Tim Attwood <tim### [at] comcast net> wrote:
> With radiosity ambient 0 means an object doesn't emit light
The reflection of light on surfaces is controlled by the diffuse term
(as it should). The ambient component can be bumped up to artificially
make a surface emit more light than it normally would, but ambient is
not necessary, and in fact for "realistic" results should be turned off.
(After all, the ambient component is only a cheap radiosity substitute.)
"Arno" <nomail@nomail> wrote:
> I'm already using a large sphere with an HDRI image map instead of
> sky_sphere. This shpere has ambient >0, hence it functions as a light
> source.
> BWT, I'm using MegaPov, since Povray 3.6 doesn't support HDRI.
Aha. Try adding the no_radiosity keyword to your glass dome.
Bill
> > source.
> Bill
Thanks! That did the trick.
Can anybody explain why this is needed here? I don't understand it.
I think it's just because the radiosity sampling ignores transparency.
Presumably, diffuse and ambient contributions to the illumination are taken
from the first object encountered along the sampling ray regardless of other
surface characteristics; as a side effect, transparent objects block
radiosity lighting. I'm sure others can expand on this if I have it wrong!
I'm not sure how one would reliably avoid this issue in standard POV-Ray
versions though - I think no_radiosity is indigenous to MegaPOV.
Bill
Bill Pragnell nous apporta ses lumieres en ce 09-02-2007 07:32:
It get's thru transparent objects in standard POV-Ray.
> Bill
Radiosity do work trough transparent objects, you can even have a lense or globe
project an image on a surface. That image becomes crude if the focal lenght gets
to long, but it's there.
WARNING: the crumsumpten of alcohol may Mack you tink you kan tpye reel gode
Yes, I guessed it should be possible. Is there anything I can do to 'fix'
this problem except for adding the no_radiosity keyword?
Render it as a 2 frame animation and use save_file to save the
radiosity data witout the glass, then load the data back in and
do a final frame with the glass.
global_settings {
assumed_gamma 1.0
max_trace_level 10
#switch (frame_number)
#case (1)
radiosity {
save_file "bidirectional.dat"
#break
#case (2)
radiosity {
load_file "bidirectional.dat"
object {globe}
#break
I'm sorry if this sounds stupid, but wouldn't this be the same as using the
no_radiosity keyword in MegaPov?
> I'm sorry if this sounds stupid, ...
The only stupid question is the one you don't ask =)
>...but wouldn't this be the same as using the
No, radiosity is calculated in the second frame for
the scene again, correcting for the globe having been
left out of the first frame, there's just more samples
that make it thru to the center sphere from the first frame.
Hmmmmm..... I tried both approaches. There's almost no difference between
the resulting images, if any.
