![](/i/fill.gif) |
Hello !!
I'm sorry, i tried to post it in Bugreport, so i'm pretty sure the
moderators refused it since it was more likely a newbie question...
I have a room, closed, and a light inside.
The camera is outside and looks at the room...
But at the bottom of the wall (from the outside) i can see a kind of light
(maybe 1 pixel only) and it is there only when the light inside is ON.
So here is the quesion : If the light is INSIDE and the room is well close,
why do I see this from the outside ???
Sorry, the comments are in french... and i'm feeling too lazy to translate
them, i just hope you won't need them.
Here is the source code and a link to the picture...
http://dragons.masters.free.fr/images/demo2.png
#include "textures.inc"
#include "metals.inc"
global_settings {
max_trace_level 20
light_source {
<4.0,1,-2>
rgb <1,1,1>
#declare a=0;
#declare b=0;
#declare c=0;
#declare d=0;
#declare e=0;
// #declare a=clock*360;
#if (clock < 1)
#declare a = clock*0.15;
#declare b = 0;
#declare c = 0;
#declare d = 0;
#if ((clock > 1) & (clock<2))
#declare a = 0.15;
#declare b = (clock-1) * 2;
#declare c = 0;
#declare d = 0;
#if ((clock >2) & (clock < 3))
#declare a = 0.15;
#declare b = 2;
#declare c = (clock-2)*2;
#declare d = 0;
#if ((clock >3) & (clock < 4))
#declare a = 0.15;
#declare b = 2;
#declare c = 2;
#declare d = clock-3;
#declare e=0;
#if ((clock >4) & (clock > 4))
#declare a = 0.15;
#declare b = 2;
#declare c = 2;
#declare d = 1;
#declare e = (clock-3)*360;
location <0.12-a,-0.8+c,-1.32-b>
// location <0.15-a,-0.8+c,-1.42-b>
// location <3.15-a,2.8+c,-2.45-b>
look_at <-0.0,-.81+d,-1.29>
plane {
<0,1,0>,
-2
pigment { Yellow }
#declare lampe = union {
difference {
union {
cylinder {
<0,0,0>
<0.03,0,0>
0.0025
sphere {
<0.03,0,0>
0.01
union {
box {
<0.03,3,3>
<3,-3,-3>
sphere {
<0.03,0,0>
0.0085
Bronze_Metal
difference {
sphere {
<0.03,0,0>
0.01
union {
sphere {
<0.03,0,0>
0.0085
box {
<0.03,3,3>
<-3,-3,-3>
NBglass
light_source {
<0.03,0,0>
White
fade_distance 0.2
fade_power 2
#declare lampe2 = union {
difference {
union {
cylinder {
<0,0,0>
<0.03,0,0>
0.0025
sphere {
<0.03,0,0>
0.01
union {
box {
<0.03,3,3>
<3,-3,-3>
sphere {
<0.03,0,0>
0.0085
Bronze_Metal
difference {
sphere {
<0.03,0,0>
0.01
union {
sphere {
<0.03,0,0>
0.0085
box {
<0.03,3,3>
<-3,-3,-3>
NBglass
light_source {
<0.03,0,0>
White
fade_distance 0.1
fade_power 1
#declare table1 = union {
// Des tables...
