POV-Ray : Newsgroups : povray.newusers : Some questions Server Time
20 Dec 2025 21:08:06 EST (-0500)
  Some questions (Message 1 to 6 of 6)
Subject: Some questions
Date: 19 Apr 2006 15:20:01
Message: <web.44468c5a17a48cdd95c034480@news.povray.org>
PovRay.
- Is there any chance to implement blurry reflections in Povray?
- Will there ever be another GI mode (I think of path tracing :)
brixX
Subject: Re: Some questions
Date: 19 Apr 2006 15:40:01
Message: <web.4446916e3adb077f6c4803960@news.povray.org>
"brixX" <og_### [at] webde> wrote:
> Hi,
> PovRay.
Perhaps fresnel reflection is what you want in POV (See fresnel in "3.5.3.4
Specular Reflection" in the help.
Yes, but you have to create it yourself (See "Is blurred reflection
possible?
" http://tag.povray.org/povQandT/languageQandT.html#blurredreflection)
-tgq
Date: 19 Apr 2006 15:41:20
Message: <44469260@news.povray.org>
brixX <og_### [at] webde> wrote:
> - Is it possible to create a ramp material (in Blender it?s called ramp, in
> cinema 4d it?s called fresnel)
  Could you be more specific?
  (You can find something in the documentation if you search for 'fresnel',
but I'm not sure if it is what you are looking for.)
  Why? You can already do blurry reflections in POV-Ray:
  What is it?
Date: 19 Apr 2006 18:30:21
Message: <4446b9fd@news.povray.org>
news:web.44468c5a17a48cdd95c034480@news.povray.org...
> Hi,
> PovRay.
in
is that what you mean?
   pigment
      marble // linear ramps or "wood" for concentrical ramps
      color_map
         [ 0.0     rgb 0 ]
         [ 1.0     rgb 1 ]
      ramp_wave // for marble and wood patterns defaut waveform  is triangle
so you have to put the ramp_wave statement
//Marc
Date: 19 Apr 2006 19:35:01
Message: <web.4446c85a3adb077f7d55e4a40@news.povray.org>
And falloff in 3DSMax? It's not easy, I think. You will need to use more
than one POVRay texturing method to imitate the effect of ramp. You might
start by looking at the brilliance (for diffuse) and metallic (for specular
highlights) keywords. Anything more sophisticated/closer to ramp will
require you to mix between textures using a texture_map. Example (uses the
angle-of-incidence pattern, which you'll find in MegaPov):
#declare SpecDim = texture {
  pigment { colour rgb <0,0,1> }
  finish { specular 1 roughness 0.01 brilliance 0.5 }
#declare SpecBright = texture {
  finish { specular 1 roughness 0.01 metallic brilliance 5 }
#declare LightDirection = <1,2,3>;
#declare MyOddTexture = texture {
  pigment_pattern { aoi LightDirection }
  texture_map {
    [0.0 SpecBright ]
    [0.5 SpecDim ]
Close to your light source, the specular highlights will appear closer in
colour to your surface, and the surface will look harder. This is a bit of
a silly example, I expect it will look horrible, but it is one way in which
you could gain more control over your surface's look, similar to falloff.
But I'm not sure that all of falloff's behaviour can be replicated in pov
without modification.
Date: 19 Apr 2006 19:40:00
Message: <web.4446c9e03adb077f7d55e4a40@news.povray.org>
Is this:
http://graphics.stanford.edu/~henrik/images/global.html
incorrect? It looks like radiosity + photon mapping should be faster and
produce lower noise than simple path tracing based on those examples.
