POV-Ray : Newsgroups : povray.newusers : Help - very difficult when it should be easy Server Time
2 Apr 2026 02:38:53 EDT (-0400)
  Help - very difficult when it should be easy (Message 11 to 19 of 19)
Subject: Re: Help - very difficult when it should be easy
Date: 16 Nov 2016 17:00:01
Message: <web.582cd6cdba97f5c181c811d20@news.povray.org>
> That looks good when I run your code - when I let it rip on a big array of
> triangular coordinates, I get a "Domain error in atan2()"
> I'll study your code and try to track down the cause.  Probably
> degenerate/coincident points or something.
Actually you'd also have to check the second instance as well:
#declare RotY = degrees(atan2(Vec.z,Vec.x));
and ensure that z & x aren't the same.  If they are, then the box is vertical
and doesn't need rotation about y.
-tgq
Date: 17 Nov 2016 13:05:01
Message: <web.582df094ba97f5c1b488d9aa0@news.povray.org>
Thanks Trevor.  :)
I _almost got it.
Still a bit hairy somewhere.
Here's what I'm trying to get to work:
#version 3.7;
global_settings {assumed_gamma 1.0}
#include "math.inc"
#include "rand.inc"
#include "textures.inc"
#include "transforms.inc"
#declare Feet = 12;
#declare Phi = (1+sqrt(5))/2;
 location <0*Feet, 0*Feet, -500*Feet>
 look_at  <0*Feet, 0*Feet, 0>
 up y
light_source {<50*Feet, 5000*Feet, 10000*Feet> Yellow} // Sun
light_source {<-100*Feet, 50*Feet, -300*Feet> White}
sky_sphere{ pigment { gradient <0,1,0>
                      color_map { [0.00 rgb <0.6,0.7,1.0>]
                                  [0.35 rgb <0.0,0.1,0.8>]
                                  [0.65 rgb <0.0,0.1,0.8>]
                                  [1.00 rgb <0.6,0.7,1.0>]
                      scale 2
                    } // end pigment
          } //end skysphere
#declare DrawingScale = 8*Feet / 25;
#declare ArcHeight = 18*DrawingScale; // measured 18 mm on drawing
#declare ArcLength = 170*DrawingScale; // measured 17 cm (170 mm) on drawing
#declare GlobeRadius = (pow(ArcHeight,2) + pow(ArcLength,2)) / (2*ArcHeight);
#declare Scale = GlobeRadius/Phi;   // radius of sphere
#debug concat( " GlobeRadius = ", str(Scale/12, 3, 2), " feet \n")
#declare TwentyHedron = array [12] {
<0, Phi, -1>,   // Top front    0
<0, Phi,  1>,   // Top Rear     1
<-Phi,  1, 0>,  // Left Top     2
<-Phi, -1, 0>,  // Left bottom  3
<Phi,  1,  0>,  // Right top    4
<Phi, -1,  0>,  // Right bottom 5
<-1, 0, -Phi>,  // Front left   6
< 1, 0, -Phi>,  // Front Right  7
<-1. 0, Phi>,   // Rear left   8
< 1, 0, Phi>,   // Rear right   9
<0, -Phi, -1>,  // bottom front 10
<0, -Phi,  1>,  // bottom rear  11
#declare IcosahedralArray = array [20][3] {
 //front top cap
    {TwentyHedron[ 0], TwentyHedron[ 4], TwentyHedron[ 1]},     //          1
    {TwentyHedron[ 0], TwentyHedron[ 7], TwentyHedron[ 4]},     //        /   \
    {TwentyHedron[ 0], TwentyHedron[ 6], TwentyHedron[ 7]},     //       2  0  4
    {TwentyHedron[ 0], TwentyHedron[ 2], TwentyHedron[ 6]},     //       \     /
    {TwentyHedron[ 0], TwentyHedron[ 1], TwentyHedron[ 2]},     //        6---7
    // middle belt
    {TwentyHedron[ 1], TwentyHedron[ 9], TwentyHedron[ 8]},
    {TwentyHedron[ 1], TwentyHedron[ 4], TwentyHedron[ 9]},
    {TwentyHedron[ 4], TwentyHedron[ 5], TwentyHedron[ 9]},
    {TwentyHedron[ 4], TwentyHedron[ 7], TwentyHedron[ 5]},     //
1---4---7---6---2---1
    {TwentyHedron[ 7], TwentyHedron[10], TwentyHedron[ 5]},     //     / \ / \ /
    {TwentyHedron[ 7], TwentyHedron[ 6], TwentyHedron[10]},     //
