![](/i/fill.gif) |
sumdumguy nous apporta ses lumieres en ce 2007/06/25 14:12:
> I am looking to create an effect where I have a tube and there is algae
> growing
> off of it. The rough shape is similar to this image:
> http://www.fortunecity.com/greenfield/hawks/191/ChekJawa/chek3.jpg
> That seems to be a real thing so no pov model is available :).
> I am wondering whether there is a tool which generates such things. It is
> not
> quite landscape or tree generator (needs to be semitransparent and no
> branching
> and does not grow on a plane but on a tube, also needs to "wiggle").
How about using sphere_sweeps with a reasonable number of points. Use the
v_turbulence and v_rotate macros, with a magnitude that start at almost zero and
slowly increase as you reach the tips, to place each succesive points. Place a
copy of those points in some arrays that you can read back to check for
intersections.
By using v_turbulence and restricting the range, you will minimize the
probability of neiboring tentacles to intersect each other, and elliminate the
risk of self-intersections.
I realise that this is somewhat advanced, and may be beter placed in the general
or advanced-users groups.
Black holes suck!
![](/i/fill.gif) |
![](/i/fill.gif) |
sumdumguy wrote:
> I just did a rough calculation and I need about 200 of these "tentacles".
> So it's not as bad as I thought but still very painful. Any automation tool
> would be good to know about.
I'm sorry I should have said let pov make and move the "tentacles" for
you using "sphere_sweep". (Like Alain's thoughts below)
"By Hand" has come to mean to me ,I know it's wrong :( , using POV to
make something. I'll try to do better. :)
You set up an array or arrays for a default "sphere_sweep" to get the
length and shape you want then deform that array for each tentacle and
place it on your tube.
![](/i/fill.gif) |
