POV-Ray : Newsgroups : povray.newusers : Floor configuration Server Time
4 Jul 2024 03:48:13 EDT (-0400)
  Floor configuration (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Floor configuration
Date: 5 Oct 2011 17:02:47
Message: <4e8cc5f7$1@news.povray.org>
Am 05.10.2011 10:03, schrieb Stan:
> global_settings {
>    assumed_gamma 1.4
I strongly suggest you use assumed_gamma 1.0; it's the only way to get
proper color math.
Date: 5 Oct 2011 17:11:39
Message: <4e8cc80b$1@news.povray.org>
>      sphere {
>     <0,0,0>,10000
>     pigment {
>       image_map { hdr "entrance1_color" once interpolate 2 map_type 1 }
>     finish {  emission 1 }
>     hollow
>     no_image
>     no_reflection
>            no_shadow
Try reducing the emission; most HDR images are too bright to be used
with emission 1, and may "drown" any reflections in a sea of pure white.
Date: 6 Oct 2011 03:10:01
Message: <web.4e8d542f753269962874e1cc0@news.povray.org>
> Also note that with HDR (i.e. radiosity-based) illumination, the
> brilliance, specular and roughness parameters have no effect.
This is the question! Thank you for you answer. But I ask how to configure floor
to have brilliance, and other. I make mistake, I use not black pigment, I use
white. Is it possible? I am new user of Pov-Ray and don't know a lot.
Date: 6 Oct 2011 03:20:53
Message: <4e8d56d5$1@news.povray.org>
pigment { rgb <0,0,0> } is black, pigment { rgb <1,1,1> } is white,
pigment { rgb <1,0,0> } is red and so on.
Regards
Date: 6 Oct 2011 03:50:00
Message: <web.4e8d5c9b753269962874e1cc0@news.povray.org>
Thank you. I  asking is it possible ti make brilliance and other, while using
hdr lighting?
Date: 6 Oct 2011 12:17:30
Message: <4e8dd49a$1@news.povray.org>
Am 06.10.2011 09:45, schrieb Stan:
>> pigment { rgb<0,0,0>  } is black, pigment { rgb<1,1,1>  } is white,
>> pigment { rgb<1,0,0>  } is red and so on.
> hdr lighting?
There are tools that generate a bunch of classic light sources from a
HDR image (a so-called "light dome"); one such piece of Software is
LightMapGen. At present, that's the closest you can get to having HDR
lighting while still being able to tweak brilliance, specular etc.
Date: 6 Oct 2011 18:15:00
Message: <web.4e8e27897532699612df0ba0@news.povray.org>
Thank you. My last question. Why when I use HDR my floor is gray? I use pigment
color <1,1,1> Even with emission 1.I like model I get, but I want white floor.
Help me please.
Date: 7 Oct 2011 16:18:23
Message: <4e8f5e8f@news.povray.org>
> color<1,1,1>  Even with emission 1.I like model I get, but I want white floor.
> Help me please.
If your floor is reflective, give it something white to reflect.
You can use reflection{... metallic}. This will tint the reflection in
white.
You can give it a colour larger than 1, but it's not realistic and can
introduce some other problems.
It's also possible to have a diffuse value larger that 1, but it can
cause other problems.
Date: 7 Oct 2011 19:39:43
Message: <4e8f8dbf$1@news.povray.org>
Am 07.10.2011 00:11, schrieb Stan:
> Help me please.
If you think your floor is too dark, increase the emission of the HDR
sphere; you can safely set it to values greater than 1.
Date: 8 Oct 2011 07:42:05
Message: <4e90370d@news.povray.org>
but isn't it strange not to get full white with pigment 1
and emission 1, regardless of environment? Even with HDR output
it seems to me the output is maxed out so additional lighting
and reflections have no effect (unless negative?).
Actually this led me to play around with negative finish values:
Negative ambient and emission seem to work fine, diffuse
lighting and reflections seem to be clipped at 0 (tried
using 3.7RC3). I'd vote for allowing negative values there
too - light sucking reflections might surely be fun ;)
The effect of diffuse < 0 can also be achieved with
negative light sources, of course, but then affects
all objects).