8---9---5---10--3---8
    {TwentyHedron[ 6], TwentyHedron[ 3], TwentyHedron[10]},
    {TwentyHedron[ 6], TwentyHedron[ 2], TwentyHedron[ 3]},
    {TwentyHedron[ 2], TwentyHedron[ 8], TwentyHedron[ 3]},
    {TwentyHedron[ 2], TwentyHedron[ 1], TwentyHedron[ 8]},
    //rear bottom cap
    {TwentyHedron[11], TwentyHedron[ 8], TwentyHedron[ 9]},     //        8---9
    {TwentyHedron[11], TwentyHedron[ 9], TwentyHedron[ 5]},     //       /     \
    {TwentyHedron[11], TwentyHedron[ 5], TwentyHedron[10]},     //      3   11
5
    {TwentyHedron[11], TwentyHedron[10], TwentyHedron[ 3]},     //       \     /
    {TwentyHedron[11], TwentyHedron[ 3], TwentyHedron[ 8]}      //          10
#macro Subdivision (BasisArray, Iterations)
 //  Subdivision of triangles
 #for (Subdivide, 1, Iterations)
 #local BasisNumber = dimension_size (BasisArray, 1);
 #local ExpandedArray = array [4 * BasisNumber][3];
 //#debug "------------\n"
     #for (BasisTriangle, 0, BasisNumber-1)
 //  Subdivision scheme for triangles
 //           1
 //         A___B
 //       0___C___2
 #local Vertex_A = vnormalize(
(BasisArray[BasisTriangle][0]+BasisArray[BasisTriangle][1])/2 );
 #local Vertex_B = vnormalize(
(BasisArray[BasisTriangle][1]+BasisArray[BasisTriangle][2])/2 );
 #local Vertex_C = vnormalize(
(BasisArray[BasisTriangle][2]+BasisArray[BasisTriangle][0])/2 );
 #local ExpandedArray [(4*BasisTriangle)+0][0] =
vnormalize(BasisArray[BasisTriangle][0]);
 //#local ExpandedArray [(4*BasisTriangle)+0][1] =
(BasisArray[BasisTriangle][0]+BasisArray[BasisTriangle][1])/2;
 #local ExpandedArray [(4*BasisTriangle)+0][1] = Vertex_A;
 //#local ExpandedArray [(4*BasisTriangle)+0][2] =
(BasisArray[BasisTriangle][0]+BasisArray[BasisTriangle][2])/2;
 #local ExpandedArray [(4*BasisTriangle)+0][2] = Vertex_C;
 #local ExpandedArray [(4*BasisTriangle)+1][0] =
vnormalize(BasisArray[BasisTriangle][1]);
 //#local ExpandedArray [(4*BasisTriangle)+1][1] =
(BasisArray[BasisTriangle][1]+BasisArray[BasisTriangle][0])/2;
 #local ExpandedArray [(4*BasisTriangle)+1][1] = Vertex_B;
 //#local ExpandedArray [(4*BasisTriangle)+1][2] =
(BasisArray[BasisTriangle][1]+BasisArray[BasisTriangle][2])/2;
 #local ExpandedArray [(4*BasisTriangle)+1][2] = Vertex_A;
 #local ExpandedArray [(4*BasisTriangle)+2][0] =
vnormalize(BasisArray[BasisTriangle][2]);
 //#local ExpandedArray [(4*BasisTriangle)+2][1] =
(BasisArray[BasisTriangle][2]+BasisArray[BasisTriangle][0])/2;
 #local ExpandedArray [(4*BasisTriangle)+2][1] = Vertex_C;
 //#local ExpandedArray [(4*BasisTriangle)+2][2] =
(BasisArray[BasisTriangle][2]+BasisArray[BasisTriangle][1])/2;
 #local ExpandedArray [(4*BasisTriangle)+2][2] = Vertex_B;
 //#local ExpandedArray [(4*BasisTriangle)+3][0] =
 #local ExpandedArray [(4*BasisTriangle)+3][0] = Vertex_A;
 //#local ExpandedArray [(4*BasisTriangle)+3][1] =
 #local ExpandedArray [(4*BasisTriangle)+3][1] = Vertex_B;
 //#local ExpandedArray [(4*BasisTriangle)+3][2] =
 #local ExpandedArray [(4*BasisTriangle)+3][2] = Vertex_C;
 #debug concat( "Vertex 0 = ", vstr(3, BasisArray[BasisTriangle][0], ", ", 3,
3), " \n")
 #debug concat( "Vertex 1 = ", vstr(3, BasisArray[BasisTriangle][1], ", ", 3,
3), " \n")
 #debug concat( "Vertex 2 = ", vstr(3, BasisArray[BasisTriangle][2], ", ", 3,
3), " \n")
 #debug concat( "Vertex A = ", vstr(3, Vertex_A, ", ", 3, 3), " \n")
 #debug concat( "Vertex B = ", vstr(3, Vertex_B, ", ", 3, 3), " \n")
 #debug concat( "Vertex C = ", vstr(3, Vertex_C, ", ", 3, 3), " \n")
