POV-Ray : Newsgroups : povray.newusers : How to make a simple CSG "readable" by humans Server Time
11 Oct 2025 01:02:34 EDT (-0400)
  How to make a simple CSG "readable" by humans (Message 1 to 7 of 7)
Subject: How to make a simple CSG "readable" by humans
Date: 4 Sep 2012 11:00:01
Message: <web.504616b15fadc892408aa4ce0@news.povray.org>
I have now succeeded in making my povray file (my thanks to those who helped on
my coordinate question).
It's effectively a piece of parameter driven CAD, which results in a quite
simple shape. It works correctly, but not well.
As it stands, the shape is actually hard to make out and understand, since in
the tiny POV file the lighting, textures and "environmental context" are all
vestigial.
Is there a standard context in which I could place my item, so that it's more
"readable" to a normal human being?
   BugBear
Subject: Re: How to make a simple CSG "readable" by humans
Date: 4 Sep 2012 16:54:26
Message: <50466a82$1@news.povray.org>
Do you mean that there is no background or ground plane in your scene?
If that is the case. In the menu
Insert > Ready_Made scenes > take your pick. ;-)
A chequered plane is traditional along with a sky sphere.
Regards
Date: 5 Sep 2012 05:55:00
Message: <web.5047207b50db82f9408aa4ce0@news.povray.org>
I'm using vim and the command line on Linux to render (I will
eventually be doing a permuted batch run of my POV for various
parameters)
Can you tell me the textual equivalent of the menu command you suggest?
 BugBear
Date: 5 Sep 2012 15:34:16
Message: <5047a938$1@news.povray.org>
> parameters)
Sorry, no I can't. I use Window$
But here is one of the basics scenes that you can paste into your scene.
Comment out the cameras if required.
// PoVRay 3.7 Scene File " ... .pov"
// author:  ...
// date:    ...
#version 3.7;
global_settings{ assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 }}
// camera ------------------------------------------------------------------
#declare Camera_0 = camera {perspective angle 75               // front view
                             location  <0.0 , 1.0 ,-3.0>
                             look_at   <0.0 , 1.0 , 0.0>}
#declare Camera_1 = camera {/*ultra_wide_angle*/ angle 90   // diagonal view
                             location  <2.0 , 2.5 ,-3.0>
#declare Camera_2 = camera {/*ultra_wide_angle*/ angle 90  //right side view
                             location  <3.0 , 1.0 , 0.0>
#declare Camera_3 = camera {/*ultra_wide_angle*/ angle 90        // top view
                             location  <0.0 , 3.0 ,-0.001>
camera{Camera_0}
// sun
light_source{< 3000,3000,-3000> color White}
// sky
sky_sphere { pigment { gradient <0,1,0>
                        color_map { [0.00 rgb <0.6,0.7,1.0>]
                                    [0.35 rgb <0.1,0.0,0.8>]
                                    [0.65 rgb <0.1,0.0,0.8>]
                                    [1.00 rgb <0.6,0.7,1.0>]
                        scale 2
                      } // end of pigment
            } //end of skysphere
// ground
plane{ <0,1,0>, 0
        texture{ pigment{ checker color rgb<1,1,1>*1.2 color
rgb<0.25,0.15,0.1>*0}
               //normal { bumps 0.75 scale 0.025}
                 finish { phong 0.1}
               } // end of texture
      } // end of plane
//---------------------------- objects in scene ----------------------------
// sample sphere
sphere { <0,0,0>, 1.00
          texture { Polished_Chrome
                    //pigment{ color Red } // rgb< 1, 0.0, 0.0>}
                    //finish { phong 1 reflection {0.40 metallic 0.5}}
                  } // end of texture
           scale<1,1,1>  rotate<0,0,0>  translate<0,1.35,0>
        }  // end of sphere -----------------------------------
Regards
Date: 5 Sep 2012 17:20:52
Message: <5047c234$1@news.povray.org>
> vestigial.
>     BugBear
A simple, minimal, start point (copy and paste in your scene):
plane{y, -5 pigment{checker}} // A ground plane using default solours.
//Placed under the reference plane in case your object extend under it.
plane{-z, -100 pigment{checker rgb<1,1,0> rgb 0.3}}
// A back plane some distance away.
Those planes use the checker pattern. Each case is exactly one unit whide.
If those a to small or large, you can scale the pattern up or down as
needed. If you scale the planes, the location will also change.
You can also adjust the location of the planes. Change the value of the
number after the Y and Z.
Now, look at your objects textures. It may be a good idea to add some
elements like those: (you don't need to use them all)
Add some highlights:
specular 0.7 roughness 0.01 // Small = tight highlights
phong 0.7 phong_size 150 // Large = tight highlights
// It tends to greatly improve your feel of the shapes.
//You can use both or only one or the other.
Change the brilliance of the surface:
brilliance 1.5 // Makes the object looks more shiny. The illumination
// is more affected by the incident angle than default.
// values less than 1 are possible but greatly flatten things.
// a value of zero will make things look cartoonish...
In some cases, adding some reflection can help:
reflection{0.1 0.5}
Adding one or more dim, optionaly coloured, light can improve things:
light_source{<-1000,500,-10>rgb<0.001, 0.002, 0.3>}
Date: 6 Sep 2012 09:20:00
Message: <web.5048a26650db82f9408aa4ce0@news.povray.org>
As background to all this, my goal is to be able to synthesise
images of saw teeth under different sharpening methods
This guy's a friend of mine:
http://www3.telus.net/BrentBeach/sawjig/sketchup.html
I would like to be able to take the angles that describe a sharpening
and auto-magically make an image; I would (ideally) like to take
a set of angles, and make a whole gallery of images.
This may involves few CPU cycles ;-)
Here's a fairly good photograph of real teeth
http://i279.photobucket.com/albums/kk132/daryl_weir/DSC04946.jpg
Here's my CSG results (all parameterised up, the maths is fine)
http://i48.photobucket.com/albums/f234/bugbear33/misc/far.png
http://i48.photobucket.com/albums/f234/bugbear33/misc/close.png
  BugBear
Date: 7 Sep 2012 06:00:00
Message: <web.5049c51b50db82f9408aa4ce0@news.povray.org>
I've now followed this guy's tips
http://warp.povusers.org/povtips/
After an 18 hour renderat 1200x800, I have this:
http://i48.photobucket.com/albums/f234/bugbear33/misc/scene.jpg
Not sure it was worth 18 hours, but not bad.
 BugBear
