POV-Ray : Newsgroups : povray.newusers : Conversion of coordinates to heightfield Server Time
28 Sep 2024 18:12:34 EDT (-0400)
  Conversion of coordinates to heightfield (Message 1 to 7 of 7)
Subject: Conversion of coordinates to heightfield
Date: 29 Jan 2009 01:40:00
Message: <web.49814ed57858db39eb381d30@news.povray.org>
Hello,
I would like to convert x,y,z-coordinates to either a heightfield a mesh or a
solid object.
The coordinates come in a format like this, with or without brackets:
{20,11.6751,0.071}
{20,11.6408,0.07}
{20,11.6066,0.0698}
{21,11.5724,0.0709}
{21,11.5382,0.0704}
{21,11.5039,0.0709}
{22,11.4697,0.0711}
{22,11.4355,0.0713}
{22,11.4012,0.0712}
(its NMR-cryoporometry data, for those interested ...)
I tried RapidDXF, 3DWin and several other programs without success.
Any suggestions ?
thanks
 Andreas
Subject: Re: Conversion of coordinates to heightfield
Date: 29 Jan 2009 05:08:35
Message: <49818023$1@news.povray.org>
"Grobi" <and### [at] boesmanncom> wrote in message
news:web.49814ed57858db39eb381d30@news.povray.org...
> Hello,
> or a
> solid object.
> {20,11.6751,0.071}
> {20,11.6408,0.07}
> {20,11.6066,0.0698}
> {21,11.5724,0.0709}
> {21,11.5382,0.0704}
> {21,11.5039,0.0709}
> {22,11.4697,0.0711}
> {22,11.4355,0.0713}
> {22,11.4012,0.0712}
> Any suggestions ?
> thanks
> Andreas
There are lots of alternative possibilities, so it largely depends on how
you need to represent the data. This small data sample shows a step-wise
increasing first value and a steadily decreasing second value, with the
third, presumably being the measured value corresponding to the first two
settings? I was sort of expecting some sort of regular grid-like scan, which
could be then plotted as a 3D graph?
It's pretty easy to get such data into a POV-Ray array, you just need to
replace the first bracket with a left chevron '<' the second with a right
chevron and a comma '>,' and top and tail it with an array declaration, as
in the example below.
Even for a very large file you should be able to do this in seconds using a
global replace function in a text editor (e.g. POV-Ray's integrated editor
on Windows). You'll need to get an accurate line count to be able to specify
the array size.
Then you can use it to create more or less any objects, colors etc. you
require. The very simple example below illustrates how you can loop through
the data using it to position and color some cylinders. It repositions and
scales the values to bring them close to the origin and into a similar order
of magnitude. It then uses the values as x,y,z coordinates to position
cylinders and also as RGB values to color them.
Chris B.
camera {location <-1,3,-3> look_at <0.5,2,0> }
light_source {<-10,20,-50>, rgb 1}
#declare Data = array [9] {
<20,11.6751,0.071>,
<20,11.6408,0.07>,
<20,11.6066,0.0698>,
<21,11.5724,0.0709>,
<21,11.5382,0.0704>,
<21,11.5039,0.0709>,
<22,11.4697,0.0711>,
<22,11.4355,0.0713>,
<22,11.4012,0.0712>,
#local I=0;
#while (I<9)
  #declare OneValue = (Data[I]-<20,11.4,0.069>)*<1,10,1000>;
  cylinder {OneValue,OneValue+z,0.1 pigment {rgb OneValue/10}}
  #local I=I+1;
plane {-z,-3 pigment {rgb <1,1,0>}}
Date: 29 Jan 2009 17:55:31
Message: <498233e3@news.povray.org>
Grobi nous illumina en ce 2009-01-29 01:38 -->
> Hello,
> solid object.
> {20,11.6751,0.071}
> {20,11.6408,0.07}
> {20,11.6066,0.0698}
> {21,11.5724,0.0709}
> {21,11.5382,0.0704}
> {21,11.5039,0.0709}
> {22,11.4697,0.0711}
> {22,11.4355,0.0713}
> {22,11.4012,0.0712}
> Any suggestions ?
> thanks
>  Andreas
To use it with POV-Ray, you need to replace the "{" with "<" and the "}" with ">".
Once it's done, it can be made into a mesh object.
