POV-Ray : Newsgroups : povray.newusers : bicubic_patch limitations? Server Time
20 Dec 2025 04:39:37 EST (-0500)
  bicubic_patch limitations? (Message 1 to 5 of 5)
Subject: bicubic_patch limitations?
Date: 12 Jan 2007 05:25:01
Message: <web.45a761af6f5b502e3cd9c0860@news.povray.org>
I am pretty New to Povray and use Moray as well to generate scenes. But I
have a problem with the bicubic_patch.
What I wanted to do is generate a flat bicubic_patch where the start control
points are all at the same position. But it seems I loose the entire rounded
side and only display one the triangle. Even bringing the points close
This is the code I have
object { // BezPtch001
  object {
    bicubic_patch { type 1 flatness 0.0100 u_steps 3 v_steps 3,
      <1.000000, -2.000000, 0.000000>, <1.000000, -2.000000, 0.000000>,
      <-2.000000, -1.000000, 0.000000>, <-1.000000, -1.000000, 0.000000>,
<0.000000, -1.000000, 0.000000>, <1.000000, -1.000000, 0.000000>,
      <-2.000000, 0.000000, 0.000000>, <-1.000000, 0.000000, 0.000000>,
<0.000000, 0.000000, 0.000000>, <1.000000, 0.000000, 0.000000>,
      <-2.000000, 1.000000, 0.000000>, <-1.000000, 1.000000, 0.000000>,
<0.000000, 1.000000, 0.000000>, <1.000000, 1.000000, 0.000000>
  material {
    Material2
  translate  1.0*z
Bizarly enough moving some of the inner pounts up along the Z axis does
solve my problem for the most part. Like this.
  object {
    bicubic_patch { type 1 flatness 0.0050 u_steps 3 v_steps 3,
      <-2.000000, -1.000000, 0.000000>, <-1.000000, -1.000000, 0.200000>,
<0.000000, -1.000000, 0.200000>, <1.000000, -1.000000, 0.200000>,
      <-2.000000, 0.000000, 0.000000>, <-1.000000, 0.000000, 0.200000>,
<0.000000, 0.000000, 0.200000>, <1.000000, 0.000000, 0.200000>,
      <-2.000000, 1.000000, 0.000000>, <-1.000000, 1.000000, 0.200000>,
<0.000000, 1.000000, 0.200000>, <1.000000, 1.000000, 0.200000>
  material {
    Material2
  translate  1.0*z
Am I just stupid? Or is this normal? And if so Why?
Napivo
Subject: Re: bicubic_patch limitations?
Date: 12 Jan 2007 06:18:27
Message: <45a76e83$1@news.povray.org>
I'm not sure what shape you want it to be, but 2 of your corner points are
in the same place. The points in a bicubic patch follow this order:
A, B, C, D,
E, F, G, H,
I, J, K, L,
M, N, O, P
You can imagine that's a top-down view of the patch, the points A D M and P
are the corners, all the ones in between are control points. In yours A and
D have the same position <1.000000, -2.000000, 0.000000>, hence it appears
triangular.
A simple square one would be:
<0,0,0>, <1,0,0>, <2,0,0>, <3,0,0>,
<0,1,0>, <1,1,0>, <2,1,0>, <3,1,0>,
<0,2,0>, <1,2,0>, <2,2,0>, <3,2,0>,
<0,3,0>, <1,3,0>, <2,3,0>, <3,3,0>
That might be an easier thing to start with. Note the control points are
evenly spread between the corners so you get a nice distribution of polygons
when pov processes the patch. Also I wouldn't bother using flatness, it's
not really necessary unless your patch is really slow to draw.
Tek
http://evilsuperbrain.com
"Napivo" <Nap### [at] yahoofr> wrote in message
news:web.45a761af6f5b502e3cd9c0860@news.povray.org...
> control
> rounded
> together doesn't solve my problem.
>  object {
>  material {
>    Material2
>  translate  1.0*z
>  object {
>  material {
>    Material2
>  translate  1.0*z
> Napivo
Date: 12 Jan 2007 08:20:01
Message: <web.45a78ae9dbaa73933cd9c0860@news.povray.org>
Thanks,
I posted a message at http://docs.google.com/View?docid=dk65p6z_6cpkdtv to
demonstrate  what I was trying to do.  It works now as I decided to curve
the deck of the ship. This is more realistic anyhow.
But I still find it odd that a flat bicubic_patch gives me a rectangle while
a curved one curves in both directions.
I will not worry about it any longer. For me the problem is solved.
Thanks for your time
Napivo
> A, B, C, D,
> E, F, G, H,
> I, J, K, L,
> M, N, O, P
> triangular.
> Tek
// Message Truncated //
Date: 12 Jan 2007 16:18:55
Message: <45a7fb3f@news.povray.org>
Napivo nous apporta ses lumieres en ce 12-01-2007 08:19:
> Thanks,
> Napivo
There is nothing "strange" about a flat bicubic_patch to apears as a rectangle.
There are 4 base points and 12 equidistent control points, all coplanar, this
can't make anything but a rectangle unless two base points are merged into one
changint it into a triangle.
   I'm so ugly I stuck my head out the window and got arrested for Mooning.
   	Rodney Dangerfield
Date: 24 Jul 2011 06:05:00
Message: <web.4e2bedf5dbaa73939724cdf50@news.povray.org>
If anyone stumbles across this problem, the solution is to set the flatness
parameter to zero (the default value).
