POV-Ray : Newsgroups : povray.newusers : rounding and logic functions Server Time
18 Nov 2025 15:00:49 EST (-0500)
  rounding and logic functions (Message 1 to 10 of 16)
Subject: rounding and logic functions
Date: 2 Aug 2013 00:55:04
Message: <web.51fb3b6e744b4afe73fc9ebb0@news.povray.org>
I was plotting some data, (Version 3.6) and I had a lot of trouble getting
otherwise programmatically simple goals accomplished.
I see there are ceil() and floor() directives, though these seem suspect.
There's div(A,B)
There's mod(), the definition of which in the manual seems ... odd.
a remainder ought to be (A/B) - int(A/B)
But the manual says that this is them multiplied by B
Maybe I'm just ignorant abut the definition of "modulus", but then the textual
definition in the manual is misleading.
There's int()
Is there no simple ROUND() function?  To round a number to Q decimal places?
Also, how do I perform an OR comparison?
IF (X = A _OR_ B)?
Thanks again to those more knowledgeable than I.
Subject: Re: rounding and logic functions
Date: 2 Aug 2013 01:52:36
Message: <51fb4924$1@news.povray.org>
Am 02.08.2013 06:54, schrieb Bald Eagle:
What's wrong with them?
That would be the fractional part of a division result, not the remainder.
Suppose you have ten pieces of cake, you have to split them fairly among
three children, and cutting a piece into smaller ones is not an option.
What's the result? Of course each child gets three pieces of cake, with
one piece of cake /remaining/. Hence, an integer division of 10/3 yields
3, and a /remainder/ of 1.
What's misleading about that? The formula given is unambiguous, the
statement that mod(A,B) gives the value of A modulo B is straightforward
(and true), and the statement that it returns the remainder after the
integer division of A/B is also simple and true.
You can achieve a round-to-nearest-integer using ceil(X-0.5); You can
achieve a round-to-Q-decimal-places by multiplying before and dividing
after, such as in:
     ceil( X*pow(10,Q) - 0.5 ) * pow(0.1,Q)
> IF (X = A _OR_ B)?
simple - just perform two individual comparisons and apply the OR
operator ("|"):
#if ((x = a) | (x = b))
Date: 2 Aug 2013 02:01:40
Message: <51fb4b44$1@news.povray.org>
Am 02.08.2013 07:52, schrieb clipka:
> the
> (and true)
(...though strictly speaking it should state that mod(A,B) gives the
smallest value that is "equivalent modulo B" to A, but nobody in the
world of computer programming would express it this way)
Date: 3 Aug 2013 11:10:01
Message: <web.51fd1cfc87475f8873fc9ebb0@news.povray.org>
I was doing a simple #if - #else - #end loop and trying to trigger an update
once every "hour".
#if ( Time1 = ceil ( Time1 ) )
They just seemed to operate opposite to how I expected, but it could just be
that I was tired and the problem was my brain, not the functions.  I'm going to
investigate further.  With coffee.  :)
Your cake analogy cleared that up immensely.  I now can "see" the process
clearly in my mind.  Thanks!
> after, such as in:
Right.  I guess I wanted truly simple and straightforward, not the "you can
write your own formula for doing what should only t5ake invoking an easily
remembered and commonly used command".
It's also rather frustrating to a noob when searching for "round", and there's
no cross-index for floor and ceil, terms which no one would ever think to search
for.
> operator ("|"):
Oh.  Bald Eagle, meet the OR operator.  OR operator, Bald Eagle.  I'll let you
two get acquainted.
That would have been a helpful cross index as well.
I searched for OR, Boolean, comparators, if, logic, functions, ....   no OR.
Date: 3 Aug 2013 17:20:16
Message: <51fd7410$1@news.povray.org>
Am 03.08.2013 17:08, schrieb Bald Eagle:
>> after, such as in:
> for.
Well, that would be too easy, wouldn't it :-P
Frankly, I'm not the best person to discuss documentation matters; I'm
happy when I can dump my description of new features into someone else's
lap, and let them sort out where it fits best, where it should be
cross-linked, and all that sort of stuff. James Holsenback has been
doing great work in that respect, and he also has been giving the
documentation a general facelift; I guess he'll be happy about hints
like yours pointing out potential for even further improvement. After
all there's one thing that becomes more and more difficult the more one
gets acquainted to a piece of software and its documentation: To notice
potential problems that new users might run into.
Date: 3 Aug 2013 17:55:01
Message: <web.51fd7bae87475f8873fc9ebb0@news.povray.org>
Right-o.  What's life without a challenge, eh?
Indeed.  You acheive a certain myopia and over-familiarity.  That's why you have
OTHER people proofread your work, because you tend read right THROUGH the
errors.
