"Phil" <nomail@nomail> wrote:
> #define norm = <0,0,0>;
// Should that be:
#declare norm = <0,0,0>;
> #while (IN A REGION WE WANT TO PLANT)
> #declare h = trace(map, <x,y,2>, <x,y,0>, norm);
> #if ((vlength(norm) != 0) & (vlength(h) < 0.5))
> object {
> tree
> translate h
> #end
// And then be sure to reset the norm back to
// zero at before the next time you use it:
> #end
> > #end
I don't think that's necessary (I've never found it to be.) norm just needs to
be 'created' once--as kind of an empty placeholder for the normal vector(s) that
will be found by tracing. (It can be set up with *any* three values, actually.)
Then each time trace traces the object, norm will be filled with a REAL normal
vector. No need to 'empty it out' each time.
Ken W.
Kenneth napsal(a):
>>> #end
What if the trace misses the object?
The returned normal vector will be zero.
> - Warp
.......and your traced-on object will be placed at <0,0,0> by default. Without
some kind of 'escape' mechanism, you might end up with *lots* of objects there.
The standard way to keep that from happening is to do this before actually
making or calling an object:
#if(vlength(norm) != 0) // that's "not equal to zero"
object{my_object translate <...the traced location...>}
#else
// DON'T make an object
If the trace 'ray' goes off your height_field (or whatever), norm will be
<0,0,0> -- and vlength of that will be zero. Very handy!
KW
Kenneth nous illumina en ce 2008-10-15 00:35 -->
>> - Warp
> #else
> #end
> KW
> I prefer to simply use:
#if(vlength(Norm))
Any non-zero value evaluate as true.
No need for the empty #else.
To the world you may be one person, but to one person you may be the world.
> #if(vlength(Norm))
> #end
I find that slightly less readable; making the not-equal-zero explicit
makes it clearer what you are trying to do.
If I wrote code like that on the job, my boss would be unhappy. ;-)
I concur there.
William Tracy
afi### [at] gmail com -- wtr### [at] calpoly edu
segfault_message = g_strdup(
"Hi, user. We need to talk.\n"
"I think something's gone wrong here. It's probably my fault.\n"
"No, really, it's not you... it's me... no no no, I think we get
along well\n"
"it's just that.... well, I want to see other people. I... what?!?
NO! I \n"
"haven't been cheating on you!! How many times do you want me to
tell you?! And\n"
"for the last time, it's just a rash!\n"
-- from the Pidgin source code
William Tracy nous illumina en ce 2008-10-19 13:28 -->
>> #if(vlength(Norm))
>> #end
> I concur there.
When I had some programming courses, the teachers always told us that it was
VERY BAD practice to test for a negated comparaison.
To write "if(x != 0)" or "if(x <> 0)", depending on the language used, was a
sure way of failing. Instead, it was MANDATORY to use "if(x)". (x!>y) had to be
replaces by (x<=y) whenever possible to. And (x !>= y) was an heresy!
After any salary raise, you will have less money at the end of the month than
you did before.
William Tracy <wtr### [at] calpoly edu> wrote:
> I concur there.
Me too--and less typing. :-)
I didn't want to confuse new users, though; I think that learning and using the
full syntax first gives newbies the confidence and experience to 'optimize'
their code later. It did for me. (Many times, in complex scenes, I still leave
complete syntax in, so that I don't have to hunt around for code snippets that
I've forgotten to add.)
KW
Interesting!
The only programming courses I've ever taken were back in the 'pre-history' days
of computing--writing Fortran IV on punched cards! (Which *really* dates me,
eh?) I could very well have been taught the same do's and don'ts--but I've
sadly forgotten.
But back to POV: If I had written the POV 'escape' code like this...
#if(vlength(norm) = 0)
// don't make an object
#else
object{my_object translate <...the traced-on location...>}
....it somehow doesn't 'look' right to me--sort of like telling POV NOT to make
any objects 'unless...'
An interesting little psychological difference. :-)
KW
