POV-Ray : Newsgroups : povray.off-topic : All that Windoze stuff Server Time
23 Jul 2026 00:03:55 EDT (-0400)
  All that Windoze stuff (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: All that Windoze stuff
Date: 29 Oct 2007 16:43:34
Message: <47265406@news.povray.org>
Orchid XP v7 wrote:
> Darren New wrote:
>> Cross-process object-oriented calling.  Basically, remote procedure
>> calls and everything you need to do it "right" instead of half-assed.
> OK. So... if I actually knew how to do all this stuff, what useful
> things could I do with it?
It's the fundamental technology that Windows parts use to talk to other
Windows parts. You could write a program that starts up Word and Excel,
loads a spreadsheet, clips a range out and pastes it into your Word
document. You can take a blob of code that someone wrote to manage
calendars, and a blob of code that someone wrote to manage email, and
paste them together to make an email-sending reminder applciation. You
can write components for (for example) decompressing your compressed
movie stream, and plug them into Windows Media Player without having to
recompile either one. It's used for everything from plug-ins,
specialized widgets, active agents running in the background,
distributed processing, and embedded programming languages for
applications.
It's basically library++, "active" libraries that can run by themselves
as independent components.
It's "component" stuff, which I don't think Linux ever really got around
to implementing, or at least not using in any sort of consistent way.
You use it to do all the sorts of things you use IPC for (pipes,
sockets, etc) in Linux land.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 29 Oct 2007 18:09:34
Message: <4726682e$1@news.povray.org>
> applications.
Let me add some: things like showing custom thumbnails for a file format
(like Windows does by default for pictures) is done by implementing a
COM interface. explorer.exe will tell your COM object to generate the
thumbnails.
Same for adding items to the context menu, and to the drag context menu
(like WinZIP and other file archivers do, right-drag a zip and it will
have an "extract here" along with the default "move here" and "copy here").
Adding toolbars to explorer and/or Internet Explorer uses COM too, so
there's a technology advertisers know well[1].
Embedding and linking objects in Office documents uses OLE, which is
based in COM. I think WordPad is a program Microsoft used to test OLE
mechanisms, then they decided to release it.
Guess what ActiveX is based on.
[1] http://img.photobucket.com/albums/v391/brownpau/friends_ie.jpg
Date: 30 Oct 2007 07:12:30
Message: <47271fae$1@news.povray.org>
Holy toolbars, Batman!
Date: 30 Oct 2007 15:01:47
Message: <47278dab$1@news.povray.org>
Problem is, it is possible to get the same effect in Firefox.
Incautious/computer-unsavvy people don't care what browser they're
using, they'll still wreak havoc on their machine.  :P
Tim Cook
Version: 3.12
Date: 30 Oct 2007 15:49:57
Message: <472798f5$1@news.povray.org>
> applications.
So... would it for example be possible to write some gizmo that enables
you to insert a mathematical formula into a Word document without Word
crashing? (Or an organisation chart, for that matter?)
Could you write a plugin for Excel that draws some new kind of chart? Or
maybe be able to write macros in Haskell instead of VisualBasic? (You
know how normally you can write a macro in VB and then use it as a
normal function in cells of the spreadsheet? Well, what if you wanted to
use Haskell instead? Is that possible, technically?)
When I develop things that have to talk to each other, I generally just
use TCP. (Because almost all programming languages know how to do it. As
a somewhat nice side effect, it also makes it possible to run components
on seperate machines.) I have no idea what the overhead is though.
(Before now I've written some code in one programming language, then had
it use TCP to talk to a Tcl script to provide a front-end. Damn, if only
there was 1 programming language that had *all* the features I need...)
Date: 30 Oct 2007 16:24:46
Message: <4727a11e$1@news.povray.org>
Possible, yes. That's exactly one of the sorts of things it's good for.
Yep.
I would expect so. It depends what Excel exposes.0
There's certainly the serialization overhead.
Yah. That's what I'm doing right now, to wrap up some buggy C++ code
that doesn't bother to deallocate resources when something fails. :)
Date: 30 Oct 2007 16:42:56
Message: <4727a55f@news.povray.org>
  OTOH most spyware is designed to stick onto IE so at least they will
have a bit less of harmful effect if you use firefox.
Date: 30 Oct 2007 17:05:52
Message: <4727aac0$1@news.povray.org>
Darren New wrote:
>> enables you to insert a mathematical formula into a Word document
>> without Word crashing? (Or an organisation chart, for that matter?)
So... when you double-click a "drawing" object in Word, and Word locks
up for 40 seconds while it pages huge amounts of data back into RAM...
that's Word loading the external plugin that handles drawing objects?
>> to use Haskell instead? Is that possible, technically?)
Heh. Where do you find this kind of information?
(I guess it's kind of moot anyway. I don't have access to any
programming language that supports COM. No, I classify VB as "joke"
rather than "programming language"...)
>> just use TCP. I have no idea what the overhead is though.
Depends on what you're sending. (If it's text anyway, that's not too
bad. Or if you're just sending button presses...)
I know you probably don't care, but for a project I once make a small
gizmo that allows you to talk a Smalltalk application and move it's GUI
to another machine on the network. (But unlike, say, X11 or VNC, you're
working at the model level rather than the bitmap level.)
Date: 30 Oct 2007 17:10:34
Message: <4727abda$1@news.povray.org>
Javascript running under Windows Scripting Host (and under IE with very
low security settings) can use COM. PHP has a COM extension too,
although I have never tried it.
Date: 30 Oct 2007 21:03:22
Message: <4727e26a$1@news.povray.org>
I don't know if that's built in, or a separate COM object, or what.
Google "Excel vba interface" or "Excel com interface".
An example of code with COM calls in it:
http://www.smartquant.com/help/excel/
Or go to msdn.microsoft.com and search, except that they tend to take
down the documentation on any older versions of products, the bastards.
Actually, most stuff that runs on Windows supports COM. Including Tcl
(google for TCOM). And including WSH.  And including anything written
with .NET.  I'd be really surprised if Perl and all them didn't, too.
Yeah. If you're sending events, it's easier. COM exposes some pretty
complex APIs, tho.
That's pretty cool.
