POV-Ray : Newsgroups : povray.newusers : how to move an object to position <0,0,0> Server Time
17 Mar 2026 02:44:12 EDT (-0400)
  how to move an object to position <0,0,0> (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: how to move an object to position <0,0,0>
Date: 8 Sep 2006 05:25:00
Message: <web.450136bb1e67056d3e732b9a0@news.povray.org>
kurtz le pirate <kur### [at] yahoofr> wrote:
> move your "rubrics cube" by adding "translate -0.50*full_cube_size"
This applies if your object rotates _exactly_ around that corner. In any
other case the following should work as long as the object is not too
complicated:
translate -0.50*(min_extent(myObject)+max_extent(myObject))
this actually centers the bounding box of the object but that should be
calculated correctly for a cube-ish structure
Hope this helps
Regards Roman
Date: 8 Sep 2006 06:03:35
Message: <45013ff7@news.povray.org>
  Just curious: What's the second 0 for?
Date: 8 Sep 2006 06:05:00
Message: <web.4501400e1e67056d800aa0230@news.povray.org>
> complicated:
> Hope this helps
> Regards Roman
Thanks for your answer. Unfortunately the cube still doesn't rotate around
the middle, maybe the bounding box of my cube is somewhere odd. Any other
suggestions?
Date: 8 Sep 2006 06:41:00
Message: <450148bc@news.povray.org>
> suggestions?
  Well, do you know the actual limits of the cube? If you do, just
substitute them in the given formula.
Date: 8 Sep 2006 06:58:00
Message: <45014cb8@news.povray.org>
Nostromo do a little mistake its in fact
translate      + 0.50*(min_extent(myObject)+max_extent(myObject))
news:web.4501400e1e67056d800aa0230@news.povray.org...
> > complicated:
> > Hope this helps
> > Regards Roman
> suggestions?
Date: 8 Sep 2006 07:00:39
Message: <45014d57@news.povray.org>
Forget it, its not nostromo mistake ,, should be mine
news:45014cb8@news.povray.org...
any
> > > complicated:
be
> > > Hope this helps
> > > Regards Roman
around
other
> > suggestions?
Date: 8 Sep 2006 07:15:00
Message: <web.450150251e67056d800aa0230@news.povray.org>
Thanks for your help, but it still won't rotate around the middle of thebig
cube. Maybe someone can have a look at my code and tell me what's wrong?
Here's the POV file
#include "textures.inc"
#include "shapes.inc"
#include "glass.inc"
#include "metals.inc"
#include "woods.inc"
#include "functions.inc"
#declare Count = 3 ;
#declare Gap = 0.2 ;
global_settings {
                ambient_light rgb <1, 1, 1>
background { rgb <1,1,1> }
#declare Rubics = union {
 #declare z_axis = 0 ;
 #while ( z_axis < Count )
  #declare y_axis = 0 ;
  #while ( y_axis < Count )
   #declare x_axis = 0 ;
   #while (x_axis < Count)
    superellipsoid { <0.25, 0.25>
     translate <(2+Gap)*x_axis, (2+Gap)*y_axis, (2+Gap)*z_axis>
    #declare x_axis = x_axis + 1 ;
   #declare y_axis = y_axis + 1 ;
  #declare z_axis = z_axis + 1 ;
 location <25, 20, -25>
 look_at <8, 6, 0>
light_source {
 <200, 200, -200>
 color rgb <1,1,1>
object { Rubics
         pigment { color Green }   //Col_Glass_Vicksbottle }
  finish {
                        phong 1
                        reflection 0.15
                        ambient 0.2
                        diffuse 0.9
  interior { I_Glass }
  scale <3,3,3>
  rotate <clock, clock*2, clock*4>
  translate +0.50*(min_extent(Rubics)+max_extent(Rubics))
When I animate this I want the cube to rotate around it's center, but it's
rotating around some point near one of the corners.
Thanks a lot in advance.
Date: 8 Sep 2006 08:45:00
Message: <web.4501659b1e67056df1cb1e660@news.povray.org>
> Here's the POV file
[snip]
> object { Rubics
>   finish {
>                         phong 1
>                         reflection 0.15
>                         ambient 0.2
>                         diffuse 0.9
>   scale <3,3,3>
Nostromo
You should translate to the origin before rotating
Date: 8 Sep 2006 09:27:48
Message: <kurtzlepirate-669711.15274708092006@news.povray.org>
In article <web.450150251e67056d800aa0230@news.povray.org>,
well, well...
from your source whe can find that :
RMax = max_extent(Rubics) => <5.4, 5.4, 5.4>
RMin = min_extent(Rubics) => <-1, -1, -1>
translate the object with : translate -0.5*(RMax+RMin) give :
RMax = <3.2, 3.2, 3.2>
RMin = <-3.2, -3.2, -3.2>
Rubics is now perfectly center at the origin and rotations are ok. if
not, there are somes others problems :
 - your are not looking at the origin.
 - in "rotation <clock, clock*2, clock*4>" don't forget that clock varie
from 0 to 1 degrees
klp
Date: 8 Sep 2006 13:00:00
Message: <web.4501a0e91e67056d3e732b9a0@news.povray.org>
when writing my own code i'd actually leave the first 0 out as well. i just
wanted to clean it up a little and went over the top maybe ;)