 #debug "------------\n\n"
 #end // end for BasisTriangle
 #local BasisArray = ExpandedArray;
#end // end for Subdivide
ExpandedArray
#end // end macro subdivision
// Build Globe for Scene
#declare Globe_Array = Subdivision (IcosahedralArray, 4)  //  <=================
perform expansion of icosahedraal basis array
#declare ExpandedNumber = dimension_size (Globe_Array, 1);
 #for (Side, 0, ExpandedNumber-1)
  #for (Vertex, 0, 2)
   #declare Globe_Array[Side][Vertex] = Globe_Array[Side][Vertex] * Scale;
  #end // end for Vertex
 #end // end for Side
#declare Strut = 5;
#declare GlobeColor = pigment {Green*0.5}
//  Cylinder Mesh (as guide) and Struts
#declare MeshSphere_1 =
union {
 #declare LastVertex = <0, 0, 0>;
     #for (Vertex, 0, 2)
   #declare ThisVertex = Globe_Array[Side][Vertex];
   //#debug concat( "Vertex = ", vstr(3, ExpandedArray[Side][Vertex], ", ", 3,
3), " \n")
   #if (Vertex > 0)
    cylinder {LastVertex, ThisVertex, Strut/4 texture {pigment {GlobeColor}
finish {specular 0.8}} }
    #declare CurrentVector = (ThisVertex - LastVertex);
      // #declare Vec = Point2 - Point1;       //Direction vector to orient to
      #declare Vec = (ThisVertex - LastVertex);
      #declare StrutLength = vlength(CurrentVector);  //LENGTH OF BOX
    //Twist rotates the box around the long axis first
    #declare Twist = 0;
      //RotZ and RotY reoorient the box to align to the vector
      #if (StrutLength = 0 | Vec.x = 0 | Vec.z = 0)
       // do nothing
      #else
       #declare RotZ = degrees(atan2(Vec.y, vlength(<Vec.x, 0, Vec.z>)));
//ROTATION ABOUT Z-AXIS
       #declare RotY = degrees(atan2(Vec.z, Vec.x));
//ROTATION ABOUT Y-AXIS
     #declare IBeam = union {
      box {<0, -Strut, -Strut/3>, <StrutLength, -Strut*0.9, Strut/3>}
      box {<0, -Strut, -Strut/2>, <StrutLength,  Strut,     Strut/2>}
      box {<0,  Strut, -Strut/3>, <StrutLength,  Strut*0.9, Strut/3>}
      pigment {Red*0.5}
     } // end IBeam
     // sphere {Point1 0.5 pigment {Orange*0.5} }
     // sphere {Point2 0.5 pigment {Violet*0.5} }
     #declare NewIBeam = object {IBeam
      rotate Twist*x
          rotate RotZ*z
          rotate RotY*y
     object {NewIBeam translate ThisVertex}
    #end // end if (atan2 check)
   #end // end if (past 1st triangle point)
   #declare LastVertex = ThisVertex;
   cylinder {LastVertex, Globe_Array[Side][0], Strut/4 texture {pigment
{GlobeColor} finish {specular 0.8}} }
   #declare CurrentVector = (Globe_Array[Side][0] - LastVertex);
   #declare Twist = 0;
     // do nothing
    #else
     pigment {Red*0.6}
    } // end IBeam
     rotate Twist*x
         rotate RotZ*z
         rotate RotY*y
} // end union MeshSphere_1
#declare Globe = union {
 object {MeshSphere_1}   // Struts
 #declare Axes = 12;
 cylinder {<0, 0, 0>, <200*Feet, 0, 0> Axes pigment {Red*0.5}}
 cylinder {<0, 0, 0>, <0, 200*Feet, 0> Axes pigment {Green*0.5}}
 cylinder {<0, 0, 0>, <0, 0, 200*Feet> Axes pigment {Blue*0.5}}
object {Globe}
Date: 20 Nov 2016 22:30:01
Message: <web.58326a12ba97f5c179917fa00@news.povray.org>
> "Bill Pragnell" <bil### [at] hotmailcom> wrote:
> > Are you trying to keep the box 'upright' - rotating it around y before tilting
> > it out of plane, like a ramp?
> Sure - that works for me.
> If so, you could use Reorient_Trans() twice on
> > them to keep it simple... it's in transforms.inc (which I see you're using
> > already).
> ("point", "axis", "vector" ...   sure.   They're all the same thing.)