box {
<0,-0.835+0.85,-1.4+1.4>
<0.05,-0.837+0.85,-1.38+1.4>
box {
<0.042,-0.837+0.85,-1.397+1.4>
<0.038,-0.85+0.85,-1.393+1.4>
box {
<0.042,-0.837+0.85,-1.387+1.4>
<0.038,-0.85+0.85,-1.383+1.4>
box {
<0.012,-0.837+0.85,-1.397+1.4>
<0.008,-0.85+0.85,-1.393+1.4>
box {
<0.008,-0.837+0.85,-1.387+1.4>
<0.012,-0.85+0.85,-1.383+1.4>
pigment { Blue }
#declare aeronef = union {
sphere {
<0,0,0>
1
Chrome_Metal
normal {
facets
size 0.15
scale <1,1,2>
// Les pics
union {
// Le pic de devant
cone {
<0,0.0,-0>
0.7
<0,0.0,-2.4>
0
// Les pics du dessus
union {
cone {
<0,0.0,-0.4>
0.4
<0,1.45,-0.7>
0
cone {
<0,0.0,-0.8>
0.4
<0,1.27,-1.35>
0
cone {
<0,0.0,-1.2>
0.35
<0,0.9,-1.9>
0
cone {
<0,0.0,0>
0.4
<0,1.5,0>
0
cone {
<0,0.0,0.4>
0.4
<0,1.45,0.7>
0
cone {
<0,0.0,0.8>
0.4
<0,1.27,1.35>
0
cone {
<0,0.0,1.2>
0.35
<0,0.9,1.9>
0
// les pics de gauche
union {
cone {
<0,0.0,-0.4>
0.4
<1.45,0,-0.7>
0
cone {
<-0.0,0.0,-0.8>
0.4
<1.270,0,-1.35>
0
cone {
<0,0.0,-1.2>
0.35
<0.9,0,-1.9>
0
cone {
<0,0.0,0>
0.4
<1.5,0,0>
0
// les pics de droite
union {
cone {
<0,0.0,-0.4>
0.4
<-1.45,0,-0.7>
0
cone {
<-0.0,0.0,-0.8>
0.4
<-1.270,0,-1.35>
0
cone {
<0,0.0,-1.2>
0.35
<-0.9,0,-1.9>
0
cone {
<0,0.0,0>
0.4
<-1.5,0,0>
0
Gold_Metal
//Fin des pics
//Le canon
union {
box {
<0,0,-1>
<0.7,0.7,-1.3>
pigment { Med_Purple }
union {
difference {
box {
<-0.3,0,-0.7>
<0.3,-0.9,-1.5>
union {
box {
<-0.25,0,-0.7>
<0.25,-0.85,-1.48>
box {
<-0.2,-0.83,-0.7>
<0.2,-0.7,-1.55>
pigment { Red }
// La vitre
box {
<0.2,-0.83,-1.495>
<-0.2,-0.7,-1.485>
NBglass
// Des lampadaires
object {
lampe
translate <-0.25,-0.75,-1.4>
object {
lampe
rotate <0,180,0>
translate <0.25,-0.75,-1.4>
// Une chaise principale
union {
prism {
linear_sweep
cubic_spline
1.5,
-1.5,
11
<0,0>
<1.5,0.3>
<2.5,1.5>
<3,4>
<2.8,4.1>
<2.2,1.7>
<1.5,0.7>
<0,0.5>
<0,0>
<1.5,0.3>
<2.5,1.5>
scale 0.2*0.025
rotate <0,90,90>
rotate <0,180,00>
translate <0,-0.844,-1.38>
cylinder {
<0,0.2,1.5>
<0,-4,1.5>
0.5
scale 0.2*0.025
pigment { Green }
// Les tables
object {
table1
rotate <0,90,0>
translate <-0.25,-0.85,-1.4>
object {
table1
rotate <0,0,0>
translate <-0.25,-0.85,-1.35>
// La table du milieu, table de commande...
