POV-Ray : Newsgroups : povray.newusers : Trying to put a simple image on a cylinder's surface Server Time
11 Oct 2025 18:23:51 EDT (-0400)
  Trying to put a simple image on a cylinder's surface (Message 1 to 3 of 3)
Subject: Trying to put a simple image on a cylinder's surface
Date: 1 Aug 2010 09:20:00
Message: <web.4c5573b0927177d058a2360d0@news.povray.org>
Haven't posted here in ages--please be gentle!
I'm trying to wrap a simple image onto the surface of a cylinder.  For various
reasons, I don't want to use image mapping and was hoping to do it with
intersecting solids.
The image is a sort of caution sign, an upright yellow triangle with a black
boarder and a black exclamation point inside.
I can create a flat version image very easily using a few triangle meshes and
disc objects, but I'm having trouble getting it to intersect with the cylider's
surface.
Does this make sense?  My gut feeling is that POV-Ray offers some dirt-simple
way to do this, but I have the impression that I'm missing something basic.
Any insight is appreciated!
Subject: Re: Trying to put a simple image on a cylinder's surface
Date: 1 Aug 2010 12:48:24
Message: <4c55a558$1@news.povray.org>
Am 01.08.2010 15:16, schrieb Dave!:
> surface.
No surprise you have trouble intersecting your sign with the cylinder
surface: You mention triangle meshes and disc objects; neither of these
have any depth, so you can't intersect them with anything.
You need to give the sign a third dimension: Use cylinders instead of
the disks, and linear_spline prisms instead of the triangle meshes. That
should get you started.
Note that if you want the sign to cover a big portion of the cylinder,
you may also run into problems with distortions. In that case, you might
need to use a set of object patterns and apply a cylindrical warp.
Date: 1 Aug 2010 17:55:00
Message: <web.4c55ecd89bf243fc58a2360d0@news.povray.org>
> > surface.
Well, I had *some* luck with inside_vector, but it caught both the front and
rear sides of the cylinder, so it was clear that I had more work to do there!
After posting, I had an idea about a union of several prisms and cylinders, and
this seems to be promising.  I'm having a bit of trouble getting it to break
exactly where I want it, but it feels like a more promising avenue than what I'd
been trying.
Good point--I wasn't clear about that.  If the cylinder is, say, 10 units in
diameter, the sign will probably be about six units across, so there shouldn't
be too much distortion.
Thanks for your input!
