POV-Ray : Newsgroups : povray.newusers : Povray on mac crashing Server Time
16 Jan 2026 16:22:09 EST (-0500)
  Povray on mac crashing (Message 1 to 8 of 8)
Subject: Povray on mac crashing
Date: 4 Sep 2006 07:20:00
Message: <web.44fc0bbadeea2ee19b850880@news.povray.org>
I installed povray 3.6 onto my macBook pro. Whenever I try to open it, it
starts opening and goes as far as showing sort of a table named 'Messages'
and another named 'Templates'. Then it just vanishes and gives this
message:- "The application POV-Ray Mac 3.6 quit unexpectedly". I was
wondering if you could help me in this matter.
I have very little experience with povray and I've only worked on it on a
Linux based machine.
Thanks
Subject: Re: Povray on mac crashing
Date: 4 Sep 2006 08:07:57
Message: <44fc171c@news.povray.org>
  Even though MacOS X *should* be able to run older MacOS software even
in the new intel macs, I still wonder if that problem you describe could
be caused by this...
  If you don't mind using povray in the linux-way, you can always
download the source distribution and compile it as a command-line
version (like in linux), assuming you have gcc (or any similar
compiler) installed. MacOS X *is* basically a unix, so it should
work.
Date: 4 Sep 2006 10:55:00
Message: <web.44fc3d1dacb2a8b619b850880@news.povray.org>
> work.
So I should be able to compile it on XCode?
Thanks
Date: 4 Sep 2006 11:55:00
Message: <web.44fc4c19acb2a8b619b850880@news.povray.org>
> > work.
> >                                                           - Warp
> Thanks
I just downloaded and compiled povray source code for linux on to my macbook
pro. I followed the instructions given in one of the files that I unpacked
from the download using the following commands:-
% ./configure COMPILED_BY="your name <email@address>" [options]
% make check
% su
$ make install
It went smoothly without a glitch. But I cant seem to run povray. I typed
"povray +I picture.pov". There is a pov file named picture.
Date: 4 Sep 2006 14:34:29
Message: <44fc71b4@news.povray.org>
  What does it say?
Date: 5 Sep 2006 07:15:01
Message: <web.44fd5c07acb2a8b619b850880@news.povray.org>
>   What does it say?
It says
-bash: povray: command not found
Date: 5 Sep 2006 07:56:28
Message: <44fd65ec@news.povray.org>
  Well, doesn't that tell you exactly what is the problem? The povray
binary is not in your path.
  Either copy the binary to somewhere in your path ("~/bin/" is usually
in linux systems, but might not be in MacOS X) or start it with the
full path. (If the binary is in the current directory, then "./povray"
or if it's in another directory then "/the/full/path/to/povray".)
Date: 6 Sep 2006 06:00:01
Message: <web.44fe9b4aacb2a8b6731f01d10@news.povray.org>
I've just obtained an Intel-based Mac, and I get exactly the same result.
DAZ Studio doesn't run either. However, if you're brave enough to try it,
the universal binary version of MegaPOV works perfectly.
http://megapov.inetart.net/download.html
Bill