union {
intersection {
box {
<-0.035,-0.835,-1.41>
<0.035,-0.837,-1.38>
union {
box {
<-0.034,-0.835,-1.409>
<0.034,-0.837,-1.381>
cylinder {
<-0.034,-0.836,-1.409>
<0.034,-0.836,-1.409>
0.001
cylinder {
<-0.034,-0.836,-1.381>
<0.034,-0.836,-1.381>
0.001
cylinder {
0.001
cylinder {
0.001
sphere {
0.001
sphere {
0.001
sphere {
0.001
sphere {
0.001
pigment { Blue }
cylinder {
<0,-0.836,-1.4>
<0,-0.836,-1.48>
0.0006
pigment { Blue }
lathe {
cubic_spline
4,
<0.007,-0.8>
<0.005,-0.837>,
<0.013,-0.85>
<0.05,-0.85>
pigment { Blue }
sturm
translate <0,0,-1.395>
union {
///////////////////// HERE IS THE LIGHT /////////////////
////////////// TURN IT OFF TO SEE WHAT IT DOES ///////////
object {
lampe2
rotate<0,0,-90>
translate<0,-0.76,-1.28>
difference {
box {
<0.025,-0,-1.3>
<-0.025,-0.87,-1>
union {
box {
<0.023,0,0>
<-0.023,-0.87,-1.298>
box {
<0.013,-0.87,0>
<-0.013,-0.80,-1.35>
#if (clock < 1)
#declare g = 0;
#if ((clock > 1) & (clock < 2))
#declare g = sqrt(clock-1)*0.012;
#if ((clock > 2) & (clock < 3))
#declare g = 0.012;
#if ((clock > 3) & (clock <= 4))
#declare g = (1-sqrt(clock-3))*0.012;
union {
union {
box {
<-0.013,-0.85,-1.2984>
<-0.0002,-0.8,-1.2996>
box {
<-0.01,-0.85,-1.2987>
<0,-0.8,-1.2993>
translate <-g,0,0>
union {
box {
<0.013,-0.85,-1.2984>
<0.0002,-0.8,-1.2996>
box {
<0.01,-0.85,-1.2987>
<0,-0.8,-1.2993>
translate <g,0,0>
T_Chrome_2A
pigment { Red }
union {
difference {
cone {
<0,0,1.8>
0.3
<0,0,2.20>
0.15
union {
cone {
<0,0,2.21>
0.11
<0,0,2>
0.04
#declare i = 0;
#while (i < 10)
box {
<0.005,1,2.3>
<-0.005,0.13,2>
rotate <0,0,i*36>
#declare i = i+1;
Bronze_Metal
#declare a=0;
object {
aeronef
translate <0,0,0>
rotate <0,e,0>
![](/i/fill.gif) |
![](/i/fill.gif) |
Oops sorry again, there's no EDIT button(or i didnt find any) and i wanted
to post my *optimized* code : here are only the basic stuff (or at least
much more useless things than before)
Also, my room wasn't EXACTLY closed : there was a hole, and a double metal
door blocked this hole, so anyway so light should have passed...
But when i withdraw the hole for the door (the metal is then INSIDE the wall
since it was a little thiner) the artifact diseapear O_o
global_settings {
max_trace_level 20
light_source {
<4.0,1,-2>
rgb <1,1,1>
location <0.13,-0.8,-1.35>
look_at <-0.0,-.7947,-1.3>
light_source {
<0.03,0,0>
White
fade_distance 0.2
fade_power 2
// THE ONLY DIFFERENCE BETWEEN LAMPE AND LAMPE2 IS THE FADE_DISTANCE AND
POWER
light_source {
<0.03,0,0>
White
fade_distance 0.1
fade_power 1
union {
difference {
box {
<-0.3,0,-0.7>
<0.3,-0.9,-1.5>
union {
box {
<-0.25,0,-0.7>
<0.25,-0.85,-1.48>
box {
<-0.2,-0.83,-0.7>
<0.2,-0.7,-1.55>
pigment { Red }
object {
lampe
rotate <0,180,0>
Here is THE LIGHT that mess up
union {
object {
lampe2
rotate<0,0,-90>
difference {
box {
<0.025,-0,-1.3>
<-0.025,-0.87,-1>
union {
box {
<0.023,0,0>
// AND HERE IS THE BOX THAT DIG A HOLE IN MY WALL...
// COMMENT IT, IT WILL FILL THE HOLE AND THE ARTIFACT DISEAPEAR...
// STRANGE, ISN'T IT ??
box {
<0.013,-0.87,0>
// HERE ARE THE 2 DOUBLE METAL DOOR : A FIRST BOX,
// thiner than the wall and not wide enough to fill all the hole,
// and another one, even thiner, that comes and fill the hole...
// IT MAKES SOMETHING LIKE THAT (view from top)
W |--------------- ---------------...
A | FIRST BOX -----
| 2n BOX |
L | -----
| DOOR 1 | | DOOR 2
L |--------------- -------------...
union {
union {
box {
box {
<0,-0.8,-1.2993>
union {
box {
box {
<0,-0.8,-1.2993>
T_Chrome_2A
pigment { Red }
object {
aeronef
translate <0,0,0>
Also, i updated the image...
![](/i/fill.gif) |