No, points and vectors are not the same thing:
- You can add a vector to a vector and get a vector
- You can subtract a vector from a vector and get a vector
- You can subtract a point from a point and get a vector
- You can add a vector to a point and get a point
- You can subtract a vector from a point and get a point
- But you can not add a point to a point
(If you insist on adding points, I suggest that you read about barycentric
coordinates.)
> Here's what I tried - still no joy.
> 1. define a transform which is a y - rotation, the magnitude of which was
> determined by projecting Point 2 onto the x-z plane [see prior code]
> 2. rotate my "x-axis vector" around y by this transform
> 3. define a transform that rotates x to the new y-rotated position
> 4. define a transform that rotates YRotated vector up to Point2, which as we
> know, is a point, a vector, and an axis
> 5. apply both transforms to the object
Does this code do what you want ?
(Replace your for loop and everything within it with this code.)
#macro ProjectToPlane(v0, vN)
   (v0 - vdot(v0, vN)/vdot(vN, vN)*vN)
#end // macro ProjectToPlane
#for (Test, 0, 4)
  #declare p1 = StartArray[Test];
  #declare p2 = EndArray[Test];
  #declare v12 = p2 - p1;
  #declare StrutLength = vlength(v12);
  sphere {
    p1, 0.5
    pigment { Orange }
  cylinder {
    p1, p2, Strut/2*1.05
    pigment { Cyan }
  sphere {
    p2, 0.5
    pigment { Violet }
  #declare vXZ = ProjectToPlane(v12, y);
  #declare TransformA = Reorient_Trans(x, vXZ)
  #declare TransformB = Reorient_Trans(vXZ, v12)
  #declare TotalTransform =
    transform {
      transform TransformA
      transform TransformB
      translate p1
  box {
    <0, -Strut/2, -Strut/2>, <StrutLength, Strut/2, Strut/2>
    transform { TotalTransform }
    pigment { Gray }
  #declare pXZ = p1 + vXZ;
  union {
    cylinder { p1, pXZ, 0.1 }
    sphere { pXZ, 0.2 }
    cylinder { pXZ, p2, 0.1 }
    pigment { Blue }
#end // for
Tor Olav
http://subcube.com
Date: 21 Nov 2016 08:00:01
Message: <web.5832ef06ba97f5c1c437ac910@news.povray.org>
I think I figured it out.
At first I thought there might be a problem with the quadrant / sector that the
calculation was done in, then it seemed like it might be anything with a Vec
with a negative x component (because the Strut object is constructed in the +x
direction).
After doing some other simplified experiments, it looks like I need to rotate in
the -y direction.   Perhaps due to the left-handed coordinate system?
Can anyone confirm?
Aside from that, I needed to translate to LastVertex (Point1) rather than
ThisVertex (Point2)
and if Twist is set to -y*RotY, then the Struts follow the spherical curvature
as desired.
Looks like it was a busy weekend here at news.povray.org
I'm glad I got some much needed rest AND (perhaps because of that) unraveled the
whole spherical trigonometry vector rotation translation spaghetti.   :)
Date: 21 Nov 2016 12:45:01
Message: <web.5833324eba97f5c1b99945e00@news.povray.org>
Whoa, you have a point (no pun intended), but this will throw a monkey wrench
into my Hungarian-like notation.  ('p' is already taken by pigment.)
Date: 21 Nov 2016 13:00:00
Message: <web.583335c8ba97f5c1c437ac910@news.povray.org>
I missed this in the flurry of weekend posts - Thanks for taking the time to
look this over and offer some fully-coded solutions!
It's VERY much appreciated.
I'll paste it into my scene and give it a go.  I always like to explore multiple
methods of accomplishing the same task - they are often different in small ways
that make one particular way well suited to solving a problem in the future.
Thanks as always for your help and expertise!
PS.  Any ideas why the degrees(atan2()) results need to be sign-inverted?
IS it the left hand coordinate system that POV-Ray uses?
Date: 21 Nov 2016 13:41:40
Message: <58333fe4$1@news.povray.org>
Am 21.11.2016 um 18:43 schrieb Cousin Ricky:
Maybe it helps that "points" can also be referred to as "location
vectors", in that they specify the vector between the coordinate origin
and the point in question.
Date: 23 Nov 2016 12:20:01
Message: <web.5835ce8eba97f5c1468fc97e0@news.povray.org>
I hope my code worked for you.
You are welcome. I'm glad to help.
I have not look at the Trevors code, so I don't know.
Generally, the rotation direction around an axis in a left handed coordinate
system is opposite of the rotation direction around an axis in a right handed
coordinate system.
But I think that you should not have to use any atan-functions to solve your
problem.
Tor Olav
http://subcube.com
Date: 25 Nov 2016 21:25:00
Message: <web.5838f1dfba97f5c1b99945e00@news.povray.org>
> >> [snip]
Then 'lv' it is!  :-)
