POV-Ray : Newsgroups : povray.off-topic : I miss this Server Time
4 Jul 2026 22:42:25 EDT (-0400)
  I miss this (Message 61 to 70 of 137)
Subject: Re: I miss this
Date: 27 Oct 2007 20:14:02
Message: <4723d44a@news.povray.org>
Darren New wrote:
> Paul Fuller wrote:
>> If 'No' then please provide an explanation or link explaining how any
>> form of energy can be turned into angular momentum in a closed system.
> Hold your cat upside down, then drop him. ;-)
Is that with or without buttered toast attached to its back :)
Date: 27 Oct 2007 22:35:37
Message: <4723f579@news.povray.org>
Paul Fuller <pgf### [at] optusnetcomau> wrote:
> Sorry but you are just wrong.
  It's easy to say "you are just wrong" without actually explaining why.
> In this case you assert that there is a point at which the cables can be
> attached that will prevent the stopping action from imparting any spin
> to the parent body.
  Attach the cable to the opposite side of the parent body. What happens?
  Besides, we can just forget the cable: Simply shoot the projectile and
that's it. With the correct amount of speed it will stop the object from
rotating. Where did the angular momentum go?
> No system of cables, pulleys, magnets, gyroscopes, friction,
> electricity, radiation, carbon nonotubes, superconductors or whatever
> can alter that.
  Since a spinning object can be used to produce energy (eg. by friction)
you are effectively saying that a spinning object is an infinite source
of energy because its angular momentum will never disappear.
Date: 27 Oct 2007 22:46:35
Message: <4723f80b@news.povray.org>
> >   In order for the rotating secondary object to affect the primary object's
> > rotation, it has to be connected to the primary object somehow. This
> > connection causes friction.
> It has to exert a force and I agree that some energy will be lost in any
> practical system.  You are just not getting the point that friction
> itself has nothing to do with angular momentum.
  So you are effectively saying that regardless of heat produced by
friction, angular momentum is always conserved. This would effectively
make a spinning object an infinite source of energy.
> >   This would be true in a completely friction-free system. The thing is,
> > friction dissipates part of this energy.
> Still hung up on friction !
  A spinning object can be used to produce heat by friction.
> True enough.  Friction is the mechanism that takes energy from the
> spinning Earth.
  Where does this energy come from?
>  At the same time there is a change elsewhere in the
> system that conserves angular momentum overall.
  Which means that the energy was produced completely for free?
Isn't that kind of the definition of a perpetual motion machine?
> The tidal locking effect is well known and you have described it
> reasonably well.  However you are wrong to say that angular momentum is
> converted to heat by friction.
  Then what is it that is converted to heat by friction?
> Angular momentum is a different thing to energy.  Sorry but there is no
> known way to convert one to another.  You can certainly use energy to
> start one mass spinning.  Thing is that there must be an opposite amount
> of angular momentum showing up somewhere else.
  Two objects with no angular momentum at all collide off-center, and
they get stuck to each other. The resulting union of masses will start
spinning because of the collision.
  Somewhere else in the universe something else starts spinning in the
opposite direction due to a magical universal conservation of angular
momentum law.
  Yes, I understand perfectly now. Thanks for clearing that up.
Date: 28 Oct 2007 04:58:08
Message: <47245d2f@news.povray.org>
  I thought about this and became to a conclusion. You could have explained
it if you knew it instead of just saying "you are wrong" without any
explanation.
  The answer is that the object-projectile system still has the angular
momentum. If we calculate the angular momentum of this system after the
firing, ie. the how the system is oriented with regard to the center of
mass of the system and the distance between the two objects, we will
probably get an angular momentum equivalent to the original one.
  The same is probably true for two approaching objects which collide.
Even though each object by itself didn't have any angular momentum, the
two-object system did. The entire two-object system is actually rotating
around the center of mass of the two objects (even though they two objects
are travelling almost rectilinearly; this is because they are not travelling
along the same line in space). When they collide and stick to each other,
the "speed of rotation" they had just before they collided will be kept. The
angular momentum will be unmodified. Only if the two objects were travelling
exactly on the same line in space will there be no rotation because there's
no angular momentum.
Date: 28 Oct 2007 05:00:57
Message: <47245dd9@news.povray.org>
scott <sco### [at] laptopcom> wrote:
> > http://www.xkcd.com/162/
> "Each turn robs the planet of angular momentum"
> Unfortunately not...
  Maybe the idea was that *while* she is spinning, the Earth rotates more
slowly, making the day longer? When she stops spinning the rotation of the
Earth may return to normal, but that day will still have been longer
nevertheless.
