POV-Ray : Newsgroups : povray.off-topic : Power Server Time
13 Jun 2026 23:07:43 EDT (-0400)
  Power (Message 24 to 33 of 133)
Subject: Re: Power
Date: 2 Sep 2007 14:00:09
Message: <46dafa29@news.povray.org>
> I just find it bizzare that this huge washing machine, spinning away to
> violently that it's deafening to stand near and you'd probably be injured
> if you touched it, uses about 5% of the power of a teeny little kettle.
> Far out!
And then you'd probably also be surprised how loud your speakers are when
you feed just 5 W into them.
> I'm currently measuring the fridge. Surprisingly, it uses a whole 100 W
> when the compressor is running. (I was expecting lower.) OTOH, it doesn't
> run for long...
> PS. 230 V? I thought it was 250 V...
IIRC the spec was changed from 240 +/- 10% to 230 +15% -5% (or something
equally stupid) to get us inline with Europe.  Doesn't your meter tell you
the voltage too?
Subject: Re: Power
Date: 2 Sep 2007 15:28:41
Message: <46db0ee9@news.povray.org>
On Sun, 02 Sep 2007 20:00:18 +0200, scott wrote:
>>> I was quite surprised that my PC uses 4 W even when it's "turned
>>> off"...
>> Does it support Wake on LAN?  If so, then there's got to be some power
>> consumed to keep it awake enough to recognise a signal coming in saying
>> "wake up now".
> Yes, but 4 W!!!!  4 mW should be enough.
Perhaps, depends on what other features the kit has, though.
I know, for example, that the system I have here at my feet has an ATX
board, which means the "power" switch is solid state rather than a
physical switch.  That means the board is powered all the time (when the
power supply switch is on at the back of the system).
Jim
Subject: Re: Power
Date: 2 Sep 2007 15:56:50
Message: <46db1582$1@news.povray.org>
>> I was quite surprised that my PC uses 4 W even when it's "turned off"...
> "wake up now".
It probably does support Wake on LAN. I really, *really* hope I have
that disabled though... (It's hard to tell!)
http://blog.orphi.me.uk/
Subject: Re: Power
Date: 2 Sep 2007 15:59:41
Message: <46db162d$1@news.povray.org>
>> saying "wake up now".
I notice that, for example, the battery charger for my mouse continues
to charge even while the PC is "off". Also, the LEDs on my MIDI
interface still twinkle. And the USB light on my external audio card
still lights up. All of these things go out when I unplug the PC from
the mains. (Or just flip the switch on the PSU.)
Even so... that takes it up to, what, 19 mW? I don't know what the other
3,981 W is for...
(That's actually slightly unfair. The meter is only accurate to the
nearest 1 W, and I don't know what its rounding mode is...)
Convesly, the PC uses *less* power than I was expecting when turned on,
so...
Subject: Re: Power
Date: 2 Sep 2007 16:04:04
Message: <46db1734$1@news.povray.org>
>> to violently that it's deafening to stand near and you'd probably be
>> injured if you touched it, uses about 5% of the power of a teeny
>> little kettle. Far out!
> when you feed just 5 W into them.
Oh... no, not really. I mean, sound vibrations are really, *really*
tiny. (Think about it; even when the sound is turned up painfully loud,
the speaker cones move by such a tiny amount you can't even see them
move at all!)
AFAIK, the reason we have 200 W amplifiers and speakers isn't so much
because it takes that much electricity to move air around, but to reduce
RF pickup in the speaker wire... (Or rather, to reduce the
*signifigance* of such pickup.)
> you the voltage too?
The mater claims 249.98 V.
Also, 49.97 Hz. (So much for "they keep it to exactly 50 Hz to help all
those clocks that use it". The frequency waivers all over the place!)
Subject: Re: Power
Date: 2 Sep 2007 16:05:11
Message: <46db1777$1@news.povray.org>
>> Far out!
> Did you measure your washing machine while it is warming water?
Yes. Then it goes up to about 25% of what the kettle uses. (Mind you,
the kettle *boils* the water, the washing machine merely makes it
slightly warm, and takes several minutes to do even that...)
Subject: Re: Power
Date: 2 Sep 2007 16:06:42
Message: <46db17d2$1@news.povray.org>
> A. Didn't you say it uses 600W at final spin speed?  That's 20% of 3000...
Your powers of mental arithmetic greatly exceed mine.
> B. It only seems bizarre because you already had decided on the way
> things are before learning even the first fact about them (ie. do an
> experiment like this, or study electrical theory).  It's really cool to
> go "wow!" and be excited about new discoveries.  But you are kinda
> saying that things you haven't seen should behave exactly as your head
> imagined it, rather than work the way it always has done, only waiting
> for you to come along and discover it.  Actually, now I think of it, you
> do that rather too often, which is unfortunate because you limit
> yourself then...   :'-s
I didn't say I don't believe it. I just said it seems really bizzare and
puzzling, that's all.
Gee, I wonder what our lawn mower uses...
Subject: Re: Power
Date: 2 Sep 2007 18:03:38
Message: <op.tx1rkc0ucs6ysw@e6600>
On Sun, 02 Sep 2007 22:05:17 +0200, Orchid XP v3 <voi### [at] devnull> wrote:
>> something equally stupid) to get us inline with Europe.  Doesn't your
>> meter tell you the voltage too?
Still within tolerance.
http://en.wikipedia.org/wiki/Mains_electricity#Voltage_levels
http://en.wikipedia.org/wiki/Mains_electricity#Frequency_stability
http://www.dynamicdemand.co.uk/grid.htm
FE
Subject: Re: Power
Date: 2 Sep 2007 22:48:49
Message: <46db7611@news.povray.org>
Orchid XP v3 wrote:
>>> Can anybody suggest why this might be?
>> It's because heat represents a huge amount of energy.
>> For instance, the humble calorie, the amount of energy required to
>> raise a single gram of water by one degree celsius, is the same amount
>> of energy required to lift that same gram of water about 387 meters in
>> Earth's gravity, or accelerate it from zero to 87 meters per second.
> Damn... pitty we can't use heat to do *useful* stuff!
Heat already does useful things.  For instance, it causes cute girls to
wear skimpy clothing.
John
Subject: Re: Power
Date: 2 Sep 2007 23:42:17
Message: <46db8299$1@news.povray.org>
On Sun, 02 Sep 2007 20:58:04 +0100, Orchid XP v3 wrote:
>  I really, *really* hope I have that
BIOS settings.  But it's not exactly easy to learn the wake-up code from
outside a NATted connection.  You've got to know the MAC address of the
system, IIRC.
Yep, according to http://en.wikipedia.org/wiki/Wake-on-LAN the magic
packet is set over a connectionless protocol (UDP, IPX) with "FF FF FF FF
FF FF FF" (in hex, hopefully obviously) plus 16 repetitions of the target
machine's MAC address, plus a 4-6 byte password.
So I don't think you have to worry about me turning your machine on from
half a world away.
Jim
