POV-Ray : Newsgroups : povray.newusers : Need help on lighting and glass materials please Server Time
28 Sep 2024 16:19:28 EDT (-0400)
  Need help on lighting and glass materials please (Message 1 to 7 of 7)
Subject: Need help on lighting and glass materials please
Date: 8 Sep 2009 08:40:00
Message: <web.4aa64f7175ff90ec9dacbac0@news.povray.org>
Hi all,
I'm new to Povray and have learned most of the basics so far to achieve what I
want. However I am trying to create an image with some glass objects and can't
quite get the lighting and vibrancy how I want it.
This is an image here:- http://www.flickr.com/photos/40381418@N02/3717188064/
on Flickr. Can anyone show how this image was made, especially the lighting and
the glass material and how it's so vivid and vibrant please.
Any help/pointer would be greatly appreciated.
thanks
Tizer001
Subject: Re: Need help on lighting and glass materials please
Date: 8 Sep 2009 09:48:43
Message: <4aa660bb@news.povray.org>
I'm not sure how to do the same lighting in POV-Ray, but as for vibrant
colors, be bold: Set some color components to /negative/ values!
Caveat: In POV-Ray, this messes up photons and caustics computations.
Date: 8 Sep 2009 12:56:33
Message: <4aa68cc1$1@news.povray.org>
> Hi all,
> thanks
> Tizer001
Any glass object need some additional parameters:
  - An interior block that contains an ior
  - That interior block can also include a fade_color, fade_distance and
fade_power to set the colour of the substance composing the object.
  - To increase realism, add some dispersion. This increase the
rendering time.
With no ior, light won't bend, resulting in an object looking somewhat
like a bubble.
Sample interior block:
interior{ior 1.5 // typical class
	dispersion 1.03 // should be kept low and > 1 to be realistic
	fade_dolor rgb<0.7, 0.75, 0.9>// a bluish glass
	fade_distance 10 // relatively small effect. Adjust for the size of
your object.
	fade_power 1 // or 1001 to use "exponential" fading
The finish should include a variable reflection block with the fresnel
option. Don't forget to add conserve_energy to the finish.
Sample complete finish:
finish{ambient 0 diffuse 0.1 // don't interact much directly with the light
  specular 0.7 roughness 0.0001 // get relatively tight highlights
  reflection{0.1 0.95 fresnel} // prety normal for glass
  conserve_energy}
The highlights realy add a lot. They help give perceptual volume to the
objects.
To get realistic caustics, you need to add a photons{} block to the
global_settings AND another photons block to your glass object.
Sample minimal global photons block:
photons{count 1000000}// set how many photons you want to shoot
photons{spacing 0.01} // set the density at whitch you want the photons shot
Glass object typical photons block:
photons{ target // enable shooting photons at this object
  refraction on // turn photons refraction on
  reflection on // turn photons reflection on
  collect off // save time. Photons don't show much on transparent
objects anyway.
Your light_source don't need a photons block. It have the folowing
DEFAULT one:
photons{refraction on reflection on}
A lone glass object is rather boring. It needs some environment to realy
show. Even if you don't see them, a sky_sphere or some ther objects can
help.
Date: 8 Sep 2009 13:55:00
Message: <web.4aa6999af02dae4686ff1d480@news.povray.org>
"tizer001" <tiz### [at] hotmailcom> wrote:
> Hi all,
> thanks
> Tizer001
In addition to photons and whatnot (as Alain said in his post) try using filter
in the pigment block to make the color more vibrant, e.g.:
sphere { 0, 1
   pigment { Red transmit 0.25 filter 0.75 }
   finish {
      diffuse 0.1
      reflection { 0.1, 0.8 fresnel on } conserve_energy
      specular 0.5
      roughness 0.01
   interior { ior 1.5 }
Date: 8 Sep 2009 15:00:01
Message: <web.4aa6a8e0f02dae462b982c670@news.povray.org>
> Hi all,
> thanks
> Tizer001
What version of POV-ray are you using?  If you are using the most recent beta,
you may want to temporarily turn off gamma correction and see if that is closer
to what you were looking for.
Add the code #version 3.6; to the top of your scene and remove the assumed_gamma
from the global settings block (if it is there) to turn it off.
-Reactor
Date: 9 Sep 2009 08:32:43
Message: <4aa7a06b$1@news.povray.org>
web.4aa64f7175ff90ec9dacbac0@news.povray.org...
> Hi all,
> lighting and
I took as a challenge to try and get as close as I could to the image.
The main issue is the ior for which I couldn't find a good value for both
refraction and caustics width
Marc
Here is the code :
#version 3.6
#declare Photons=1;
global_settings {
  max_trace_level 11
  #if (Photons)          // global photon block
    photons {
      spacing 0.02                 // specify the density of photons
  location  <-5,3,-5>
  look_at   <0,0.0,0>
light_source {
  <-500,400,200>*.2
  color rgb 1.0
  photons {
    refraction on
    reflection on
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb 1.3]
      [0.7 rgb <0.8,0.8,0.8>]
plane {
  y, 0
    pigment { color rgb 1 }
    finish {ambient 0 diffuse .6 brilliance 0
    reflection {
        .5
    //  conserve_energy
#macro M_Glass(Cnt_spheres)
material {
  texture {pigment {color Fadecolors[Cnt_spheres] transmit .7 filter .3}
    finish {
      ambient 0.0
      diffuse 0.0
      specular 1
      roughness 0.005
      reflection {
        0.3, 1
       // fresnel on
        falloff 3
      conserve_energy
  interior {fade_color Fadecolors[Cnt_spheres]
    ior 1.5
  #if(Photons=0)
    caustics .2
      fade_power 1001
      fade_distance .8
#declare
Fadecolors=array[7]{<1,0,0>,<1,0.5,0>,<1,1,0>,<0,1,0>,<0,0.5,1>,<0,0,1>,<.8,0,.8>};
#declare Rayon=.5;
#declare Nb_spheres=7;
#declare Depart=(Nb_spheres/2)*-Rayon;
#declare Cnt_spheres=0;
#while (Cnt_spheres<Nb_spheres)
        sphere {
                y*Rayon, Rayon
                translate x*(Depart+(Rayon*2*Cnt_spheres))
                photons {  // photon block for an object
                        target 1.0
                        refraction on
                        reflection on
                hollow
         #declare Cnt_spheres=Cnt_spheres+1;
Date: 16 Sep 2009 16:00:01
Message: <web.4ab14316f02dae46a82a02bf0@news.povray.org>
> Marc
> Here is the code :
brilliant, marc. a real inspiration to newbies. thanks
steve
