POV-Ray : Newsgroups : povray.newusers : Emissive media "shadow" problem - please help Server Time
28 Jul 2024 04:20:13 EDT (-0400)
  Emissive media "shadow" problem - please help (Message 1 to 8 of 8)
Subject: Emissive media "shadow" problem - please help
Date: 29 Nov 2010 17:55:00
Message: <web.4cf42ece6a873a78f5f7d8980@news.povray.org>
In developing my first POV-Ray scene I encountered a subtle artifact and I am
not sure how to get rid of it. I have a 100% transmissive cylinder containing
identically-transformed emissive media with a cylindrical distribution. When in
front of a dark reflective texture, the edges of the cylinder appear dark (a
little bit like a shadow, but obviously not a shadow). When in front of a
brighter or flatter texture, the edges of the cylinder do not appear darker than
the surroundings--the desired effect. This artifact seems a bit stronger when
the cylinder is partially embedded in the dark-textured object. This image shows
what I mean:
http://www.freeimagehosting.net/image.php?923dd7c03e.png
Could anyone suggest what causes this, and how I might get rid of it?
The following code reproduces this scene:
background { rgb 0 }
global_settings {
      max_trace_level 256 //just in case
//includes
#include "golds.inc"
//declare textures
#declare gold = texture
   T_Gold_1C
camera { location <2, 2, -7> look_at <0,0,0> }
light_source {<20, 40, 10>, rgb 1.5 media_interaction off shadowless }
plane { y,-3
        pigment { Blue }
        finish { ambient 0 diffuse .3}
box { <-1,-1,-1>, <1,1,1>
   texture {gold}
#declare med1 = media {
   emission 7
   intervals 1
   samples 10
   method 3
   density {
        cylindrical color_map {
         [0 rgb <0,0,0>]
         [1 rgb <1,0,0>]
#declare med1cont = cylinder {
         <0,1,0>, <0,-1,0>, 1
         pigment {rgbt 1}
merge {
   object { med1cont
      scale <.1,1.1,.1>
      translate <1,0,-1>
   object { med1cont
      scale <.1,1.1,.1>
      translate <0,0,-2>
   interior {
      media { med1
         scale <.1,1.1,.1>
         translate <1,0,-1>
      media { med1
         scale <.1,1.1,.1>
         translate <0,0,-2>
   hollow
   no_shadow
Subject: Re: Emissive media "shadow" problem - please help
Date: 29 Nov 2010 18:58:48
Message: <4cf43e38$1@news.povray.org>
Am 29.11.2010 23:53, schrieb KurtB:
> Hi,
> what I mean:
I don't see anything strange in that image. Are you sure it's not just a
subtle optical illusion, or a peculiarity of your display?
Date: 29 Nov 2010 21:35:22
Message: <4cf462ea$1@news.povray.org>
> Hi,
> what I mean:
Change your reflective box with:
    texture {pigment{Blue}finish{reflection 1 ambient 0 diffuse 0}}
Presto, you can no longer see where the front cylinder get in front of
the box.
The reason: your ground plane is pure blue -> NO red and no green.
The gold box contribure a good amount of red and green.
The red media add some red.
Result: on front of the blue parts the only red comes from the media,
while in front of the box, you have more red giving a brighter, less
saturated, shade.
I'd change your container as follow:
          pigment {rgbt 1}
interior{media {
    emission 7
    intervals 1
    samples 10
    method 3
    density {
          [0 rgb <0,0,0>]
          [1 rgb <1,0,0>]
Then:
union{
    object { med1cont
       scale <.1,1.1,.1>
       translate <1,0,-1>
    object { med1cont
       scale <.1,1.1,.1>
       translate <0,0,-2>
Put the media in the container defined around the Y axis.
Then, as you translate the object, it's media will get translated with it.
You don't need media_interaction off and shadowless in your light
source, as only the box can cast a shadow.
Also, the emissive media container already don't cast any shadow, so
no_shadow is not usefull.
Date: 3 Dec 2010 04:10:00
Message: <web.4cf8b33f65f17013f5f7d8980@news.povray.org>
Thank you both for your comments so far. I really appreciate your pointers,
Alain, but I must apologize as the example I posted was not very clear. I have
played around with this a bit more, and I discovered that the artifact becomes
more pronounced if I increase the quality settings for radiosity.
