POV-Ray : Newsgroups : povray.newusers : forcing POVray to ignore degenerate cylinders Server Time
16 Jan 2026 21:47:18 EST (-0500)
  forcing POVray to ignore degenerate cylinders (Message 1 to 10 of 16)
Subject: forcing POVray to ignore degenerate cylinders
Date: 12 Feb 2006 11:20:01
Message: <web.43ef5f884162a93c32691d8c0@news.povray.org>
howdyall,
is there still no way to force POVray to ignore degenerate cylinders
altogether and keep parsing and rendering, instead of just stopping? did a
search and it seems this prob goes back to 2002. anyone anywhere ever do
something about it?
basically it seems PYMOL generates a lot of degenerate cylinders when
outputting molecular models to POVray and it's plain too difficult to weed
them all out line by line.
please help. i can barely render anything because of this.
best,
shane
Subject: Re: forcing POVray to ignore degenerate cylinders
Date: 12 Feb 2006 11:27:59
Message: <43ef620f$1@news.povray.org>
Please do not mulipost. Keep your post in one group. Please read the
messages in the FAQ group for posting guidelines.
	Thorsten, POV-Team
PS: Your posts in p.advanced-users and p.general have been removed.
Date: 12 Feb 2006 12:10:00
Message: <web.43ef6add4e14e35732691d8c0@news.povray.org>
>  Thorsten, POV-Team
oh, pardon. just wasn't sure about the group for which the Q was best
suited.
Date: 12 Feb 2006 13:35:03
Message: <dsnv3t$s9e$1@chho.imagico.de>
shane wrote:
> howdyall,
No.  If you don't want a cylinder don't put it in the scene.
> did a
> something about it?
You don't have to.  Simply replace any cylinder with a macro call like:
Cylinder(Pos1, Pos2, Radius)
instead of
cylinder { Pos1, Pos2, Radius }
and use a macro like the following to generate the cylinders:
#macro Cylinder(Pos1, Pos2, Radius)
   #if (vlength(Pos2-Pos1)>Radius*0.001)
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 12 Feb 2006 19:07:36
Message: <43efcdc8@news.povray.org>
> suited.
  If it seems to belong to several groups, just post it into one of them.
It's not like the people who know answers would only read a few groups.
Date: 13 Feb 2006 14:02:31
Message: <43f0d7c7$1@news.povray.org>
I was going to add that this will have a pretty bad impact on the parse
time, but a quick test with 100.000 cylinders took 5 secs to parse
without and 7 seconds to parse with the macro. So no problem here.
Nevertheless it's annoying that a degenerate cylinder causes a parse
time error and not a warning. Degenerate triangles, spheres and boxes do
not trigger errors (in fact they're not even triggering warnings),
whereas an empty mesh throws an error, too. Is that really necessary?
What's the problem with ignoring those objects at parse time?
Florian
Date: 13 Feb 2006 15:05:44
Message: <43f0e698$1@news.povray.org>
Not to mention unions containing just one object.
Date: 13 Feb 2006 15:34:55
Message: <43f0ed6f$1@news.povray.org>
Not really, but it certainly was a deliberate choice at the time. Not one I
personally think was the best, but things like this happen.
The errors are for some (did not check all) of these cases due to POV-Ray
precomputing some values to increase speed of intersection tests right after
parsing the object. It then detects the object is degenerate and instead of
deleting the invalid object plus issuing a warning, it generates an error
because rendering would most certainly fail if the object would be left in
the scene.
Some of these annoyances have already been addressed in POV-Ray 3.7 betas,
some more are marked on the POV-Team's internal (well, source code comments,
not more so far) todo list for 3.7 and others won't make it for 3.7 to get
improved. Eventually, I suppose all errors should be detected at parse time
(there are even some detected at render-time!) and issue warnings or
possible errors (which are non-fatal) and delete the offending object from
the scene and continue by default,. Of course, other options making this
still a fatal error might be useful, too, such that nobody wastes days
rendering a scene just to discover an object is missing due to a typo that
made in degenerate, and the final image is useless.
	Thorsten
Date: 13 Feb 2006 15:50:01
Message: <web.43f0f0b94e14e3576c4803960@news.povray.org>
As an additional note, degenerate cylinders are not equal to other
degenerate objects.  Other objects that are degenerate are essentially
objects of 0 dimension in all directions, and will not form a surface of
any sort so the rays can pass by without intersection without deleting the
object.  However, a cylinder can be degenerate in length but not radius.
This would be equivilant to a flat disc with zero thickness which would be
a surface that rays can intersect with.  However with no length vectors,
the orientation of this disc is unknown to POV and the surface intersection
cannot be calculated which can cause a calculation problem.
There may be ways that this can be fixed in a newer version as Thorsten has
pointed out, by automatically deleting the offending object, however in
some instances it may not be desired.
-tgq
Date: 13 Feb 2006 15:50:03
Message: <dsqrbj$uon$1@chho.imagico.de>
In contrast to a sphere with radius 0 a degenerate cylinder is not
simply invisible - it is not well defined how it should look like.  Also
note triangles, spheres and boxes are not ignored - triangles in a mesh
are but this is something different.
