POV-Ray : Newsgroups : povray.newusers : Non-uniform fog... Server Time
8 Apr 2026 17:38:27 EDT (-0400)
  Non-uniform fog... (Message 1 to 4 of 4)
Subject: Non-uniform fog...
Date: 19 May 2006 05:45:01
Message: <web.446d92aa77416bd5a8eb78fb0@news.povray.org>
I need a non-uniform fog and I've tryied with this:
    box{
        <-100,-10,1>, <100,20,2000>
          hollow
      pigment {rgbt <0,0,0,1>}
      interior {
      media {
         intervals 1
         samples 1,1
         emission <0.8,0.8,0.8>
         density{bozo}
the result is a strange and innatural fog!
How can I do?
Subject: Re: Non-uniform fog...
Date: 19 May 2006 05:53:41
Message: <446d95a5@news.povray.org>
danyolgiax <d.o### [at] gmailcom> wrote:
>          intervals 1
>          samples 1,1
  What do you expect with those settings?
Date: 19 May 2006 08:58:30
Message: <446dc0f6@news.povray.org>
>    box{
>          hollow
>      interior {
>      media {
>         intervals 1
>         samples 1,1
>         density{bozo}
>How can I do?
One problem is the color.  From the documentation (section 3.5.11.4):
"The bozo pattern has a default color_map built in that results in a
green, blue, red and white pattern with sharp transitions."
If you don't want such colorful fog, see section 3.6.2.3.2,  "Density
with color_map."
Hope this helps.
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 19 May 2006 11:39:03
Message: <446de697$1@news.povray.org>
danyolgiax nous apporta ses lumieres en ce 19/05/2006 05:40:
>     box{
>           hollow
>       interior {
>       media {
>          intervals 1
>          samples 1,1
>          density{bozo}
> How can I do?
To few samples. You probamly need something like 20 to 100 or more. Only use one
value, the second
is not used with the default sampling method. The default method needs AT LEAST 3
samples.
Try using the bumps pattern instead of bozo. bozo use it's own color_map, bumps don't.
Black holes suck!
