POV-Ray : Newsgroups : povray.newusers : halo command error Server Time
8 Apr 2026 12:06:01 EDT (-0400)
  halo command error (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: halo command error
Date: 15 May 2008 12:56:31
Message: <482c6b3f$1@news.povray.org>
james lake nous illumina en ce 2008-05-14 19:41 -->
> "Tim Attwood" <tim### [at] comcastnet> wrote:
>> // A thin blue media, becoming lighter as it approaches
>> // the planet's surface.
>> #declare PlanetAtmosphere = sphere { <0,0,0>, 1
>>    hollow
>>    material {
>>       texture {
>>          pigment { rgbt <1,1,1,1> }
>>       interior {
>>          media {
>>             emission <0,0,2>
>>             density {
>>                spherical
>>                color_map {
>>                   [0 rgb 0]
>>                   [0.05 rgb 1]
>>                   [1 rgb 1]
>>          media {
>>             emission <2,2,0>
>>             density {
>>                spherical
>>                color_map {
>>                   [0 rgb 0]
>>                   [0.05 rgb 0.25]
>>                   [1 rgb 1]
>>    scale 1.05
> I tried this and it works, but now the Earth is a solid white sphere.  Is there
> another command that must accompany these?  Or should I change the settings?
> Thanks for the help!
> James Lake
You put that object around your earth, scaled 5% larger than the size of the
earth sphere.
You know you've been raytracing too long when you've ever "lost" a Julia fractal
because you're not quite sure how to align things in four dimensions.
Dylan Beattie
Date: 15 May 2008 22:25:00
Message: <web.482cef5ffa7c99c2d4dec990@news.povray.org>
> >>    hollow
> >>    material {
> >>       texture {
> >>       interior {
> >>          media {
> >>             emission <0,0,2>
> >>             density {
> >>                spherical
> >>                color_map {
> >>                   [0 rgb 0]
> >>                   [0.05 rgb 1]
> >>                   [1 rgb 1]
> >>          media {
> >>             emission <2,2,0>
> >>             density {
> >>                spherical
> >>                color_map {
> >>                   [0 rgb 0]
> >>                   [0.05 rgb 0.25]
> >>                   [1 rgb 1]
> >>    scale 1.05
> > James Lake
> earth sphere.
> Alain
> Dylan Beattie
I did that but it still generates a solid white sphere.  It is not transparent,
and does not fade at the edges.  There must be another setting or command that
has to change.  The planet and the atmosphere get put together with this:
#declare Planet = union {
  object { PlanetSphere }
  #ifndef (Quick)
    object { PlanetCloudSphere0 }
    object { PlanetAtmosphere }
Is this a good way to do it?
Thanks,
James
Date: 15 May 2008 23:41:45
Message: <482d0279$1@news.povray.org>
james lake napsal(a):
>>>>    hollow
>>>>    material {
>>>>       texture {
>>>>       interior {
>>>>          media {
>>>>             emission <0,0,2>
>>>>             density {
>>>>                spherical
>>>>                color_map {
>>>>                   [0 rgb 0]
>>>>                   [0.05 rgb 1]
>>>>                   [1 rgb 1]
>>>>          media {
>>>>             emission <2,2,0>
>>>>             density {
>>>>                spherical
>>>>                color_map {
>>>>                   [0 rgb 0]
>>>>                   [0.05 rgb 0.25]
>>>>                   [1 rgb 1]
>>>>    scale 1.05
>>> James Lake
>> earth sphere.
>> Alain
>> Dylan Beattie
>   #ifndef (Quick)
>   #end
> Thanks,
> James
Try greatly reducing the media density. The density required is very
dependent on your earth size.
Simply add another density block inside the media, like:
density{
density{
  rgb 1e-5
You know you've been raytracing too long when...
you ever saw a beautiful scenery and regretted not to take your 6"
reflective ball and a digital camera, thinking "this would have been a
perfect light probe"
		-Johnny D
Johnny D
Date: 16 May 2008 13:15:32
Message: <482dc134@news.povray.org>
james lake nous illumina en ce 2008-05-15 22:20 -->
>>>>    hollow
>>>>    material {
>>>>       texture {
>>>>       interior {
>>>>          media {
>>>>             emission <0,0,2>
>>>>             density {
>>>>                spherical
>>>>                color_map {
>>>>                   [0 rgb 0]
>>>>                   [0.05 rgb 1]
>>>>                   [1 rgb 1]
>>>>          media {
>>>>             emission <2,2,0>
>>>>             density {
>>>>                spherical
>>>>                color_map {
>>>>                   [0 rgb 0]
>>>>                   [0.05 rgb 0.25]
>>>>                   [1 rgb 1]
>>>>    scale 1.05
>>> James Lake
>> earth sphere.
>> Alain
>> Dylan Beattie
>   #ifndef (Quick)
>   #end
> Thanks,
> James
The sample use a 1 unit radius "planet", and it's density is set acordingly.
What is the dimention of your planet? If it's 100 units radius, you need to
reduce the media's density by 100, it the radius is 1000, reduce the density by
1000.
What is the quality setting? If set to low, it ignore the transparency and the
rgbt 1 (totaly transparent) becomes rgb 1 (white).
Any society that would give up a little liberty to gain a little security will
deserve neither and lose both.
Benjamin Franklin
Date: 16 May 2008 20:34:50
Message: <482e282a@news.povray.org>
> transparent,
> that
>  #ifndef (Quick)
>  #end
This media is intended to be around a unit sphere.
