, it
all handles "as if" it were a naive linked list of individual characters...
So you see, Haskell *can* be made efficient. It's just not completely
done yet.
Date: 1 Nov 2007 13:58:47
Message: <472a21e7$1@news.povray.org>
What Darren said. ;-)
Notice that a string is a *single-linked* list. (I.e., there are "next"
pointers but no "prev" pointers.)
Date: 1 Nov 2007 14:00:03
Message: <472a2233$1@news.povray.org>
> require 1 byte...
No - it's Unicode. 24 bits per character. ;-)
But yes, the standard Haskell string type is geared to flexibility, not
performance. See my ByteString comments...