Database administrators do it with their relations
Date: 30 Jan 2009 04:00:00
Message: <web.4982c17ba614deff9eb381d30@news.povray.org>
Hi there,
thanks for your answers.
I have something like 50-100 thousand coordinates, only the x-value is
incremented in a regular fashion, y and z are a bit random.
I currently have a sphere at every coordinate, which looks nice and is the
closest to the actual measument.
But how exactly do i convert those coordinates to a mesh (triangles)?
thanks
 Andreas
Date: 30 Jan 2009 06:08:21
Message: <4982dfa5$1@news.povray.org>
news:web.4982c17ba614deff9eb381d30@news.povray.org...
> Hi there,
> thanks
> Andreas
You could do that by generating a mesh or a mesh2 object. The mesh2 object
would probably be a little easier, because the syntax allows you to specify
a list of vertex_vectors in the same basic format as for the array of
coordinates. You would then need to specify a list of face_indices, which is
like specifying how to join the dots using triangular faces.
This is where it starts to get tricky.  If the points followed a sort of 2D
grid pattern then it's pretty easy to work out a way to join up the dots and
get a continuous surface where the vertices are at the height given by the
3rd dimension of your coordinates. Indeed I think that there are various
macros about that would be able to help you do that for well-defined grid
patterns.
However, if it is only the x-value that is incremental (and that goes up in
fairly chunky steps), then working out a meaningful way to join the dots
becomes quite awkward.  One approach would be to take all the <y,z> values
for a particular value of x and sort them on their y value. It would be
possible then to run along the first set of points using a triangle to
connect each point to the next and back to the y-axis. You could process the
second set connecting them back to the nearest vertex on the first set etc.
I suspect this would be quite challenging though, particularly if you're new
to POV-Ray and/or programming in general.
Plan B.
A simpler alternative that sidesteps these problems entirely is to consider
using prism objects instead of meshes. It's a bit of a cheat, but with this
number of points it could give you something that looks fairly similar. This
idea is to basically draw a series of pyramids with their apexes at the
required coordinates. It may therefore trick the viewer, giving the illusion
of forming a coherent mesh-like surface.
The example below uses the original 9 points you posted, but transposes the
y and z coordinates because the section of the prism object needs to be
defined in the x-z plane.
If this doesn't give you what you want, it may be worth posting the image
you made using spheres onto povray.binaries.images. This should at least
give an impression of the sort of point distribution you're working with,
which may inspire other ideas. You might also wish to provide a URL to an
image on the Internet that shows the sort of representation you'd like to
achieve.
Chris B.
camera {location <-1,1,-1> look_at <1,0.5,1> }
light_source {<-10,20,-50>, rgb 2}
<20,11.6751,0.071>,
<20,11.6408,0.07>,
#declare MyPrism = prism {
  linear_spline conic_sweep
  -1, 0, 5,
  <-0.8, -0.8>,
  <+0.8, -0.8>,
  <+0.8, +0.8>,
  <-0.8, +0.8>,
  <-0.8, -0.8>
  translate y
#local I=0;
#while (I<9)
//  cylinder {OneValue,OneValue+z,0.1 pigment {rgb OneValue/10}}
  object {
    MyPrism
    translate <OneValue.x,0,OneValue.y>
    scale <1,OneValue.z/5,1>
  #local I=I+1;
plane {y,0 pigment {rgb <1,1,0>}}
Date: 30 Jan 2009 12:00:00
Message: <web.498330fca614deffbdc576310@news.povray.org>
If the density of points is quite uniform despite all randomness, using blobs
instead of spheres might give good results, too, I'd guess.
Date: 3 Feb 2009 03:11:12
Message: <4987fc20$1@news.povray.org>
Grobi wrote:
> Hello,
> solid object.
> {20,11.6751,0.071}
> {20,11.6408,0.07}
> {20,11.6066,0.0698}
> {21,11.5724,0.0709}
> {21,11.5382,0.0704}
> {21,11.5039,0.0709}
> {22,11.4697,0.0711}
> {22,11.4355,0.0713}
> {22,11.4012,0.0712}
> Any suggestions ?
> thanks
>  Andreas
An other option could be to write a Perl script which convert the data
to a mesh or what ever you want.
regards,
Reinhard
