POV-Ray : Newsgroups : povray.off-topic : My laptop is a binge drinker Server Time
11 Oct 2024 13:14:57 EDT (-0400)
  My laptop is a binge drinker (Message 1 to 10 of 26)
Subject: My laptop is a binge drinker
Date: 10 Sep 2007 06:28:30
Message: <46e51c4e$1@news.povray.org>
So, last night I knocked over a full can of beer onto my MacBook. Which
was open, turned on and rendering (as usual). Most of the spillage went
directly onto the keyboard. As you can imagine, I let out a set of
strangled expletives and fairly levitated from my chair to deal with the
catastrophe.
I turned it off, tipped the excess beer off the keyboard and took out
the battery. Then I spent the best part of an hour trying to find a set
of screwdrivers small enough to permit a careful disassembly; having
found some, I then sat down and, well, carefully disassembled it. A bit
of respect to Apple here - I was expecting to have to break something at
this point, but the entire keyboard lifted off in its entirety with a
minimum of fuss (although there were about 15 screws in the battery bay
alone that I didn't immediately notice). I took out the RAM too.
Next, I liberally hosed down the keyboard and laptop interior with lab
grade ethanol, soaked up the excess with paper towels, played a cold
hairdryer over the whole thing for a few minutes and left it to dry. As
I type, there it still sits.
I will reassemble it this evening and fire it up to see what's what. In
the meantime, does anyone have any additional advice?
Subject: Re: My laptop is a binge drinker
Date: 10 Sep 2007 06:58:47
Message: <46e52367@news.povray.org>
> A bit of respect to Apple here - I was expecting to have to break
> something at this point, but the entire keyboard lifted off in its
> entirety with a minimum of fuss (although there were about 15 screws in
> the battery bay alone that I didn't immediately notice). I took out the
> RAM too.
Yeh, most laptops have very easily removed keyboards, I guess so suppliers
can replace with region-specific keyboards without having to take the whole
thing apart.  My Dell has 4 or 5 screws on the back that are even labelled
"K" :-)
Nope, sounds like it should be fine.  The only problem will be if some of
the keys are "sticky", that can sometimes be really hard to fix totally -
but if you rinsed it off before the beer started to dry it shouldn't be a
problem.
Good luck!
Date: 10 Sep 2007 09:05:46
Message: <46e5412a$1@news.povray.org>
> catastrophe.
just make sure it gets enough exercise so it doesn't get a beer belly......
Date: 10 Sep 2007 12:06:17
Message: <op.tyf4c50ac3xi7v@news.povray.org>
And lo on Mon, 10 Sep 2007 14:05:46 +0100, Tom Austin <taustin> did spake,
saying:
>> was open, turned on and rendering (as usual). I will reassemble it this
>> evening and fire it up to see what's what. In the meantime, does anyone
> belly......
and note that you'll now only be able to do that render when you pour some
more beer onto it, otherwise it'll be 'file not found' ;-)
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 10 Sep 2007 13:13:41
Message: <46e57b45$1@news.povray.org>
1. Where the hell did you get lab-grade ethanol from?
2. Isn't that likely to disolve important plastic components?
http://blog.orphi.me.uk/
Date: 10 Sep 2007 17:08:36
Message: <46e5b254$1@news.povray.org>
I heard that you can stick a cell-phone, or an Ipod
that has gotten wet into a bag of dry uncooked rice
overnight to get the last of the water out.  The rice
absorbs the water I guess. You might try some
variation on that.
Date: 10 Sep 2007 17:24:28
Message: <46e5b60c@news.povray.org>
46e5b254$1@news.povray.org...
> variation on that.
One of these variations can be Silica gel dryer (the stuff you find in
little bags in electronic devices package)
Marc
Date: 10 Sep 2007 20:34:57
Message: <46e5e2b1$1@news.povray.org>
If you persist in drinking around your laptop, get an external keyboard
so that you can keep the CPU farther away from the beer.
John
Date: 11 Sep 2007 05:03:09
Message: <46e659cd$1@news.povray.org>
> spake, saying:
>>> Which was open, turned on and rendering (as usual). I will reassemble
>>> it this evening and fire it up to see what's what. In the meantime,
>> belly......
> some more beer onto it, otherwise it'll be 'file not found' ;-)
When I eventually check the output file I'll probably find unexpected
focal blur. Or maybe the preview will look much better than the actual
image or something. :)
Date: 11 Sep 2007 05:17:12
Message: <46e65d18$1@news.povray.org>
The lab at work. You've probably got access to some too by the sounds of
it, although I wouldn't go 'borrowing' any unless you know for certain
that you won't get fired for it.
I don't think so, maybe some of the cheaper adhesives. Now acetone -
that would probably dissolve the circuit boards! Ethanol is particularly
suitable for cleaning electronics because it's hydrophilic,
non-conductive and evaporates very swiftly at room temperature.
