POV-Ray : Newsgroups : povray.newusers : the concept of focus in povray? Server Time
3 Jun 2025 04:27:20 EDT (-0400)
  the concept of focus in povray? (Message 1 to 5 of 5)
Subject: the concept of focus in povray?
Date: 28 Mar 2016 23:55:01
Message: <web.56f9fc75d50d895f3fdf54d50@news.povray.org>
Hi,I have studied this soft for several days and have 2 questions:
1、which keyword is used to set the focus of perspective model carema?
look_at?direction? or others?
2、Besides,when one focus of the carema is set,how can we ensure
that the objects of the image is clear under this focus?
I'm confused about this.Could anyone help me? Thanks!
Subject: Re: the concept of focus in povray?
Date: 29 Mar 2016 03:07:40
Message: <56fa29bc$1@news.povray.org>
Welcome to the club!
I suppose you are talking about focal blur and depth of field like in a
Real Life camera. Basically, the cameras in POV-Ray are pinpoint
cameras, i.e. they do not have a lens for focussing. As a result the
scene is always sharp from foreground to background.
However, focal blur (or depth of field) can be simulated in POV-Ray. The
best you can do presently imo, is to play with the example camera scenes
that are present in the scenes/camera folder of POV-Ray. You will find
there the focalblur.pov scene which you can use, besides all the other
camera types of course.
Date: 29 Mar 2016 03:19:25
Message: <56fa2c7d$1@news.povray.org>
The centre of the zone of sharpness is specified by the focal_point vector.
Regards
Date: 29 Mar 2016 07:55:00
Message: <web.56fa6cccbb7237713fdf54d50@news.povray.org>
> Thomas
Thanks a lot.I have found the focalblur.pov in the help file following your
advice~
Date: 29 Mar 2016 11:04:28
Message: <56fa997c$1@news.povray.org>
Am 29.03.2016 um 05:54 schrieb Lsq:
The plane of focus is defined by specifying "focal_point VECTOR", where
VECTOR is a point on the desired plane of focus.
You will also need to specify "aperture FLOAT", where FLOAT is the
radius (or diameter? I keep forgetting) of the camera aperture. To give
a convincing sense of scale, it should be around the equivalent of 1 cm
in scene dimensions.
The "blur_samples", "confidence" and "variance" parameters can be used
to tweak render speed and quality.
