POV-Ray : Newsgroups : povray.newusers : An image_map on the whole box? Server Time
8 Apr 2026 13:52:31 EDT (-0400)
  An image_map on the whole box? (Message 1 to 8 of 8)
Subject: An image_map on the whole box?
Date: 19 Jul 2006 07:00:01
Message: <web.44be105035a75dd650c9b38a0@news.povray.org>
when I use a image_map as a texture for a box, then of course I can't see on
at least one side of the box the correct image.
So, my question is, if it is possible, to translate, scale, rotate or
whatever, to see the image on every side of the box?
Here's the expample of my problem:
http://three.fsphost.com/MSAB5/PC_problem.JPG
Subject: Re: An image_map on the whole box?
Date: 19 Jul 2006 08:35:00
Message: <web.44be263e211f9441a2981db0@news.povray.org>
possibility 1: rotate the image_map by <45,45,0>
possibility 2: use a mesh or mesh2 with uv_mapping instead of a box
possibility 3: use an intersection of (seperately textured) planes instead
of a box
possibility 4: use proceduals instead of image_maps
Hope this helps
Regards Roman
"MSAB" <MSA### [at] gmxnet> wrote:
> Hi,
Date: 19 Jul 2006 09:07:52
Message: <44be2ea8$1@news.povray.org>
"Roman Reiner" <lim### [at] gmxde> wrote in message
news:web.44be263e211f9441a2981db0@news.povray.org...
> of a box
> Hope this helps
> Regards Roman
>> Hi,
>> on
Possibility 5: (a bit of a cheat) would be to have 3 concentric copies of
the same object with the image rotated appropriately through 90 degrees on
each one. The one with the image correct on the x-plane should then be
scaled by <1.0001,1,1>, the one with the image on the y-plane by
<1,1.0001,1> etc. This won't handle every little piece of your surface, but
the main outer surfaces will end up with the right texture showing through.
Chris B.
Date: 19 Jul 2006 09:27:06
Message: <44be332a$1@news.povray.org>
>> of a box
> each one.
   Doesn't anyone read the documentation anymore? How about simply
using uv-mapping on the box directly? It's a supported object:
http://povray.org/documentation/view/3.6.1/358/
   If you use a repeating planar image map, scale it properly and
then apply uv_mapping, it will repeat the image on each side of
the box.
Date: 19 Jul 2006 10:25:00
Message: <web.44be4089211f9441cc36dbe70@news.povray.org>
Thanks, but I only can use meethod "rotate<45,45,0>", becasue the whole
modell isn't really a box. It's the thing you can see in my first post :D.
There I used only CSG and no meshes or other objects like that. But thanks
to your other answers...
MfG
MSAB
Date: 19 Jul 2006 11:20:52
Message: <44be4dd4@news.povray.org>
"MSAB" <MSA### [at] gmxnet> wrote in message
news:web.44be4089211f9441cc36dbe70@news.povray.org...
> MfG
> MSAB
Method 5 doesn't need it to be a real box either.
Chris B.
Date: 19 Jul 2006 12:00:00
Message: <web.44be5638211f9441138f92b60@news.povray.org>
> > MfG
> > MSAB
> Regards,
> Chris B.
Yes, sure. But however I have to make everything new for that method and
that would be too much work (for me :D), because the source is over 2000
lines long. So I better use method 1^^.
MSAB
Date: 22 Jul 2006 01:02:00
Message: <44c1b148@news.povray.org>
MSAB wrote:
> Hi,
Try this:
#declare T1 = texture { image_texture here }
#declare T2 = texture {
	radial
	texture_map { [.65 T1 ] }
	frequency 4
	rotate y*45
#declare Cutoff = .15; // adjust Cutoff to fit vertical corners
#declare T_Cube = texture {
	slope y
	texture_map {
		[0.00     T1 rotate x*90 ]
		[Cutoff   T1 rotate x*90 ]
		[Cutoff   T2  ]
		[1-Cutoff T2  ]
		[1-Cutoff T1 rotate x*90 ]
		[1.00     T1 rotate x*90 ]
RG