If you wish to use a different size, scale it after union...
#declare PlanetSurface = sphere { <0,0,0>, 1
      image_map {
         jpeg "earth02.jpg"
         map_type 1
      rotate <0,-150,0>
   object {PlanetAtmosphere}
   object {PlanetSurface}
object {
   Planet
   scale 2
   translate <-1.5,-0.5,0>
Date: 17 May 2008 01:14:48
Message: <482e69c8$1@news.povray.org>
Tim Attwood napsal(a):
>> transparent,
>> that
>>  #ifndef (Quick)
>>  #end
scaling an object doesn't reduce its density. Eight thousand times a
piece of steel is a piece of steel, not a piece of super-sparse steel.
you start thinking up your own "You know you've been raytracing too long
when..." sigs (I did).
		-Johnny D
Johnny D
Date: 17 May 2008 22:38:49
Message: <482f96b9@news.povray.org>
> scaling an object doesn't reduce its density. Eight thousand times a piece
Yeah, the density isn't dependent on scale, I forgot that.
This should work with diferent radius planets.
#declare PlanetRadius = 50;
   hollow
   material {
      interior {
         media {
            emission <0,0,2>
            density {
               spherical
               color_map {
                  [0 rgb 0]
                  [0.05 rgb 1/PlanetRadius]
                  [0.05 rgb 0]
                  [1 rgb 0]
         media {
            emission <2,2,0>
            density {
               spherical
               color_map {
                  [0 rgb 0]
                  [0.05 rgb 0.25/PlanetRadius]
                  [0.05 rgb 0]
                  [1 rgb 0]
   scale 1.05
      image_map {
         jpeg "earth02.jpg"
         map_type 1
      rotate <0,-150,0>
   scale PlanetRadius
object {
   Planet
   translate <-PlanetRadius,0,0>
Date: 18 May 2008 13:55:01
Message: <web.48306c0afa7c99c2d4dec990@news.povray.org>
>    hollow
>    material {
>       texture {
>       interior {
>          media {
>             emission <0,0,2>
>             density {
>                spherical
>                color_map {
>                   [0 rgb 0]
>                   [0.05 rgb 0]
>                   [1 rgb 0]
>          media {
>             emission <2,2,0>
>             density {
>                spherical
>                color_map {
>                   [0 rgb 0]
>                   [0.05 rgb 0]
>                   [1 rgb 0]
>    scale 1.05
>    pigment {
>       image_map {
>          jpeg "earth02.jpg"
>          map_type 1
>       rotate <0,-150,0>
>    scale PlanetRadius
> object {
>    Planet
 Thanks for your help, but now I get a new error.  I replaced "earth02.jpg" with
my file name in:
      image_map {
         jpeg "earthmap1k.jpg"
         map_type 1
         interpolate 2
      rotate <0,-150,0>
But the new error highlights the jpeg line stating:
PARSE ERROR: CANNOT OPEN JPEG FILE
I've used jpeg and png maps before, and even tried cutting and pasting those
into here but for some reason this file doesn't like it.  Why is it doing this?
Thanks,
James Lake
Date: 18 May 2008 14:40:00
Message: <web.483077d0fa7c99c2d4dec990@news.povray.org>
>    hollow
>    material {
>       texture {
>       interior {
>          media {
>             emission <0,0,2>
>             density {
>                spherical
>                color_map {
>                   [0 rgb 0]
>                   [0.05 rgb 0]
>                   [1 rgb 0]
>          media {
>             emission <2,2,0>
>             density {
>                spherical
>                color_map {
>                   [0 rgb 0]
>                   [0.05 rgb 0]
>                   [1 rgb 0]
>    scale 1.05
>    pigment {
>       image_map {
>          jpeg "earth02.jpg"
>          map_type 1
>       rotate <0,-150,0>
>    scale PlanetRadius
> object {
>    Planet
Please ignore my last post - I realized the JPEG file was in a different folder.
 Even then, I had to play with the scales between this include file and the
master POV file to get it to look right.  I found out that if I did the scaling
in this include file, then presented it as a scale of "1" in the master POV
file, it looks great. Thank you to those who responded to my pleas for help!
James Lake
Date: 19 May 2008 15:00:42
Message: <4831ce5a$1@news.povray.org>
james lake nous illumina en ce 2008-05-18 13:51 -->
>>    hollow
>>    material {
>>       texture {
>>       interior {
>>          media {
>>             emission <0,0,2>
>>             density {
>>                spherical
>>                color_map {
>>                   [0 rgb 0]
>>                   [0.05 rgb 0]
>>                   [1 rgb 0]
>>          media {
>>             emission <2,2,0>
>>             density {
>>                spherical
>>                color_map {
>>                   [0 rgb 0]
>>                   [0.05 rgb 0]
>>                   [1 rgb 0]
>>    scale 1.05
>>    pigment {
>>       image_map {
>>          jpeg "earth02.jpg"
>>          map_type 1
>>       rotate <0,-150,0>
>>    scale PlanetRadius
>> object {
>>    Planet
> my file name in:
>    pigment {
>       image_map {
>          map_type 1
>          interpolate 2
>       rotate <0,-150,0>
> Thanks,
> James Lake
Where is your image located?
The way you call it, it must redide in the same folder as your scene, the
include folder, or some other allowed folder as defined by you.
You know you've been raytracing too long when you look at waterfalls, dust,
rain, snow, etc, and think: "If only I had a fractalized, vector based
particle-system modeler with collision detection!"
