POV-Ray : Newsgroups : povray.newusers : Bump / Normal height Server Time
18 Dec 2025 16:23:51 EST (-0500)
  Bump / Normal height (Message 1 to 4 of 4)
Subject: Bump / Normal height
Date: 13 Aug 2007 22:45:00
Message: <web.46c1166a18f10146e3b389310@news.povray.org>
I can't seem to figure out how to change the intensity of normal surfaces
from the pov documentation. i.e how far a normal surface portrudes from the
regular surface of an object.
How do I change how far the checker lines extend beyond the 2 unit radius of
the sphere?
Is there any to also change the width of the lines (i.e) thicker lines, but
keeeping the area of each square relatively the same?
The pic and source are as follows
http://www.geocities.com/jeffwood581981/bump.bmp
http://www.geocities.com/jeffwood581981/bump.txt
Any help is greatly appreciated.
Subject: Re: Bump / Normal height
Date: 14 Aug 2007 00:40:42
Message: <JUuh6CAEITwGFwTK@econym.demon.co.uk>
>the sphere?
Bumps and normals don't extend beyond the surface. The effect is
produced by pretending that the surface is tilted, but each pixel is
still located exactly on the surface.
To actually extend beyond the radius of the sphere you can switch to
using isosurfaces.
   "The GeoCities web site you were trying to view has temporarily
   exceeded its data transfer limit. Please try again later."
You could probably have avoided that problem by using a compressed image
format for your files. An 800*600 full colour BMP image is 1.406 Mb. You
could have used a JPG image of about 40kb (depending on how lossy you
set the compression) or a lossless PNG image of 79kb.
Mike Williams
Gentleman of Leisure
Date: 14 Aug 2007 06:07:09
Message: <46c17ecd$1@news.povray.org>
Woody nous apporta ses lumieres en ce 2007/08/13 22:41:
> the sphere?
Normals never change the actual shape of the object, only the aspect of the surface.
If you want your checker pattern to change the shape of the sphere, you need to
use an isosurface.
For that, you need to use layered pattern. Add 3 gradients pattern, one aligned
along each axis, with a color_map like: color_map{[0.01 rgb 0][0.01 rgbt 1]}
You know you've been raytracing too long when whenever you write include, even
in essays, etc, you always add a "#".
Date: 14 Aug 2007 09:47:28
Message: <46c1b270@news.povray.org>
This will not only sidestep the data transfer limit problem, but also
allow those of us who live in the middle of nowhere and are permanently
stuck on dial-up to actually *see* your pics.  ;)
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
