POV-Ray : Newsgroups : povray.newusers : Gamma Settings Server Time
2 Jul 2024 03:03:48 EDT (-0400)
  Gamma Settings (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Gamma Settings
Date: 5 Mar 2012 18:36:35
Message: <4f554e03$1@news.povray.org>
clipka wrote:
> Strictly speaking, POV-Ray 3.7 doesn't introduce a fully new gamma
> handling concept at all; it just (1) obsoletes the 3.6 default of not
> performing any gamma handling at all
Does this mean if you already used assumed_gamma 1.0 in 3.6
then your rgb colors will render the same with #version 3.7?
Date: 5 Mar 2012 18:51:39
Message: <4f55518b$1@news.povray.org>
Am 06.03.2012 00:36, schrieb Christian Froeschlin:
Yes.
Date: 6 Mar 2012 12:01:56
Message: <4f564304@news.povray.org>
> It might make /some/ sense to add a kind of "prgb" keyword; the rgb
> keyword actually means "physical colors" /only/ if assumed_gamma is set
> to 1.0. This interpretation of "rgb" is backward compatible with 3.6.
  I don't think "rgb" is generally considered to describe the amount of
radiant energy (measured in Joules) reflected by a surface (so that for
example "rgb 0.5" means that the surface reflects half of the incoming
radiant energy), but rather the *perceived* color of the surface (iow.
"rgb 0.5" means that the surface *looks* exactly half as bright as
"rgb 1").
  Measuring things in terms of perceived brightness is way more common than
in terms of absolute radiant energy. For instance, most SI units related to
light, such as the lux and the candela, measure perceived brightness.
Date: 6 Mar 2012 12:27:06
Message: <4f5648ea$1@news.povray.org>
Am 06.03.2012 17:33, schrieb Warp:
> "rgb 1").
Careful when using those terms: While the luminous flux (measured in
lux) and luminous intensity (measured in candela) do include some
correction to account for /some/ peculiarities of human perception,
these are limited to wavelength-dependent weighting, and doesn't account
for gamma-like effects. For any given hue and saturation, the units
still represent light intensity /linearly/.
Thus, a luminous flux of 0.5 lux is still perceived as about 73% as
bright as a flux of 1.0 lux.
Date: 6 Mar 2012 21:05:00
Message: <web.4f56c156e3adea41345179960@news.povray.org>
> >    It becomes a bit more problematic when you are not defining the colors
> > yourself, but are using a pre-defined texture (eg. from an include file).
> > Now, I don't remember if something was added to POV-Ray 3.7 to "convert"
> > such a pre-defined texture into 'srgb' on the fly.
Ok, well in looking at all the include files from the folder
"POV-Ray\v3.7\include" (stones1, stones2, textures, colors, etc) they all say
they're for version 3.5. Are they the wrong ones to be using with 3.7?
> No, indeed not. I guess the proper solution there is to overhaul the
> standard include files to use "srgb" throughout.
So are you saying I should do a Find and Replace for everything "rgb" and
replace with "srgb" in these include files? Actually, most of the "rgb"
statements are "rgbt". whatever that means..
Date: 7 Mar 2012 01:18:03
Message: <4f56fd9b$1@news.povray.org>
Am 07.03.2012 03:01, schrieb JamesB7271:
They're the official ones that come with 3.7, if that's what you're
asking. That doesn't mean they're ideal for 3.7 though.
Maybe a good thing would be to copy the files (maybe name them
"stones1_srgb.inc", for instance), and modify those copies.
Besides "rgb", which defines a color in terms of red, green and blue,
there are also keywords that define the color's transmit and/or filter
value at the same time; those are "rgbt", "rgbf", and "rgbft".
The keywords "srgbt", "srgbf" and "srgbft" also exist.
Date: 8 Mar 2012 20:00:02
Message: <web.4f595563e3adea41345179960@news.povray.org>
Ok, I did a Find and Replace on my stones2.inc file (well the new
stones2_srgb.inc file) and replaced everything "rgb" with "srgb". So "rgbt" now
becamse "srgbt".
That appears to have worked. The textures I was using for these sample renders
now look normal again (much richer color definition) instead of all washed out.
So the problem actually was a mismatch of version 3.7's new use of srgb and the
lack of srgb values in the old 3.5 include file 3.7 was processing. Correct?
Thank you so much everyone for all your assistance in clearing this up. I now
feel confident that everything is "right" so I can start moving forward..
Thanks,
-James
Date: 8 Mar 2012 20:31:12
Message: <4f595d60$1@news.povray.org>
Am 09.03.2012 01:57, schrieb JamesB7271:
Yup.
Date: 9 Mar 2012 03:45:04
Message: <4f59c310@news.povray.org>
> becamse "srgbt".
  I think it would be better if there was some way of specifying an
assumed_gamma for a declared texture. Perhaps something like:
    texture { some_declared_texture assumed_gamma srgb }
or something similar.
Date: 9 Mar 2012 10:34:56
Message: <4f5a2320$1@news.povray.org>
Am 09.03.2012 09:45, schrieb Warp:
>> becamse "srgbt".
Hm... I do have some doubts whether this could actually fly, but I'll
ponder the idea.
