POV-Ray : Newsgroups : povray.newusers : The Trouble of rendering Crystal letters Server Time
12 Oct 2025 04:05:02 EDT (-0400)
  The Trouble of rendering Crystal letters (Message 1 to 7 of 7)
Subject: The Trouble of rendering Crystal letters
Date: 23 Apr 2009 17:05:01
Message: <web.49f0d6c06d439aa84a5e8270@news.povray.org>
This is my first post in this newsgroup, although
i have been reading all messages for some time
and have learn a lot about Pov-Ray.
Please take a look at this file:
http://aulasdigitales.net/universidad_isa_crystal.zip
This compressed file contains a small render and
a Pov-Ray scene.
In fact, this my Nth version of this scene, but after so
many trials, i am still unable to produce a lighting
effect that shows clearly the crystal letters over a
white (or light colored) background.
Every advice (and a small render that shows the results)
is more than welcome.
Thanks in advance.
alejandro
Subject: Re: The Trouble of rendering Crystal letters
Date: 23 Apr 2009 18:42:24
Message: <49f0eed0@news.povray.org>
As a first improvement, increasing max_trace_level will help.
Try this:
global_settings { ambient_light color rgb <1, 1, 1> max_trace_level 50}
Unfortunately, it will take a lot longer to render ;)
Also, I think your U and N overlaps.
Note that there is also a "text" primitive in POV-Ray.
Date: 23 Apr 2009 21:15:01
Message: <web.49f1118dccd2c9e44a5e8270@news.povray.org>
> Try this:
Yes, this made brighter the crystal letters!
Now i changed the plane texture to Glass, and
finally can see a clear background, but just
as expected, there is no reflection in the
glass letters, so they are barely visible.
Tomorrow, will keep experimenting with other
glass textures and their parameters.
i received this pov file from a friend, it's exported from Rhino 3D.
When i contact him, i will ask how to fix this.
Christian, many thanks again for your guidance!
alejandro
Date: 23 Apr 2009 23:39:53
Message: <49f13489$1@news.povray.org>
capellan nous illumina en ce 2009-04-23 16:59 -->
> Hi,
> a Pov-Ray scene.
> Thanks in advance.
> alejandro
The light_source definition is not complete and it's located inside your text.
As it is now, it's located at 1,1,1 and don't have an intensity. After the
<1,1,1>, add "rgb 1" so that it will light up the scene. Now, you only have
ambient lighting and the bakground to make your letets show.
Each leter is given it'sown material, each defined for that leter. It would be
beter to put them in an union and apply one material to the union as a whole.
You could use the text primitive, at leadt for the "Universidad" word. It can
create a object from almost any text using any available font. Sample:
text{ttf"times.ttf""Universidad",0.5,0 scale 10
material { //taken from your scene
         pigment { color Col_Glass_Clear }
         finish { F_Glass6 }
       interior {
         I_Glass_Exp(2)
         fade_color color Col_Glass_Clear
dispersion 1.1 // added for completeness
     }    //added for the example
photons{target refraction on reflection on collect off}
The photons block don't have any effect unless you add a photons block in the
global_settings.
Keep your eyes wide open before marriage, half shut afterwards.
Benjamin Franklin
Date: 23 Apr 2009 23:45:00
Message: <web.49f13593ccd2c9e4f50167bc0@news.povray.org>
I think that is probably because there is nothing much in the scene *to*
reflect, except for the black background or sky_sphere.
Try adding a colorful sky_sphere, or some other colorful objects above the
lettering; the lettering should reflect very nicely as a result.
Ken W.
Date: 11 Nov 2009 11:10:01
Message: <web.4afae102ccd2c9e4f46691e50@news.povray.org>
> Hi,
> http://www.chromeautoemblems.com/index.php/cPath/20
> a Pov-Ray scene.
> Thanks in advance.
> alejandro
Message: <web.4afae141ccd2c9e4f46691e50@news.povray.org>
> Hi,
> a Pov-Ray scene.
> Thanks in advance.
> alejandro
