POV-Ray : Newsgroups : povray.newusers : Making first animation Server Time
19 Nov 2025 05:31:54 EST (-0500)
  Making first animation (Message 1 to 3 of 3)
Subject: Making first animation
Date: 12 Jun 2008 09:10:00
Message: <web.48511fe4df878755758217b80@news.povray.org>
Hi. I am new to POV-Ray. I am trying to make my first animation. I have looked
up documentation and have gone throught the help topics. I just cant seem to
get it to work. I am using MLCad to render legos. I can render 1 image. But I
cant figure out how to create/edit ini files or command line instructions. Is
there a pecial place I need to keep these files? Where in the pov file do i
need to add time code and such. How do I edit it. Is there a place where I can
find all this information in one place? I know once I get the first animation
done that I'll be on my way. I justwould atleast like to see it produce
multiple renderings. Then I will need to know how to rotate or move something
over time in my animation. Any help will be greatly appreciated.
Thanks
Subject: Re: Making first animation
Date: 12 Jun 2008 09:24:41
Message: <dp82541k6ummlr56rfq5nr6gb2ud1u08c7@4ax.com>
>Thanks
Hi and welcome,
Firstly what OS are you using and have you read the help files 2.3.8.1
The Clock Variable: Key To It All.
The INI file is usually kept in same folder as the Pov file. You can
read about it here 1.2.5.2  INI Files
It would be a good idea to look at the examples that come with
Pov-Ray. Try Bong.
There is also a newsgroup especially for animations povray.animations
Regards
Date: 14 Jun 2008 13:39:24
Message: <4854024c$1@news.povray.org>
hager4 nous illumina en ce 2008-06-12 09:08 -->
> Thanks
If you are using the windows version, there is a "command line" box just next to
the resolutions drop-list. Just add "+kffn" where "n" is the number of frames
that you want. If you want a looped animation, you should add "+kc" in the same
location.
Both can also be placed in an ini file.
If you have an ini file associated with your scene file, it should reside in the
same folder, and have the same name exept for the extention: Myscene.pov and
Myscene.ini.
I hope our wisdom will grow with our power, and teach us, that the less we
use our power the greater it will be.
Thomas Jefferson
