POV-Ray : Newsgroups : povray.off-topic : I miss this Server Time
5 Jul 2026 03:44:57 EDT (-0400)
  I miss this (Message 91 to 100 of 137)
Subject: Re: I miss this
Date: 29 Oct 2007 11:19:47
Message: <47260823@news.povray.org>
Darren New wrote:
> Paul Fuller wrote:
>> If 'No' then please provide an explanation or link explaining how any
>> form of energy can be turned into angular momentum in a closed system.
> Hold your cat upside down, then drop him. ;-)
...into a cardboard box (leather gloves recommended).  Close the lid
flaps, overlapping them in such a way as to hold the box closed.  Then
check the crisper drawer in your fridge.  If any vegetables have
decayed, you should really clean out your fridge more often.
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 29 Oct 2007 15:03:54
Message: <47263caa@news.povray.org>
Warp wrote:
> Paul Fuller <pgf### [at] optusnetcomau> wrote:
>>>   Assuming yes, how does this conversion affect angular momentum?
>> Simple - a photon carries angular momentum.
>   Is electromagnetic radiation the only possible form of energy?
No. Mass is the only possible form of energy. :-)
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 29 Oct 2007 15:08:03
Message: <47263da3$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> Warp wrote:
>>>   A theoretical question: Can mass be converted to other forms of energy?
>> Mass *is* energy. That's where energy is stored. That's why things with
>> lots of kinetic energy are heavier.  That's why a helium atom weighs
>> less than four hydrogen atoms.   E=mc^2.
>   That didn't really answer my question.
The answer is "mu". That is the answer that unasks the question.
There is no "other form" of energy. All energy and mass are the same
thing. To ask whether mass can be converted to other forms of energy is
meaningless. All forms of "energy" are sloppy ways of measuring the
change of mass. Kinetic energy is an increase in measured mass. Energy
of atomic fission comes from a decrease in rest mass of the atoms left
behind.
It's like asking if heat can be converted to kinetic energy. Heat *is*
kinetic energy, just going all different directions.
>> It doesn't. It doesn't go anywhere.  It's all the same stuff.
>   Since angular momentum is dependent on mass, that means that eg. heat
> has mass?
Yes. As the atoms move faster, they gain mass due to relativistic
increases.  Yeah, really.
Date: 29 Oct 2007 15:17:18
Message: <47263fce@news.povray.org>
> meaningless.
  Then wikipedia is horribly wrong, I suppose.
http://en.wikipedia.org/wiki/Energy_conversion
Date: 29 Oct 2007 15:21:28
Message: <472640c8@news.povray.org>
Warp nous apporta ses lumieres en ce 2007/10/29 09:32:
> has mass?
Absolutely! It's just that in everydays terms, it's to small to be evaluated
using ordinary instruments. Heat is manifested by an increase in the average
motion of the atoms around a resting location. More heat = faster and longer
movements of the atoms. Faster movement = more kynetic energy.
For here we are not afraid to follow truth wherever it may lead.
Thomas Jefferson
Date: 29 Oct 2007 16:34:38
Message: <472651ee$1@news.povray.org>
They don't.  While to the outside observer there's no visible/relevant
difference between an *apparent* change in mass and an *actual* change
in mass, it's still not the same thing.  Even if it gives an identical
measurement at any precision.  Why?  Because I say so.  :P  Kind of like
how a rhombus with four equal angles isn't the same thing as a square,
even if it has all the same properties.  ;)
Tim Cook
Version: 3.12
Date: 29 Oct 2007 16:37:23
Message: <47265293$1@news.povray.org>
>> meaningless.
E=mc^2
Energy and mass are the same thing. You can't take mass and turn it into
energy, because it's the same thing.
The difference between the energy in carbon bonds and the energy in
quickly moving water droplets is where the energy is stored and what
tools you use to measure it. But it's all ultimately mass.
You're asking whether the bits in a void* can be converted into the bits
in a float. The question is in one sense nonsensical: They're all bits,
ones or zeros.  The question in another sense is about the
interpretation of the behavior of different patterns assigned arbitrary
meanings by human beings.  I answered the former. Wiki answered the latter.
Energy *is* mass. Mass *is* energy. They're the same thing as seen from
different sides, measured with different tools. When Wiki says "you can
convert chemical energy to heat energy", they mean you can change the
tool you need to use to perceive as a human being the mass stored in
different places. They mean "energy that shows up as increased mass
because of a gravitational field can be distinguished from energy that
shows up as increased mass because of the velocity relative to the
observer."  They're both increased mass. You can take bits of the mass
(like some of the mass that four hydrogen atoms have in excess of a
helium atom made from the same fundamental particals) and distribute it
into massy photons and massy relativistic increase in speed of air
molecules flying away from the explosion. But the mass is still there.
Date: 29 Oct 2007 17:39:47
Message: <47266133@news.povray.org>
Darren New wrote:
> E=mc^2
Bzz bzzt.  'Equivalent' does not mean 'the same thing'.  There is a
definite difference between mass and energy.  At the very least, 'mass'
is a subset of 'energy'.
Tim Cook
Version: 3.12
Date: 29 Oct 2007 18:10:50
Message: <4726687a@news.povray.org>
  That sounds a bit like saying that a combustion motor *is* a lightbulb
because the energy consumed by both can be measureds in watts.
  Common properties don't necessarily make to things the same.
Date: 29 Oct 2007 18:17:12
Message: <472669f8@news.povray.org>
Err, sorry?  Are you trying to make a joke or something?
