POV-Ray : Newsgroups : povray.newusers : image spherical projection and postscript. Server Time
28 Sep 2024 22:15:56 EDT (-0400)
  image spherical projection and postscript. (Message 1 to 5 of 5)
Subject: image spherical projection and postscript.
Date: 2 Feb 2008 05:55:00
Message: <web.47a44adec0e4bb1b5f201c20@news.povray.org>
Hi everybody,
I have a bitmap I want to project onto the surface of a sphere. I want to use
spherical projection, so that the image is not distorted. The problem is that I
want to control the angle covered (measured from the center of the sphere). One
solution would be to increase the bitmap size with nothing around, but that is
ugly. What is the correct way to do this?
Another question: I am using a bitmap obtained from a postscript file I have,
because I did not find the way to use the PS directly. Is it possible?
Thanks in advance.
Subject: Re: image spherical projection and postscript.
Date: 2 Feb 2008 07:19:50
Message: <47a45fe6$1@news.povray.org>
"zeycus" <mig### [at] onocom> wrote in message
news:web.47a44adec0e4bb1b5f201c20@news.povray.org...
> Hi everybody,
> use
> that I
> sphere). One
> that is
Use the 'once' keyword and scale in 'x'  to get a segment (or scale in 'y'
and translate in 'y' to get a ring around the middle of the sphere).
light_source { <-15,7.5,-15>, rgb 2}
camera {location <0,3,0> look_at <0,0,0>}
sphere {0,1
      image_map {sys "ngtest11.bmp" once}
      scale 0.6*x
      rotate x*90
      warp {spherical
        orientation y
        dist_exp 1
> have,
No. The valid bitmap types are "gif | tga | iff | ppm | pgm | png | jpeg |
tiff | sys".
No vector graphics formats are supported.
Chris B.
Date: 2 Feb 2008 07:29:08
Message: <47a46214@news.povray.org>
  Apply this tip using the spherical warp:
http://tag.povray.org/povQandT/languageQandT.html#cylindricalrepeat
Date: 3 Feb 2008 10:25:01
Message: <web.47a5dc66a2a0ea67b5f201c20@news.povray.org>
> > Hi everybody,
> > use
> > that I
> > sphere). One
> > that is
> Hi,
> sphere {0,1
>   texture {
>     pigment {
>       scale 0.6*x
>       rotate x*90
>       warp {spherical
>         orientation y
>         dist_exp 1
Thank you, this is exactly what I was looking for. I did not know the warp
command, that was my problem.
> > have,
> tiff | sys".
A pitty. Maybe not many people would use it, I don't know, but for me it would
be useful!
Date: 3 Feb 2008 10:57:28
Message: <47a5e468@news.povray.org>
news:web.47a5dc66a2a0ea67b5f201c20@news.povray.org...
>> 'y'
Looking at the link Warp posted, I think you should be able to do the same
with Map Type 1 and avoid the need for the Warp, but I've not tried that
myself.
Chris B.
