POV-Ray : Newsgroups : povray.newusers : Smooth blending of two or more materials via bitmap mask(s) Server Time
8 Apr 2026 17:42:06 EDT (-0400)
  Smooth blending of two or more materials via bitmap mask(s) (Message 1 to 4 of 4)
Subject: Smooth blending of two or more materials via bitmap mask(s)
Date: 6 May 2006 13:00:01
Message: <web.445cd5308ae347bc1effc9720@news.povray.org>
Hi all,
I am relatively new to Povray. Usually I model in Blender and then render
with Povray via Blend2Pov.
Basically what I am trying to do is to create nice looking rust material.
Let's say I have base metal material, displacement image (lettering that has
to be embossed) and 3 layers of rust. All of that has to be blended together
via image masks I am going to create in GIMP.
I have tried to experiment with material maps, but I get really weird
results :(
I don't get smooth transition between materials.
Here is a mask:
http://img282.imageshack.us/img282/5996/mask1cs.jpg
And here is a result:
http://img473.imageshack.us/img473/6500/matmaptest2vs.jpg
Can somebody help me and explain how to get smooth transaction between
materials please?
Subject: Re: Smooth blending of two or more materials via bitmap mask(s)
Date: 6 May 2006 14:45:00
Message: <web.445ceda2965bd4271bd1c060@news.povray.org>
> results :(
No, you won't generally get smooth transition between materials using
material maps. What you really want to use here is a texture_map. See
'3.5.5.1  Texture Maps' in the POV 3.6 docs. Using a texture_map, you can
get smooth or sharp transitions between textures.
Why do you want to use a displacement map for the text, rather than a POV
text object? Is the text distorted by the corrosion? Will you do the
displacement using a heightfield, a mesh, an isosurface, or just fake it
with normals? Decisions, decisions! :) Since you're new to POV, I'd suggest
using a heightfield or mesh, if the native text object isn't suitable.
Good luck with the rust. It can be very hard to get it to look right, but
there are a few rust experts around here, with great examples posted last
year. Just scan back through the 'images' group for pics and code.
Date: 6 May 2006 15:09:29
Message: <445cf469$1@news.povray.org>
news:web.445ceda2965bd4271bd1c060@news.povray.org...
Have a look at 3.5.11.20  Image Pattern in the POV 3.6 doc as well
Marc
Date: 6 May 2006 15:55:01
Message: <web.445cfe15965bd42776ba2c900@news.povray.org>
> Marc
Good idea, Marc! It's probably a little simpler than using a texture_map
with an image_map, too. I'd forgotten about this one...
