POV-Ray : Newsgroups : povray.newusers : Advice on rendering a topographic scene Server Time
16 Dec 2025 08:12:54 EST (-0500)
  Advice on rendering a topographic scene (Message 1 to 8 of 8)
Subject: Advice on rendering a topographic scene
Date: 28 Aug 2012 08:00:00
Message: <web.503cb1ead916b0083999cf850@news.povray.org>
I admire a lot the work of Diana Lange.
She uses Cinema4D to render DXF models built with the Processing software.
I'd like how the same could be achieved using Pov Ray.
Here is a sketch of what I'm trying to get:
http://24.media.tumblr.com/tumblr_m09z83dVUZ1qzngato1_500.jpg
What I notice on her rendering is:
- this kind of shadow on the ground, very diffuse
- this very subtile blue light
- this "cream aspect"
As I'm a beginner, I wonder how, which elements to use in my .pov script to get
similar results
Thanks in advance for any help,
Mathieu
I already have a scene that renders a landscape but it's not alike. Here is the
script:
# include "colors.inc"
# include "textures.inc"
background {White}
light_source { < 667167, 60000, 4040564 > color White }
   look_at <667101.25310945, 600, 4042753.78420398 > //easting, elev, northing
   location < 666850, 1000, 4060343 > //easting, elev, northing
   angle  50 // vertical camera aperture
height_field  {
   tga "IN\dem.tga"
   smooth
pigment{
rgb <1,1,1>
  finish {           // (---surface finish---)
    ambient 0.3
    brilliance 9
   scale < 14000, 50000, 14000 > // dx,dz,dy of extent in meters
   translate  <660575, 0, 4036730> // west_corner, 0, south_corner
  sky_sphere {
      gradient y
      color_map {
        [0 color Grey]
        [1 color White]
      scale 2
      translate -1
plane {
    y, -200
    pigment { color Grey }
    finish {
    ambient .8
    diffus
Subject: Re: Advice on rendering a topographic scene
Date: 28 Aug 2012 10:03:43
Message: <503ccfbf$1@news.povray.org>
Am 28.08.2012 13:56, schrieb mathieu_r:
Try area lights for this (see "area_light"), or a completely
radiosity-lit scene (see "radiosity").
Multiple light sources: A bright blue one from the left, and a white one
from the right.
Alternatively (when using radiosity-based illumination) a bright blue
sky, and a yellowish light from the right that, together with the blue
sky, adds up to a nice plain white.
I guess that's just the very diffuse lighting, and maybe the choice of
colors.
Note that the reference image doesn't use a simple plane & background,
but something curved, like a hollow shell.
The reference image also clearly uses global illumination (otherwise we
couldn't see the structure of the underside); in POV-Ray, that can be
achieved by using radiosity.
Date: 28 Aug 2012 10:09:31
Message: <503cd11b$1@news.povray.org>
> colors.
I guess that a bit of fog might also be needed.
Date: 29 Aug 2012 03:15:02
Message: <web.503dc14e99d682a9270882f00@news.povray.org>
Thanks a lot for your advice.
Here is my actual image.
Would you see any improvement to be done so as it looks like Diana Lange's
rendering?
-> "completely radiosity-lit"
I have put some radiosity on my scene, also some light sources. How to make it
**completely** radiosity-lit
-> "a bright blue"
How to influence on light brightness?
We can influence the light brightness by making it far from the object?
-> "very diffuse lighting"
How to make lighting very diffuse?
-> "I guess that a bit of fog might also be needed."
Does the fog paramter seem correct to you?
Thanks,
Mat
Here is my script:
# include "shapes.inc"
# include "skies.inc"
# include "rad_def.inc"
global_settings {
   radiosity {
      Rad_Settings(Radiosity_Normal,off,off)
background {Grey}
        location <7,10,-13>
        look_at <0,0,0>
        angle 70
light_source {
        <0,5,-50>
              color White
              area_light
              <30,0,0>  <0,0,30>
              4,4 // numbers in directions
              adaptive 0  // 0,1,2,3...
              jitter // random softening
              translate<-10, 50,  -10>
light_source {
        <0,50,100>
              color MidnightBlue
              area_light
              <30,0,0>  <0,0,30>
height_field {
        png
        "IN\dem.png"
        smooth
        texture{
        pigment { White }
        finish {
        ambient 0.1
        diffuse 0.55
        translate <-0.5,0,-0.48>
        scale <14,4,14>
plane {
    y, -5
    finish {
    ambient .9
    diffuse .3
    roughness 1
fog {
    distance 30
    color rgbf<0.6, 0.6, 0.6, 0.1>
    turbulence 0.1
    turb_depth 0.8
Date: 29 Aug 2012 03:25:01
Message: <web.503dc2d999d682a9270882f00@news.povray.org>
Sorry, I forgot to include my image:
https://docs.google.com/open?id=0B2ZYzwKbiu3JUFlla19PUndJNW8
> rendering?
> -> "a bright blue"
> Thanks,
> Mat
> Here is my script:
> global_settings {
>    radiosity {
> background {Grey}
> camera {
>         location <7,10,-13>
>         look_at <0,0,0>
>         angle 70
> light_source {
>         <0,5,-50>
>               color White
>               area_light
>               <30,0,0>  <0,0,30>
> light_source {
>         <0,50,100>
>               color MidnightBlue
>               area_light
>               <30,0,0>  <0,0,30>
> height_field {
>         png
>         "IN\dem.png"
>         smooth
>         texture{
>         pigment { White }
>         finish {
>         ambient 0.1
>         diffuse 0.55
>         scale <14,4,14>
> plane {
>     y, -5
>     finish {
>     ambient .9
>     diffuse .3
>     roughness 1
> fog {
>     distance 30
>     turbulence 0.1
>     turb_depth 0.8
Date: 29 Aug 2012 03:41:20
Message: <503dc7a0$1@news.povray.org>
Please, attach your image to a message in povray.binaries.images
(p.b.i.). That is the way to show your work in these newsgroups.
I, for one, do not use google docs.
Date: 29 Aug 2012 16:15:40
Message: <503e786c$1@news.povray.org>
I might but I get this message:
You need permission to access this item.
You are signed in as ME### [at] gmailcom, but you don't have permission to
access this item. You can request access from the owner or choose a
different account. Learn more
Regards
Date: 2 Sep 2012 14:15:16
Message: <5043a234$1@news.povray.org>
You need to set access right for that image to Everybody, or manualy
grant access permision to everybody, one by one.
