POV-Ray : Newsgroups : povray.newusers : Animate Text Around a Sphere Server Time
7 Jul 2024 06:36:57 EDT (-0400)
  Animate Text Around a Sphere (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Animate Text Around a Sphere
Date: 9 Apr 2011 04:48:07
Message: <4da01d47$1@news.povray.org>
On 09/04/2011 12:20 AM, Alain wrote:
> Then, don't use a modeler for your text but use the text primitive to
> create your individual letters. Unless a letter appears 100's times,
> you'll use much less memory, you'll save parsing and loading time, and
> the difference in render time won't be that important. Also, no faceting
> nor mesh artefacts.
> Anyway, the letters from those modelers are mesh objects, one mesh
> object per letter, even for a word, with duplicated letters in the word
> as several meshes.
As StephenS pointed out.
Bishop3D exports SDL code.
> Missusing union causes many "Sould have more than one
> objects in CSG".
Yes my constant companion. :-(
But a necessary evil.
> It also makes your code ugly.
I can't say that I agree with either you or StephenS. Machine written
code is never elegant, from the little I've seen. So what difference
does an extra line or two make?
Anyway it is years since we have had the coders ranting on about how
using a SDL modeller is an affront to the very idea of Pov-Ray.
Regards
Date: 9 Apr 2011 05:23:47
Message: <4da025a3$1@news.povray.org>
>> objects in CSG".
You could suggest to the Bishop3D team that unions
with one element get exported as object instead.
Date: 9 Apr 2011 05:38:45
Message: <4da02925$1@news.povray.org>
On 09/04/2011 10:23 AM, Christian Froeschlin wrote:
>>> objects in CSG".
I obviously did not make myself clear. Putting a single object in a
union is a workaround because Bishop3D does not have a local axis and if
you want to rotate the object around a point, that is the only way to do it.
If Bishop3D did as you suggest then it would break its import feature
and import the object as fixed at the point of import.
I did, of course, suggest to the development team that a local axis
would be useful. That was some years ago.
Regards
Date: 9 Apr 2011 06:30:00
Message: <web.4da0351dabacefca795598320@news.povray.org>
> code is never elegant, from the little I've seen...
To be some what more complete:
I also find any SDL code with 5 to 8 indent spacing hard to read and change to 1
or 2 spacing before I continue.
Stephen S
Date: 9 Apr 2011 14:57:35
Message: <4da0ac1f@news.povray.org>
>>>> objects in CSG".
> it.
Not at all.
POV-Ray also don't have "local" axis, only 1 set of global axis.
If the object is named, then there is NO need to use union.
Whenever you find yourself placing a single object in an union, use
"object" instead.
If you want to place several objects around an axis at a given radius,
then the way to do it is:
union{
  object{Object1 translate Radius rotate<x,y,z>}//Correct
  object{Object2 translate Radius rotate<x,y,z>}
rotate Global_Union_Rotation
translate Global_Object_Location
You wrongly suggers this:
union{
  union{Object1 translate Radius rotate<x,y,z>}//NOT correct
  union{Object2 translate Radius rotate<x,y,z>}
Anyway, it's usualy beter to model all objects around the origin, scale
and rotate them as needed, then to translate them to the desired location.
A lamp should reside with it's base at y=0.
A door with it's hinge at x=0, z=0.
A cabinet with it's back at x=0 or z=0.
Date: 9 Apr 2011 17:02:20
Message: <4da0c95c$1@news.povray.org>
>> it.
> Not at all.
Not at all, what? That I not make myself clear or that it is the only
way to do it in Bishop3D?
I'm probably using the terminology used by Moray that is confusing you.
> "object" instead.
I take it that you've not used either Moray or Bishop3D much. In case we
are talking at cross purposes. My last post was in reply to a suggestion
that Christian made about Bishop3D
> union{
No, what I meant was this:
union {
  sphere {  // Sphere0
   0.0, 1.000000
   translate <0.0,0.0,14.0> // Radius of revolution
  }  // end Sphere0
  rotate    <0.0,27.0,0.0> /* Required rotation about the centre of
revolution*/
  translate <-10.0,0.0,10.00> // Centre of revolution
Yesss, but when using a modeller you do that then leave them where they
are and use the method I described. Moray is different as it gives you
an extra degree of freedom and you don't need to use an extra union.
Regards
Date: 11 Apr 2011 12:17:15
Message: <4da3298b@news.povray.org>
> union {
> sphere { // Sphere0
> 0.0, 1.000000
> } // end Sphere0
> rotate <0.0,27.0,0.0> /* Required rotation about the centre of revolution*/
This should be:
object{
  sphere {  // Sphere0
   0.0, 1.000000
  }  // end Sphere0
revolution*/
Date: 11 Apr 2011 15:19:20
Message: <4da35438$1@news.povray.org>
On 11/04/2011 5:17 PM, Alain wrote:
> This should be:
> object{
> sphere { // Sphere0
> 0.0, 1.000000
> } // end Sphere0
Maybe it should be but it isn't.
Regards
Date: 15 Apr 2011 20:50:00
Message: <web.4da8e69fabacefca6811d79b0@news.povray.org>
> > This should be:
> > object{
> > sphere { // Sphere0
> > 0.0, 1.000000
> > } // end Sphere0
> Regards
>      Stephen
Thanks for all of the input. I.m going to treat each letter as an object. I'll
post the movie in the animation group along with my text scene file.
DigitalDad
Date: 10 May 2011 09:07:32
Message: <4dc93894$1@news.povray.org>
Am 09.04.2011 10:48, schrieb Stephen:
Speed and memory consumption.
Using a union for a single object will add unnecessary overhead, roughly
duplicating the memory required per letter; it also /will/ impact render
time, if ever so slightly.
