POV-Ray : Newsgroups : povray.newusers : Real mountain 3D-profile Server Time
14 Apr 2025 11:45:43 EDT (-0400)
  Real mountain 3D-profile (Message 1 to 5 of 5)
Subject: Real mountain 3D-profile
Date: 3 Nov 2015 06:10:00
Message: <web.563895b94d395aaa426ff40@news.povray.org>
For a school project with my class, we drew a mesh over mount Pilate
(switzerland) and extracted all heights from the map. I already plotted a
3D-surface in Excel, but I thought, using povray I could somehow take a satelite
picture of the area a render a nice image of the mountain.
My problem is that I didn't use povray for a long time and thus don't know how
to do this in a quick way.
As far as I saw, I can't use height field. Should I use mesh or mesh2? How to
get my texture picture over the mesh?
Maybe somebody out there can solve my problem in no time... ;) Thanks in
advance!
Martin
Subject: Re: Real mountain 3D-profile
Date: 3 Nov 2015 07:41:43
Message: <5638ab87$1@news.povray.org>
On 3-11-2015 12:08, Martin Lacher wrote:
> Hi,
> advance!
Just thinking aloud: you will need to uv-map your mesh. I suppose you
can export the mesh as an obj file for instance, and load that into an
appropriate program like Wings3D (free) where you can uv-map the mesh,
export again and turn it into a mesh2 file with Poseray, and finally
render in POV-Ray. That is the way I would take.
Date: 3 Nov 2015 08:32:24
Message: <5638b768$1@news.povray.org>
>> Hi,
>> a satelite
>> know how
>> How to
>> advance!
This tutorial might be useful
Using UV-mapping with POV-Ray meshes
https://www.mediaport.net/CP/Artichaud/Tran/sources/tutuve.htm
Regards
Date: 3 Nov 2015 11:25:00
Message: <web.5638df43df8ec5b4fa363e170@news.povray.org>
"Martin Lacher" <fue### [at] gmxch> wrote:
> Hi,
> advance!
> Regards,
> Martin
If I understand your problem correctely mesh will be easier than mesh2. You
define a triangle for every triangle in your Excel-data and specify the
uv-vectors as the x and z component of your triangle, if y is up, or the x and y
component, if z is up. With mesh2 you have to bother about the indices of the
Vertices. Internally both objects are the same.
If you have defined proper uv-vectors you can texture your mesh with something
like
texture{
   uv_mapping pigment{ Image_map { jpeg "YourSatelliteImage.jpg"} }
Since I never plottet surfaces with Excel, I have no idea how your data are
arranged. So I can give you this hints only.
Best regards,
Michael
Date: 3 Nov 2015 19:45:41
Message: <56395535$1@news.povray.org>
when you say mesh in this context, do you mean a rectangular grid?
If so the height data is essentially an image that can be used with
height_field, except for the file format. You might be able to convert
the excel data into ppm/pgm which has an ASCII based variant and is
supported by POV-ray
   http://netpbm.sourceforge.net/doc/ppm.html
Otherwise you need to go with a mesh. Since the mesh in essence
still represents a height field it is probably not necessary to uv-map
it, defining pigment without uv-mapping will allow you to project the
the satellite imagery "from above" which should be what you need.
