POV-Ray : Newsgroups : povray.newusers : sound-/sine wave in povray Server Time
15 Dec 2025 17:34:01 EST (-0500)
  sound-/sine wave in povray (Message 1 to 7 of 7)
Subject: sound-/sine wave in povray
Date: 16 Sep 2010 15:00:00
Message: <web.4c9268b1d5cad8236731f09e0@news.povray.org>
So here's a thingie I can't solve, don't know enough math to figure this one out
(I presume my problem's math-related): I want to make a sine-wave in 3D, with a
look like a b_spline (as in: rounded edges, to give it a proper 3D-look), like
the representation of a sound wave in Audacity. Could anyone help me with this
please?
Subject: Re: sound-/sine wave in povray
Date: 16 Sep 2010 15:43:49
Message: <4c927375$1@news.povray.org>
I'm not sure how it looks in Audacity but you might try a sphere_sweep.
Date: 16 Sep 2010 17:24:43
Message: <4c928b1b$1@news.povray.org>
> please?
You can use a sphere_sweep. Sample the sin function at sufisently small
intervals.
It's also possible to use an isosurface.
Date: 16 Sep 2010 19:40:01
Message: <web.4c92aa22613bfb9ed939a6800@news.povray.org>
I recently bought a turntable with USB connection so I could put old vinyl
records onto CD and it comes with Audacity. To see anything like a sine wave I
must magnify the view to the extreme, otherwise mostly see chaotic waveforms not
simple sine waves from music. Guess that's beside the point.  ;)
Not sure sphere_sweep is going to be good for this since it requires a known
number of points. I could just be thinking wrong but stringing spheres together
might be easiest to work math in for variations on waveform.
Simple example here (because it's all I could do), not intended as THE solution:
/* sine or sound wave */
camera
 location <15, 0.5, -25>
 look_at <15,0.5,0>
#local T=25; // total time
#local I=0; // time count
#local S=0.1; // scale
#local A=3; // amplitude
#local F=0; // frequency
union
#while (I<T)
#local R=seed(I); // random
sphere
 <I+F,sin(I)*A,0>, S
#local I=I+S;
#local F=0;// sin(I); // math to reshape wave, like sin(I*R)
texture
 pigment
  function {abs(y)}
  color_map {
   [0 rgb <0,1,0>]
   [1 rgb <1,0,0>]
  scale 1+S // adjust to sphere size
 finish
  ambient 1
} // end union spheres
/* end sine or sound wave */
Date: 17 Sep 2010 05:45:01
Message: <web.4c933804613bfb9e6731f09e0@news.povray.org>
Thank you very much! That looks beautiful, I'll just try and modify this sample,
maybe change the coloring of the spheres, maybe try to create the look of a
single thread (and not a string of spheres), and perhaps if I could create some
"cartoony" randomness to the peaks of the wave forms, that would really look
great.
Oh, and your records must be in pretty bad shape if you can't see the sine wave
(or maybe I always zoom in very far with Audacity), enjoy anyway! Oh, and make
sure you record to 44k1Hz, and not 22050Hz, or if you burn it to CD it will come
out like the Smurfs (because the CDplayer will play back at 44k1 regardless)! (I
had that once, very funny, but not what I wanted at all)
Date: 17 Sep 2010 15:35:00
Message: <web.4c93c214613bfb9ed939a6800@news.povray.org>
Happy to help.
Christian and Alain are probably right about using sphere_sweep, I just have
trouble every time I try to automate the coordinates for those. I finally got it
right(?), see redone script below. Had seen Mike Raiford's post in off-topic,
Wavelet, so that got me thinking more about this.
Yep, that was the first thing I found out, using 44.1 not a higher (better?)
rate. That sounds fine to my ears. My records are in bad shape or well used, and
the randomized wave form of my script is about what I see when zoomed into the
Audacity graph.  ;)
/* example sound wave */
#local Sweep=yes;
camera
 look_at <15,0.5,0>
#if (Sweep=yes)
#local I=2; // time count
#local Ss=1; // scale
sphere_sweep
 b_spline
 T,
#while (I-2<T)
 <I+F,sin(I)*A,0>, S
#local I=I+Ss;
#local F=sin(I*R);//(sin(I/2)+cos(I/3)); //sin(I);
#else
union
#while (I<=T)
sphere
 <I+F,sin(I)*A,0>, S
#local I=I+S;
#local F=0; // sin(I); // math to reshape wave, like sin(I*R)
#end // if
texture
 pigment
  function {abs(y)}
  color_map {
   [0 rgb <0,1,0>]
   [1 rgb <1,0,0>]
  scale 1*A+S // adjust amplitude and sphere size
 finish
  ambient 1
Date: 17 Sep 2010 17:01:23
Message: <4c93d723$1@news.povray.org>
> great.
If you use a string of relatively short cylinders connected by spheres,
you can get something very reasonable.
The cylinders rid you of the beady aspect, and the spheres will fill up
the gaps between the cylinders.