Date: 28 Oct 2007 05:50:46
Message: <op.t0wlq1e3cs6ysw@e6600>
> the
> nevertheless.
Yeah, but she will have spent it spinning...
FE
Date: 28 Oct 2007 06:58:38
Message: <4724796e$1@news.povray.org>
> explanation.
Several times, as carefully as I could I explained that angular momentum
is conserved in a closed system.  That is a general principle that is
apparently fundamental to the way the universe works.  Apart from
stating the principle which you will find in any physics textbook that
touches on the subject and on many websites, I also explained as
carefully as I could in this medium where the angular momentum was
transferred from and to in several examples.
Sorry but you continued to assert that friction could cancel out angular
momentum and that a spinning closed system could be brought to rest
without any external force.
When I asked plainly is angular momentum conserved in a closed system
you replied:
 >>Angular momentum can be lost by converting it to heat (or other forms
 >>of energy for that matter), so the answer is no, unless you don't
 >>consider it a "closed system" anymore if there's heat dissipation
 >>(OTOH, this heat could theoretically be collected and stored, keeping
 >>the whole thing a closed system).
I'm still unclear from your other posts as to whether you still maintain
this position.  Perhaps you have taken some time to research the facts
and would recant your statement?
I'll admit to being a poor instructor.  I think you have to admit to
being a) wrong and b) pig-headed about it.
I will reply to your other posts to try to clear up some of the wrong
assertions that you continue to make in them.  It would be nice if you
could reply in one coherent go though rather than in dribs and drabs of
silliness.
Date: 28 Oct 2007 07:00:03
Message: <472479c3$1@news.povray.org>
I actually do explain more after that one line that you quoted.
>> to the parent body.
When the cable goes taut the projectile will exert a force on the body
(and vice versa) that will be off centre and will cancel the rotation.
Of course things will bump around but once that is finished the net
rotation will be as before the projectile was fired.  At every stage if
you care to add up the angular momentum of the system it will be constant.
I can't reply with numbers and formulae unless you can give a diagram
with distances, masses and velocities.
It is carried in the off centre velocity of the mass of the projectile.
>> can alter that.
Absolutely not and it is revealing that you misunderstand or
misrepresent the argument to that degree.  I'm not talking about the
rotation of any single part of the system being constant.  I'm talking
about the sum of the angular momentum of the whole system.
As the rotation of a mass A is reduced, an opposite change in angular
momentum occurs somewhere else in the system.  And not by magic.  simply
ask what is exerting the tangential force to slow down A and you'll find
an equal and opposite force acting on that other thing.  And please
don't say friction is exerting the force!  Some other part of the system
must be applying the force be it via friction or any other means.
That you make just nonsense statements on my behalf then tear them down
is poor style.
Date: 28 Oct 2007 07:39:56
Message: <4724831c$1@news.povray.org>
I am saying that angular momentum is conserved.  As I have replied
elsewhere to you this does not make your tacked on sentence about
infinite energy true.  I am not saying that but you have added it
because you misunderstand or want to misrepresent what I am saying.
Yes.  So can rubbing sticks together.  Neither will in any case alter
the total angular momentum of a system.
>> spinning Earth.
There is a spinning mass.  That stores energy in kinetic form.  Slowing
it down by friction converts stored kinetic energy to heat energy.  It
does not convert angular momentum into heat.  There will be an effect
elsewhere that causes a matching change to the angular momentum of
another part of the system.  Look I even said that in the next paragraph.
V
No it is transferred.  Please stop making silly assertions on my behalf.
Energy stored in the rotation of the Earth, Moon and both around each
other.  Lots of energy there!  And if you care to read on the subject
you'll find that the rotation of the Earth has slowed and the separation
of the Earth and Moon has increased over time.  The energy has been
transferred into heat by friction as you say.
As I think you have realised elsewhere the system comprising the
original two masses does already have angular momentum.  This then shows
up as the rotation of the combined body.
> momentum law.
No.  You are just being silly again trying to paint my arguments and
make them appear ridiculous.  There is no magic and something
unconnected does not start spinning.  Any change to the rotation of one
part of a system must be caused by a force exerted on it by another
part.  That is where you will find the corresponding change in rotation
that balances out the angular momentum.
Date: 28 Oct 2007 09:19:01
Message: <47249a55@news.povray.org>
> explanation.
So now you're saying that *I* don't understand the topic.  Very, very rich.
Sounds like you are coming around to the correct view that total angular
Yes.  Angular momentum is conserved.