High quality radiosity: http://www.freeimagehosting.net/image.php?84dfca2887.png
Low quality radiosity: http://www.freeimagehosting.net/image.php?242bc9ec78.png
You can see the artifact where the green arrow points in the first image. It is
as if the "rgb 0" part of the emissive media is emitting black, but from all I
have read in the documentation that is not how POV-Ray is supposed to work. This
time, at least, I know it is not an optical illusion (you can zoom in and see it
quite clearly on the pixel scale) or a quirk of my display (I tried it on
another display, just to be sure).
What could cause this "shadow" to appear?
Here is the same scene as I originally posted, but with the two radiosity blocks
added and the density of the emissive media modified to highlight the
cylindrical "shadow". Low quality radiosity is "RADtest"; high quality is
"RADfinal". (This scene took a bit over an hour to render on my Intel E8400
using "RADfinal" and the "+a0.0 +am2 +r4" command-line options for
anti-aliasing.)
#declare RADfinal = off;
#declare RADtest = off;
  global_settings {
     #if(RADfinal)
       radiosity {
        pretrace_start 0.08
        pretrace_end   0.001
        count 1600
        nearest_count 20
        error_bound 0.05
        recursion_limit 20
        low_error_factor 0.5
        gray_threshold 0.0
        minimum_reuse 0.005
        brightness 2//3
        adc_bailout 1/255
        media on
        always_sample off
       ambient_light 0.5
      #if(RADtest)
       radiosity {
        pretrace_start 0.08
        pretrace_end   0.04
        count 100
        nearest_count 5
        error_bound 1
        recursion_limit 20
        low_error_factor 0.7
        gray_threshold 0.0
        minimum_reuse 0.01
        brightness 2//3
        adc_bailout 0.01
        media on
        always_sample off
       ambient_light 0.5
      max_trace_level 256
//includes
//declare textures
   T_Gold_1C
plane { y,-3
        pigment { rgb 0.5 }
   texture {gold}
   emission 7
   intervals 1
   samples 10
   method 3
   density {
         [0 rgb <0,0,0>]
         [0.8 rgb <1,0,0>]
         [1 rgb 1]
   density {
      function {sin((y+1)*pi*5)*sin((y+1)*pi*5)*0.8+0.2}
      color_map {
         [0 rgb 0]
         [0.5 rgb 1]
         [1 rgb 1]
         pigment {rgbt 1}
merge {
   object { med1cont
      scale <.1,1.1,.1>
      translate <1,0,-1>
   object { med1cont
      scale <.1,1.1,.1>
      translate <0,0,-2>
   interior {
      media { med1
         scale <.1,1.1,.1>
         translate <1,0,-1>
      media { med1
         scale <.1,1.1,.1>
         translate <0,0,-2>
   hollow
   no_shadow
Date: 3 Dec 2010 09:26:42
Message: <4cf8fe22$1@news.povray.org>
Am 03.12.2010 10:07, schrieb KurtB:
It still took me some time to recognize it, but yes, it's there: What at
first glance looks like the edge of the cube is indeed an artifact.
Unfortunately, all I can think of right now is: "My that's weird!"
My current favorite culprit would be a problem in the radiosity code
causing the media to illuminate only geometry outside its container. But
that's just a guess.
Date: 3 Dec 2010 22:03:00
Message: <4cf9af64@news.povray.org>
>> pointers,
>> clear. I have
>> becomes
Your guess seems to be comfirmed in my latest test. The dark line
disapears when you cut out the part of the cylinder that intersect the
box and you make sure there is a narrow gap between the container and
the box.
Date: 4 Dec 2010 01:24:37
Message: <4cf9dea5@news.povray.org>
Am 04.12.2010 04:02, schrieb Alain:
> the box.
Would you mind submitting a bug report on http://bugs.povray.org so this
issue doesn't get lost?
Date: 7 Dec 2010 01:05:07
Message: <web.4cfdcd6265f17013f5f7d8980@news.povray.org>
I have really enjoyed using POV-Ray so far and I am glad to see it is being
continually improved. Alain, your suggestion allowed me to remove the artifact
from my scene! Thank you both again for your help.
