POV-Ray : Newsgroups : povray.newusers : forcing POVray to ignore degenerate cylinders Server Time
27 Mar 2026 12:27:46 EDT (-0400)
  forcing POVray to ignore degenerate cylinders (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: forcing POVray to ignore degenerate cylinders
Date: 13 Feb 2006 15:05:44
Message: <43f0e698$1@news.povray.org>
Florian Brucker wrote:
> Nevertheless it's annoying that a degenerate cylinder causes a parse
> time error and not a warning.
Not to mention unions containing just one object.
Date: 13 Feb 2006 15:34:55
Message: <43f0ed6f$1@news.povray.org>
> time error and not a warning. Degenerate triangles, spheres and boxes do
> not trigger errors (in fact they're not even triggering warnings),
> whereas an empty mesh throws an error, too. Is that really necessary?
Not really, but it certainly was a deliberate choice at the time. Not one I
personally think was the best, but things like this happen.
> What's the problem with ignoring those objects at parse time?
The errors are for some (did not check all) of these cases due to POV-Ray
precomputing some values to increase speed of intersection tests right after
parsing the object. It then detects the object is degenerate and instead of
deleting the invalid object plus issuing a warning, it generates an error
because rendering would most certainly fail if the object would be left in
the scene.
Some of these annoyances have already been addressed in POV-Ray 3.7 betas,
some more are marked on the POV-Team's internal (well, source code comments,
not more so far) todo list for 3.7 and others won't make it for 3.7 to get
improved. Eventually, I suppose all errors should be detected at parse time
(there are even some detected at render-time!) and issue warnings or
possible errors (which are non-fatal) and delete the offending object from
the scene and continue by default,. Of course, other options making this
still a fatal error might be useful, too, such that nobody wastes days
rendering a scene just to discover an object is missing due to a typo that
made in degenerate, and the final image is useless.
	Thorsten
Date: 13 Feb 2006 15:50:01
Message: <web.43f0f0b94e14e3576c4803960@news.povray.org>
As an additional note, degenerate cylinders are not equal to other
degenerate objects.  Other objects that are degenerate are essentially
objects of 0 dimension in all directions, and will not form a surface of
any sort so the rays can pass by without intersection without deleting the
object.  However, a cylinder can be degenerate in length but not radius.
This would be equivilant to a flat disc with zero thickness which would be
a surface that rays can intersect with.  However with no length vectors,
the orientation of this disc is unknown to POV and the surface intersection
cannot be calculated which can cause a calculation problem.
There may be ways that this can be fixed in a newer version as Thorsten has
pointed out, by automatically deleting the offending object, however in
some instances it may not be desired.
-tgq
Date: 13 Feb 2006 15:50:03
Message: <dsqrbj$uon$1@chho.imagico.de>
In contrast to a sphere with radius 0 a degenerate cylinder is not
simply invisible - it is not well defined how it should look like.  Also
note triangles, spheres and boxes are not ignored - triangles in a mesh
are but this is something different.
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 14 Feb 2006 04:41:22
Message: <43f1a5c2@news.povray.org>
Thanks for your opinions about that. I hadn't considered that from a
mathematical point of view a degenerate cylinder is troublesome
(although, from a user's point of view it may not be).
I'm glad to hear that the POV team is aware of the issue and that first
measures will already be included in 3.7.
Florian
Date: 14 Feb 2006 09:42:01
Message: <43f1ec39@news.povray.org>
  The problem is simply that if the endpoints of the cylinder are the
same point but the cylinder has a non-zero radius, POV-Ray cannot know how
to orientate the resulting disc.
  Basically there doesn't exist degenerate spheres (the only exceptional
case is a sphere with a radius of 0, but that's just no sphere at all)
or degenerate boxes (creating an infinitely thin "box" is umambiguous
and thus there's no problem). However, a cylinder with a non-zero radius
but with coincident endpoints is a problem because it can't be created
unambiguously.
Date: 14 Feb 2006 19:58:00
Message: <43f27c98$1@news.povray.org>
Warp nous apporta ses lumieres en ce 14/02/2006 09:42:
> unambiguously.
It's obvious that in that case, the axis of the cylinder is undefined: it's impossible
to know it's
orientation. You have a few options:
- ignore the object. Don't draw it and issue a warning or a non-fatal error.
- "assume" it's a sphere of the defined radius. Issue a warning about the
"asumption"/conversion.
This is somewhat similar to scale 0.
- throw a fatal error and abort the render.
Change is inevitable, except from vending machines.
Date: 15 Feb 2006 04:02:39
Message: <43f2ee2f$1@news.povray.org>
> it's impossible to know it's orientation.
I second that. There's simply not enough information to define the
object. But why should POV make wild guesses of what it could have
been the user intended. Just drop the thing like a box/sphere of zero
volume. I would prefer just a warning message and no fatal error
in that case.
Sebastian
Date: 15 Feb 2006 08:30:01
Message: <web.43f32c454e14e3576c4803960@news.povray.org>
> in that case.
> Sebastian
POV doesn't need to think to 'drop' zero volume spheres and boxes.  They
have no diminesional surface for rays to intersect so they can be left in
the scene as is without causing parsing problems, the individual rays will
pass by them unhindered without POV having to alter the scene.  This is not
the case for cylinders, POV would need to be able to think to see that a
cylinder is degenerate and remove it because of the problem with them as
its been explained.   This additional thinking by POV may add to the
parsing overhead.
-tgq
Date: 15 Feb 2006 10:57:57
Message: <43f34f85$1@news.povray.org>
> parsing overhead.
This sounds as if the POV parser is in bad need for a
garbage filter. Imagine a typo in a macro produces
boxes with no volume. Actually I tried it and the
only message I got was that there was no pigment given.
With given pigment I could blow up parsing time at will.
#declare c=0;
#while(c<100000)
   box{<0,0,0><0,0,0> pigment {rgb <1,0,0>}}
   #declare c=c+1;
even replies:
Slab Building Error: Out of memory.  Cannot allocate -124288 bytes for
temporary tree entry.
It shouldn't be too hard to check a box size or a
cylinder length while parsing. Probably it's that
nobody had enough spare time to implement this.
Sebastian
