POV-Ray : Newsgroups : povray.newusers : Singularity Server Time
26 Jun 2024 08:04:20 EDT (-0400)
  Singularity (Message 1 to 10 of 10)
Subject: Singularity
Date: 18 Jan 2013 07:10:00
Message: <web.50f93b2668285565377391f20@news.povray.org>
when I put a camera in the focal point of a prabolic mirror it looks like there
is a singularity. But this constilation is exactly what I need/want. Is there a
posibillity to change the way of calculation from povray or something else what
I can do?
thx,
  Tim
Subject: Re: Singularity
Date: 18 Jan 2013 08:28:20
Message: <50f94df4$1@news.povray.org>
Am 18.01.2013 13:08, schrieb timer:
> I can do?
Well, what do you expect?
At the focal point of a parabolic mirror, by its very nature, it doesn't
matter where you look - you'll always see whatever is placed right in
the optical axis of the mirror.
Date: 18 Jan 2013 09:25:01
Message: <web.50f95aefdf0a0378377391f20@news.povray.org>
That would be awesome because this is what I want. But unfortunately it's get
black when I move the camera in the focal point. A little but over and under
that focal point it looked nice, but this is, for me, the wrong view point.
Date: 18 Jan 2013 10:31:16
Message: <50f96ac4$1@news.povray.org>
Am 18.01.2013 15:24, schrieb timer:
That's surprising to me. Can you give a sample scene?
Date: 18 Jan 2013 13:50:01
Message: <web.50f9993bdf0a037848a9cfc40@news.povray.org>
During generating a sample scene I realize that this work. So I worked reverse
to localize my real problem.
It look like a combination of two paraobolic mirrors generate this singularity.
##### SAMPLE CODE #####
global_settings {
        max_trace_level 5
//      location <300,250,-50>  // sideview
        location <0,100,-1>     // worked
//      location <0,100,0>      // doesn't worked
//      location <0,100,1>      // worked
        look_at <0,100,20>
light_source {
        <0,2000,0>
        color rgb <1,1,1>
plane {
        y, 0
                checker color rgb<0,0,0> color rgb<1,1,1>
        scale <100,100,100>
plane {
        y, 10000
        pigment { color rgb<0,0,1> }
        finish {
                ambient 0.6
// Parabel 1
intersection {
        quadric {
                <-5/132,-5/132,0>
                <0,0,0>
                <0,0,-1>
                33/5
        box {
                <-4,-4,4>
                <4,4,8>
        scale <10,10,10>
        finish {
                metallic
                reflection 1
        translate <0,100,0>
// Parabel 2
quadric {
        <5/26,5/26,0>
        <0,0,0>
        <0,0,1>
        7/10
        scale <10,10,10>
        finish {
                metallic
                reflection 1
        translate <0,100,0>
##### END SAMPLE CODE #####
Date: 18 Jan 2013 14:48:37
Message: <50f9a715@news.povray.org>
Am 18.01.2013 19:49, schrieb timer:
It appears to me that the quadric solver goes berserk on the second
parabola whenever a ray is exactly parallel to the parabola's axis
(which happens when the camera is exactly in the first quadric's focal
point, but I suspect it would also happen with an orthographic camera).
At present my only idea would be to try modeling the second parabola
with some other primitive type (isosurface for instance) - and to file a
bug report on http://bugs.povray.org.
Date: 18 Jan 2013 15:26:28
Message: <50f9aff4@news.povray.org>
Am 18.01.2013 20:48, schrieb clipka:
Turns out that this is not /precisely/ true. Actually the problem occurs
when the ray is /almost/ parallel to the parabola's axis (which happens
because when reflected earlier at the other parabola there are ever so
slight rounding errors). In such a case the algorithm gags on precision
issues.
Date: 18 Jan 2013 16:10:57
Message: <50f9ba61$1@news.povray.org>
Le 18/01/2013 21:26, clipka nous fit lire :
> issues.
would sturm help ?
(quadric does not seem to be documented to like sturm, but a change of
syntax for a poly ? hmm not sure)
Date: 18 Jan 2013 16:28:11
Message: <50f9be6b$1@news.povray.org>
Am 18.01.2013 22:10, schrieb Le_Forgeron:
>> issues.
> would sturm help ?
Quadrics use their own specialized root solving code.
But the code can apparently be fixed by replacing a "(a != 0.0)" test
with "(fabs(a) >= EPSILON)".
Date: 19 Jan 2013 04:10:01
Message: <web.50fa623fdf0a03783f7fc4420@news.povray.org>
Now I made the second parabolic with poly and it worked very well. With and
without sturm.
Thank you very much.