I'm trying to illustrate to myself how things work, so maybe some of those ideas
will help out with clarifying the docs.
Date: 3 Aug 2013 18:35:39
Message: <51fd85bb$1@news.povray.org>
> once every "hour".
Using such a loop would only work for a *very* long parse operation as
it can only be evaluated during that time. When rendering or editing
your scene, the loop is never used.
Date: 3 Aug 2013 18:56:15
Message: <51fd8a8f$1@news.povray.org>
> errors.
What did you have in mind ... I could add an index entry to ceil and
floor so they come up when round is the search term. That would be on
windows version only. Mileage may vary. As far as expanding the
reference section
http://wiki.povray.org/content/Reference:Numeric_Expressions#Functions
(where ceil and floor are mentioned) I don't see a lot of room there
given the format used for the rest of the functions. Maybe a small
example /could/ be made to fit into the current scheme, but that
/really/ doesn't do anything to address the fact you weren't aware that
ceil and floor could be used like clipka showed ... at the moment kings
x on coming up with a different layout. For the heck of it I took a
quick tour of the tutorial and see that it's lacking in any sort of
information about writing functions, so I guess I'm out of ideas
Date: 3 Aug 2013 21:45:01
Message: <web.51fdb16487475f8873fc9ebb0@news.povray.org>
Well, to start off, I find that things like this help me to understand things
WAY more than text.
http://news.povray.org/povray.binaries.tutorials/thread/%3Cweb.51f61e827603294573fc9ebb0%40news.povray.org%3E/
A picture's worth a thousand words, and all that.
Here's what my first impressions are when I look at that wiki page:
That green text is WAY too small.
I don't know what a unary minus or a unary plus is.
I'd expect mention of exponential functions in the precedence listing.
I'd also point out that (A^2) is not a valid expression - pow(x,2) is the way to
write that in POV-Ray.  And don't confuse pow() with pwr().
I think I tried doing an #if (X=<Y), but the <has to precede the =
I don't know what a bit-wise operation is
THEN should be searchable and linked to the ? operator
abs(A)
Absolute value of A. If A is negative, returns -A otherwise returns A.
#debug concat ("ABS -1 = ",str(abs(-1),3,0)) returns 1, not -1.
I don't know what hyperbolic trig functions are (off the top of my head)
#declare Step = 0;
#while (Step <= 2)
#debug concat ("Number = ",str(Step,3,1))
#debug "\n"
#debug concat ("ceiling = ",str(ceil(Step),3,1))
#debug "\n"
#debug concat ("floor = ",str(ceil(Step),3,1))
#debug "\n"
#debug "\n"
#declare Step = Step + 0.1;
Floor and ceiling return the same value.
THAT's what's wrong with them.
For the function inside(), what is the "object identifier"? is that something
like #declare O=object{}?
strlen() is useful for text functions, but for rendering text in an image, I'd
like to know how large that text will actually be.
You have tan(A) and tanh(), but tan2(A,B) is ... elsewhere.
will val(s) accept val("3X")?
I HAD to render and animate the dot product file in order to understand what it
did.  The text didn't help me understand that it was a vector perpendicular to
the two vectors I was ... dotting.
.... and as a noob, I find it a little disorienting when an example uses some
obscure POV-Ray function without a prior simple/common one...
#if (image_width < 300) crand 0.1 #else crand 0.5 #end
.... because now I have to interrupt my train of thought and go off on some
tangent to look up what "crand" is.
So, there's an example of my constructive criticism.
Feel free to email me with requests for illustrations or proofreading /
commentary.
Thanks for what I'm sure is a TON of hard work, James.  I've been there, so I
know what it's like.
Date: 3 Aug 2013 21:55:01
Message: <web.51fdb3a287475f8873fc9ebb0@news.povray.org>
> > once every "hour".
> Alain
Well, the parse and render phases are something I need to better understand,
because I long to do cool stuff with functions and macros, and I've seen that
asked plenty of times.  Lots of reading and experiments for me.
I used the loop in my render, and it seemed to work fine.
   #declare A = A + B;
   #declare B = B + 2;
   text { ttf "arial.ttf" str (B, 3, 0) 0.1, 0 translate <Time1-2,
Level1*Y_Factor+2, -0.4> pigment {color Yellow}}
   #debug concat ("Time1 = ", str (Time1, 3, 1))
   #debug "\n"
   #debug concat ("A = ", str (A, 3, 1))
   #debug "\n"
  #else
  #end // end if
once I got the #if comparator right, it worked just like I expected it to.
#if ( Time1 / Step = int (Time1/Step)  DID NOT work.
Go figure.
