POV-Ray : Newsgroups : povray.newusers : Semi-transparent photograph overlaid an image Server Time
11 Oct 2025 18:27:43 EDT (-0400)
  Semi-transparent photograph overlaid an image (Message 1 to 5 of 5)
Subject: Semi-transparent photograph overlaid an image
Date: 16 Sep 2010 20:35:01
Message: <web.4c92b6faac5cfc7634d207310@news.povray.org>
I was trying to overlay a semi-transparent PNG over my image. I came up with a
very inelegant solution for the textured box.  (I have the box and image
positioning down pat.)
Can anyone offer up a simple solution for texturing a semi-transparent box
overlaid on a scene, one that is relatively independent of the SDL lighting that
hits it?
thanks.
Subject: Re: Semi-transparent photograph overlaid an image
Date: 17 Sep 2010 02:37:27
Message: <4c930ca7@news.povray.org>
I'm not sure I understand well what you mean but to get your box independent
from scen lighting, finish{ambient 1 diffuse 0} is a good start :)
BTW did you try screen.inc ?
Marc
web.4c92b6faac5cfc7634d207310@news.povray.org...
>with a
> lighting that
> hits it?
> thanks.
Date: 17 Sep 2010 11:35:01
Message: <web.4c938a61a32ab61da00085090@news.povray.org>
Thanks, but I know how to get a PNG image in front of the camera, and I see this
as the main benefit of screen.inc.
What I want is to place semi-transparent image in front of the camera, such that
what I see is generally X% my PNG, 100-X% the regular camera.  I came up with a
very inelegant way to do this, but it was so clunky and sensitive to the room
lighting.
I am wondering what would be the way to **texture** a box so it is a
semi-transparent overlay on top of my scene.
> Marc
Date: 17 Sep 2010 15:41:15
Message: <4c93c45b$1@news.povray.org>
Am 17.09.2010 17:33, schrieb gregjohn:
> lighting.
     #declare P=0.6;
     plane { z, 0
       clipped_by { box { <0,0,-0.1>, <1,1,0.1> } }
         pigment { image_map { png "foo.png" once filter all 1-P } }
         #if (version < 3.7)
           finish { ambient 1 diffuse 0 specular 0 phong 0 }
         #else
           finish { ambient 0 emission 1 diffuse 0 specular 0 phong 0 }
       no_reflection
       no_shadow
       no_radiosity
       no_photons
       transform { ... }
This gives a neat semi-transparent square image stretching from <0,0,0>
to <1,1,0>, which isn't affected by scene lighting in any way, nor does
it affect the scene in any way - ready to be translated, scaled,
rotated, sheared or otherwise transformed to be positioned right in
front of the camera. P=0.0 gives you only the scene, P=1.0 gives you
only the image, P=0.5 gives you an 50%:50% blend.
Depending on what effect you're /really/ aiming for, you may want to use
yet some different voodoo though. For instance, you might actually want
to "add" the image rather than blend it with the scene. For that purpose
you could use something like:
   #declare P=0.6;
   #declare E=0.001;
     pigment { image_map { png "foo.png" once filter all 1-E } }
     #if (version < 3.7)
       finish { ambient P/E diffuse 0 specular 0 phong 0 }
     #else
       finish { ambient 0 emission P/E diffuse 0 specular 0 phong 0 }
Here, P=0.0 gives you the scene + 0% of the image, while P=1.0 gives you
the scene + 100% of the image. E is just a very small value (what
mathematicians would call "epsilon") that governs how well the whole
construction really matches an "add" operation - the smaller the better
(note that E=0.0 unfortunately doesn't work).
Date: 17 Sep 2010 16:25:01
Message: <web.4c93ce7ca32ab61da00085090@news.povray.org>
Thanks greatly. Will try out.
