POV-Ray : Newsgroups : povray.newusers : Sci-fi Lasers ?? help ! Server Time
21 Dec 2025 07:18:57 EST (-0500)
  Sci-fi Lasers ?? help ! (Message 1 to 10 of 10)
Subject: Sci-fi Lasers ?? help !
Date: 3 Feb 2006 14:45:00
Message: <web.43e3b24af52523be7037812b0@news.povray.org>
does anyone know of a way to make star trek "phaser beam" laser effects ??
there seems to be no actual way to make this effect as far as i have read on
the newsgroups... can someone please help ?? optics.pov and laser.pov
doesnt have that star trek like effect that im looking for... its supposed
to be a VERY narrow beam (line or thread) of light .. sort of like a string
beetween to point.. emmissions doesnt seem to work either or i am using
them incorrectly...
Subject: Re: Sci-fi Lasers ?? help !
Date: 3 Feb 2006 18:49:36
Message: <43e3ec10$1@news.povray.org>
B-rat nous apporta ses lumieres en ce 03/02/2006 14:43:
> them incorrectly...
Use a narrow cylinder going from the phaser to the target. Make it hollow and fill it
with an
emiting media with a high density value. You can also add some absorbing media with a
complementary
pigment.
If the container is very narrow, you need to use a comparatively large density value
as there's not
much media available.
Using that kind of media, if you also use radiosity with "media on", your beam will
actualy
illuminate it's surrounding. You need to use a large count value, otherwise, you'll
miss the beam to
often.
Don't cry because it is over, smile because it
happened.
Date: 4 Feb 2006 05:45:00
Message: <web.43e484799034a6727037812b0@news.povray.org>
it with an
a complementary
> pigment.
tried that .. didnt quite work ;)
as there's not
actualy
miss the beam to
> often.
can someone give me an example of this ?
Date: 4 Feb 2006 08:55:01
Message: <web.43e4add39034a6727037812b0@news.povray.org>
ok.. well this sort of does the trick if its modified a bit :D
cylinder {<-10,10,0>, < -5, 10, 0>, 0.2 hollow
    texture {pigment {color rgbf <0.3,0,0.3,1>}}
    interior {
        media {
            scattering {1, color rgb 100 extinction 100}
           emission color rgb 0.8
            method 3
            intervals 1 samples 4
it sort of works... sort of ..
Date: 4 Feb 2006 12:02:00
Message: <43e4de08$1@news.povray.org>
Subject line "sci-fi lasers" piqued my interest so I gave it a try beginning
from your example.
This has a soft edge by using the cylinder pattern, and to arrange the
resulting laser I started with the cylinder object oriented and scaled to
fit the media then rotated, scaled, translated into place. That can make it
easier to work with the media. Watch out for any density changes during the
resizing.
// pink phaser beam
cylinder {<0,0,0>, <0,1,0>, 1
 hollow
    texture {pigment {color rgbf 1}}
    interior {
        media {
         scattering {1, color rgb <1,0,1> extinction 0}
         emission <1,0,1>*3
         absorption <0.3,0.9,0.3>*9 // help opacity against background
            method 3
            // intervals 1 samples 4
            density {
             cylindrical
             density_map {
              [0 rgb 0]  // outer edge
              [0.5 rgb <1,1,1>]
              [1 rgb <3,3,3>] // inside
    rotate -90*z
    scale <5,0.2,0.2>
    translate <-10,10,0>
You might want to consider illumination effect on surroundings, and this
having a scattering media means it'll be affected by external lighting. Alot
depends on how you intend it to look in a scene.
Date: 4 Feb 2006 13:25:01
Message: <web.43e4f0e29034a67279d64170@news.povray.org>
nice example :D
a little color change to fit different ships and its just what i wanted,
thx
Date: 4 Feb 2006 15:00:00
Message: <web.43e506cc9034a67279d64170@news.povray.org>
well.. the only problem with that is the fact that i cant emm.. well quite
frankly i cant turn it into a beam laser, which is kind of what im going
for at the moment, the problem being that i cant determin exactly where it
will start and where it will end... and i've been playing around with this
for a while and i just cant get it to go from point A to point B... help ?
Date: 4 Feb 2006 22:03:43
Message: <43e56b0f$1@news.povray.org>
"B-rat" <Bra### [at] gmailcom> wrote in message
news:web.43e506cc9034a67279d64170@news.povray.org...
Oh... yeah... I overlooked that aspect, sorry.
I'm not sure if it could be done in a better way than the following example.
The problem is with the starting point having to be at the origin instead of
any vector, which then necessitates that object (the firing ship?) being
positioned correctly first. But at least the target can be anyplace (I
think-- I didn't check negative vectors). Chances are it could be done
another way but this is all I came up with.
#include "transforms.inc"
#declare A = 0;  // origin (where beam begins)
#declare B = <6,4,2>;  // beam target location
#declare W = 0.2;  // width of beam
cylinder {A, B, W
 hollow
    interior {
        media {
         scattering {1, color rgb <0.9,0,0.3> extinction 0}
         emission <0.9,0,0.3>*3
            method 3
            density {
             cylindrical
             density_map {
              [0 rgb 0]
              [0.5 rgb <1,1,1>]
              [1 rgb <3,3,3>]
             scale W
             Point_At_Trans(B)
Date: 5 Feb 2006 02:10:01
Message: <web.43e5a42a9034a672f187b58f0@news.povray.org>
hmm, all i have to do now is translate it at the end and the origin can be
anywhere i want, thanks.
Subject: Re: Sci-fi Lasers ?? glad to have helped
Date: 5 Feb 2006 22:58:09
Message: <43e6c951$1@news.povray.org>
news:web.43e5a42a9034a672f187b58f0@news.povray.org...
I had fun sending the beam from a sphere to a box and through a cone on the
way there. Lasers are intriguing things... even if ray traced without
photons!  ;)
