POV-Ray : Newsgroups : povray.newusers : volume rendering from a text file containing positions in 3 dimensions Server Time
26 Mar 2026 13:04:19 EDT (-0400)
  volume rendering from a text file containing positions in 3 dimensions (Message 1 to 9 of 9)
Subject: volume rendering from a text file containing positions in 3 dimensions
Date: 12 Mar 2010 15:10:01
Message: <web.4b9a9f1d5498087ffdf151b0@news.povray.org>
dear users
i installed POV-Ray on a linux machine and it will be nice if somebody helps me
with the question below
i have a txt file containing spherical particle positions (x,y and z) and i want
to produce a 3 -dimensional image from this txt file
i just started using POV Ray today and i think we need to produce two files with
extension *.ini and *.pov from the text file of positions
thanks for the help
regards
anki
Subject: Re: volume rendering from a text file containing positions in 3 dimensions
Date: 12 Mar 2010 17:17:52
Message: <4b9abd90$1@news.povray.org>
Hi anki,
POV is quite specific in what it will read in. You really need the data
in CSV format:
x1,y1,z1,x2,y2,z2
To get a handle on the file, do this:
#fopen IDENTIFIER "filename" read
Then to read the next value(s) from a CSV, do this:
#read (IDENTIFIER, PosX, PosY, PosZ)
You now have the first 3 values in the variables PosX, PosY and PosZ
You'll also need to look at #while() to handle looping through the file
The POV file defines the scene and the INI file is used to provide
additional information (eg, How many frames to render in an animation,
what file type to output, etc...)
My default INI file is:
Initial_Frame=0	;Start at frame 0
Final_Frame=100	;End at frame 100
Initial_Clock=0	;The variable "clock" will change from 0
Final_Clock=1	;to 1 ovr the course of the animation
;Frame Subset: This is done so you can render a couple of frames from an
animation without altering the clock variable above
;Subset_Start_Frame = 100	;start at this frame
;Subset_End_Frame = 1439	;end at this frame
Input_File_Name=Scene.pov ;The POV file to render (usually in same
directory)
Output_to_File=on	;Write out to file after rendering?
Cyclic_Animation=on ;Offset the end of the animation slightly so that a
cyclic animation doesn't "jerk" as it loops through frame 0
Most of these have command line switches - See the help for more info
Hope that helps a bit
Date: 13 Mar 2010 11:56:59
Message: <4b9bc3db$1@news.povray.org>
> dear users
> thanks for the help
> regards
> anki
In your text file, are the values separated by comas or by spaces?
In the first case, a simple #while loop is all you need to read those
values.
If you don't know how many elements are in the file, you can use
#while(!eof <file>).... #end to read untill you reatch the end of the
text file. In that case, you read the first 3 values before you start
the loop, and you read the next 3 as the last instruction of the loop,
just before the #end.
In the second case, it's beter to do a search and replace to replace the
spaces by comas.
The text file is not used to generate the *.ini nor the *.pov file. The
*.pov file will use the *.txt file as a data source.
The *.pov file is the one actualy describing the scene: camera location
and caracteristics, light(s) location(s) intensity and colours, what
objects to place at each locations with what texture,... In the *.pov
file, you will read your data and construct the scene from that.
The *.ini file is optional. You can render the *.pov file directly from
the command line:
<path>pvengine.exe file.pov
You can add the image's dimentions the same way, just add +w1025 +h768
to get a 1024 by 768 pixels image.
The *.ini file is mostly usefull when you need to enter several
arguments and it becomes unweldy to always write them on the command
line. It's also very usefull when doing animations as Simon proposed
with his sample.
You can have a *test.ini to do the test renders, then a *.ini or
*final.ini file to render the final image. Both versions refers to the
same *.pov file.
The test version will have smaler resolution and lower, or no, aa,
possibly lower quality setting, less animation frames,...
The final version will use full quality, good aa, larger resolution, all
the animation's frames,...
Date: 17 Mar 2010 12:45:01
Message: <web.4ba10674d4b839cffdf151b0@news.povray.org>
Hi  Alain and Simon
Thanks a lot for your reply, atleast some things are clear now
actually my text file looks like below
1st column is sphere number
2nd column is x-position, 3rd- y position and 4th- z -position
there are 4000 particles in a box
1 487.726807 383.565125 99.485672
2 377.206238 393.352325 17.296064
3 452.328613 346.985321 33.054535
4 453.301697 334.173981 14.480576
5 724.187988 389.938171 55.237068
6 298.778717 388.706055 30.780521
7 685.588074 366.411072 31.322350
4000 56.78   456.67   234.56
i can make the text file , where columns are separated by commas like
x1,y1,z1
x2,y2,z2
x3,y3,z3
still i have a doubt about the format to use in *.pov file to read this text
file
is it like to put the commands as
"#fopen identifier 'pos.txt' read
while loop
end"    in a file named sphere.pov and use ./povray sphere.pov to produce
rendering image ?
could you please suggest me a sample *.pov file which reads a text file
containing the positions of particles like i have
thank you very much
regards
anki
Alain <aze### [at] qwertyorg> wrote:
> > dear users
> > thanks for the help
> > regards
> > anki
> values.
> spaces by comas.
> the command line:
> with his sample.
> same *.pov file.
> Alain
Date: 17 Mar 2010 16:00:12
Message: <4ba134cc$1@news.povray.org>
Here is some sample code which should get you started.
