POV-Ray : Newsgroups : povray.newusers : [Noob] Camera help Server Time
17 Aug 2025 13:40:59 EDT (-0400)
  [Noob] Camera help (Message 1 to 7 of 7)
Subject: [Noob] Camera help
Date: 21 Jun 2007 10:00:02
Message: <web.467a84289c4ccf4c7b1722700@news.povray.org>
I can't get the camera to go where I want it to go, when I put in
coordinates, it always ends up being rotated. What am I doing wrong (or
what should I be doing right)?
Subject: Re: [Noob] Camera help
Date: 21 Jun 2007 12:00:26
Message: <467aa09a$1@news.povray.org>
As with any question:
What are you trying to do?
What are you doing?
(at least post your camera code)
What goes "wrong"?
(what do you mean rotated? there are 3 axes of rotation - which do you
have problem with?)
Where is the problem with using a standard camera and setting the
location and the look at points?
camera{
   up y
   location <0,2,-10>         //where the camera is
   look_at  <0,2,0>           //where you want to look
   angle 41
Date: 21 Jun 2007 15:34:35
Message: <467ad2cb$1@news.povray.org>
Well, just a wild guess here--the camera by default tries to orient
itself with y as "up". If your camera is pointed straight up or straight
down the y axis, it can get confused.
William Tracy
|a|f|i|s|h|i|o|n|a|d|o|@|g|m|a|i|l|.|c|o|m|
|w|t|r|a|c|y|@|c|a|l|p|o|l|y|.|e|d|u|
You know you've been raytracing too long when your 18 year-old daughter
asks if she can marry one of the POV Team, and you give her your
complete blessing.
Taps a.k.a. Tapio Vocadlo
Date: 21 Jun 2007 17:38:47
Message: <467aefe7$1@news.povray.org>
Caligula nous apporta ses lumieres en ce 2007/06/21 09:59:
Here are the parameters of a default camera:
camera{
	location <0,0,0>
	right 4/3
	up <0,1,0> // can be shortened to up y
	direction <0,0,1>// can be shortened to direction z
	sky y
If you place it on the y axis and look along it, it can get confused. A
workaround would to place it at the same distance but along the -z axis then
rotate 90*x to bring it on the +y axis.
Instead of using:
camera{location 10*y look_at -y} or camera{location 10*y direction -y}
use:
camera{location -10*z rotate 90*x}
You may confuse the axis system: +x is toward the right, +y is up (vertical) and
+z is away (horizontal).
Don't cry because it is over, smile because it happened.
Date: 22 Jun 2007 06:47:01
Message: <467ba8a5@news.povray.org>
Just add a "translate <your coordinates>" at the end of the camera
block. Much simpler.
Date: 24 Jun 2007 03:20:01
Message: <web.467e1b147b36d3efc573be920@news.povray.org>
Wow, thanks everybody for the help, but I figured out what my problem was.
I hadn't specified the sky correctly, so it would end up pointing funny
directions.
Date: 24 Jun 2007 09:09:04
Message: <467e6cf0@news.povray.org>
Caligula nous apporta ses lumieres en ce 2007/06/24 03:19:
> directions.
You usualy don't need to define the sky vector, the default of +y is normaly
good for any cases.
The same hold true for the up vector.
I find the affluence of incahol to be totally, whatever he said