Note that the file format needs to have a comma at the end
of the line as well!
// You mentioned you know the number of points, otherwise do two passes.
#declare NUM = 4000;
// Open data file
#fopen DATA_FILE "pos.txt" read
// Read data
#declare POS_X    = array[NUM]; // Create and initialize arrays
#declare POS_Y    = array[NUM];
#declare POS_Z    = array[NUM];
#declare POS_X[0] = 0.0;
#declare POS_Y[0] = 0.0;
#declare POS_Z[0] = 0.0;
#declare INDEX = 0;
#while (defined(DATA_FILE) & INDEX < NUM)
   #read(DATA_FILE,POS_X[INDEX],POS_Y[INDEX],POS_Z[INDEX])
   #declare INDEX = INDEX+1;
#declare NUM = INDEX; // Fewer than expected is ok
#fclose DATA_FILE
// Use data
union
   #declare INDEX = 0;
   #while (INDEX < NUM)
     sphere {<POS_X[INDEX],POS_Y[INDEX],POS_Z[INDEX]>, 1}
   pigment {color rgb 1}
Date: 17 Mar 2010 19:17:02
Message: <4ba162ee$1@news.povray.org>
> Hi  Alain and Simon
> x1,y1,z1
> x2,y2,z2
> x3,y3,z3
> file
> while loop
> rendering image ?
> thank you very much
> regards
> anki
Put a coma after each values.
Sample file:
#declare Cluster = union{
  #read(DATA_FILE, PosX, PosY, PosZ)
   #while (defined(DATA_FILE))
  	sphere{<PosX, PosY, PosZ>, Radius}
   #fclose DATA_FILE
   pigment{rgb 1}
It opens your input file and read the first 3 values.
It then start a loop.
The loop place a single sphere, then it reads the next 3 values.
It will continue to loop until you reatch the end of your file. At that
moment, DATA_FILE becomes undefined and the loop falls through.
The #fclose DATA_FILE is not realy needed as the file is automaticaly
closed, and it's identifier suppressed, after you tried to read past
it's end.
After the end of the loop, a texture is applied to the union and the
union is closed.
I used a #declare. It allows you to use your cluster of spheres several
times with no need to read your data a second time.
This construction allows you to read any file of any length with no need
to know how many elements are contained in it.
You don't need any array.
You can use any object as your shape, you are not limited to use spheres.
Date: 22 Mar 2010 11:20:01
Message: <web.4ba78a8ad4b839c79d090110@news.povray.org>
Dear Alain and Christian
Thank you very much for your response and giving me suggestions to read the text
file.
I am able to produce the image, but still i have got some issues
I use camera location and look_at and light_source with these positions given
below.
Actually i used different positions for them to get a nice 3-dimensional image,
but i think i am not using optimal values
the set of particles positions i have, x-position ranges from 0.0 to 40.0;
y-position ranges from 0.0-20.0 and z-position ranges from 0-10.0
that means x-dimension is of 40 particle diameter length; y-dimension is of
20-particle diameter length and z-dimension is of 10-particle diameter length
particle diameter is 1.0
could you please suggest me the best way to put the light source and camera
position
background { color Cyan}
    location <0, 5, -3>
    look_at  <24, 9, 2>
light_source { <10, 5, -3> color White}
thanking you
anki
> > Hi  Alain and Simon
> > x1,y1,z1
> > x2,y2,z2
> > x3,y3,z3
> > file
> > while loop
> > rendering image ?
> > thank you very much
> > regards
> > anki
> Sample file:
>    #end
>    #fclose DATA_FILE
>    pigment{rgb 1}
> it's end.
> union is closed.
> Alain
Date: 22 Mar 2010 19:16:45
Message: <4ba7fa5d$1@news.povray.org>
> position
there is no general answer to this ... how should the image look
like? I'd probably start by translating the particles by <-20,-10,0>
and placing the camera at <0,0,-10> with look_at <0,0,0>. Then the
objects are centered and the initial setup is easy to understand.
Next, change the distance of the camera and play with the angle
keyword to get the desired zoom. The light should probably be
much further away from the origin, try an initial value of
<-100,80,-60> or so. Finally, move the camera to the side
or rotate the geometry to get the desired perspective.
Date: 22 Mar 2010 19:29:32
Message: <4ba7fd5c$1@news.povray.org>
> file.
> below.
> position
> camera {
>      location<0, 5, -3>
>      look_at<24, 9, 2>
> light_source {<10, 5, -3>  color White}
> thanking you
> anki
> lain<aze### [at] qwertyorg>  wrote:
>>> Hi  Alain and Simon
>>> x1,y1,z1
>>> x2,y2,z2
>>> x3,y3,z3
>>> file
>>> while loop
>>> rendering image ?
>>> thank you very much
>>> regards
>>> anki
>> Sample file:
>>     #end
>>     #fclose DATA_FILE
>>     pigment{rgb 1}
>> it's end.
>> union is closed.
>> Alain
With no access to your data, it's dificult to juge, but I'll try using a
set of 4000 randomly placed spheres.
You can try moving the camera around until you find a spot from where
you get an interesting view.
Maybe moving the light to a somewhat larger distance from your spheres.
I think that it may be to close, but it may need to be that close.
Some times, adding a second light can help.
Adding some highlight can add a lot but may not be interesting/advisable
in your case. Try it to see.
You may try using smaler spheres, presently, there is a lot of overlaping.
