POV-Ray : Newsgroups : povray.newusers : objects turn white with raised ambience Server Time
14 Mar 2026 15:09:30 EDT (-0400)
  objects turn white with raised ambience (Message 1 to 8 of 8)
Subject: objects turn white with raised ambience
Date: 22 Dec 2005 18:15:00
Message: <web.43ab330f9ef0c7f3dff1290@news.povray.org>
I'm testing a scene with Christmas lights, and to get the effect of the
lights I thought turning up the ambient values sufficiently high would work
(with radiosity).  The only problem I run into is that four of the six
colors of lights I use turn white when the ambient value is raised.  Two of
them are function perfectly however.
The scene file is rather large, so here is a link:
http://www.geocities.com/iancrofoot/treeLit.txt
Putting lightsources in all the bulbs would be HUGE pain, so this is the
only method I can think of.  If there is a better method, or at least a fix
to my problem, I would be pleased.
Subject: Re: objects turn white with raised ambience
Date: 22 Dec 2005 21:25:01
Message: <web.43ab5f12405ec266a6f2f67b0@news.povray.org>
You'll get more people looking at your code if you try to isolate the
problem into a small scene we can easily read & run.
//---------- Ian's code ----------------------
#declare redlight_WingsMat =
  texture{
      pigment{ rgbf <0.866667, 0.00000e+0, 0.286667, 0.500000>}
      finish{
        ambient rgb 100
        diffuse 1.00000
        brilliance 1.00000
        specular 0.500000 roughness 5.00000e-2
I've only had a quick look at your scene, but if the section above is an
example of your problem, then I suggest not using white as your ambient
colour.
Instead use something like this:
 ambient rgb 100*<0.866667, 0, 0.286667>
Sorry, I haven't tested this out.
Date: 22 Dec 2005 23:18:03
Message: <iQSr7RAen3qDFwzp@econym.demon.co.uk>
>  texture{
>      finish{
>        ambient rgb 100
>        diffuse 1.00000
>        brilliance 1.00000
>colour.
What happens is that the colours get clipped. The colours that don't
turn white are the ones that have a zero component.
E.g. when this colour gets multiplied by 100
      pigment{ rgb <0.866667, 0.00000e+0, 0.286667>}
it gives
      pigment { rgb <86.6667, 0, 28.6667>}
which when clipped to a max of 1.0 gives
      pigment { rgb <1,0,1> }
which is pure magenta.
Similarly, the coloured ambient value is only going to help when one of
its colour components is zero or very small.
E.g. for this colour
      pigment{ rgb <0.920000, 0.700000, 0.220000>}
      finish{ ambient rgb <0.920000, 0.700000, 0.220000>*100 }
When you multiply the pigment by the ambient you get
      pigment {rgb <84.64, 49, 4.84>}
Which, when clipped to a max of 1.0 gives
      pigment {rgb <1,1,1>}
which is pure white.
You could choose to only use colours that have at least one zero
component. Even then, the high ambient is going to cause them to be
clipped to one of the pure colours red, blue, green, yellow, magenta or
cyan. The radiosity that they give off is from the unclipped colour.
Alternatively you could consider this:
  texture{
      pigment{ rgb <92, 0.7, 0.22>}
      finish {ambient 1}
This causes the orange bulbs to be orange, but then cast red radiosity.
Mike Williams
Gentleman of Leisure
Date: 23 Dec 2005 03:20:01
Message: <web.43abb098405ec266a6f2f67b0@news.povray.org>
> >colour.
Of course. Oops! (I'm glad I put that disclaimer in :)
FWIW, until I started reading these newsgroups, I didn't even know you could
use colour values outside the zero to one range. I was puzzled when I first
saw SDL with fading light sources using rgb 100, but I'm so used to it now
that I'd forgotten all about colour clipping.
> it gives
That makes sense, Mike.
>   texture{
>       finish {ambient 1}
> Mike Williams
What about using a layered texture, with the bottom layer having a high
white ambient and the top layer with the desired colour as filtered
transparency? Or even using two objects, a coloured bulb object,
containing a white glowing object?
Other possible techniques:
* Develop the scene using low light values & brighten up the scene with
post-processing.
* Use two-pass radiosity.
Date: 23 Dec 2005 04:48:23
Message: <abdVJCAib8qDFwEV@econym.demon.co.uk>
I tried those, and I also tried having a high ambient no_image object
around a conventional object In all cases the radiosity comes from the
unclipped value and the visible image comes from the clipped value of
the same thing. So if the combination object is bright enough to cast a
decent amount of radiosity, then what you see is bright enough to suffer
from clipping.
>post-processing.
That works. You have to set the ambient of the non-bulb objects to zero,
or close to zero, and you have to also increase the saturation in post-
processing because brightening the image by large amounts will tend to
cause the saturation to be washed out.
I'd imagine that the increased length of the development/test cycle
would make it tedious to get it to look just right.
That works. It looks like the best solution. Run the first pass with the
"ambient rgb 100" and a radiosity save file. Run the second pass with
"ambient rgb 1" and a radiosity load file.
It's also easy to develop because the radiosity look exactly like it
does with "ambient rgb 100" and the bulb looks exactly like it does with
"ambient rgb 1".
Mike Williams
Date: 23 Dec 2005 12:39:52
Message: <43ac3668$1@news.povray.org>
Ian Crofoot nous apporta ses lumieres en ce 2005-12-22 18:13:
Why don't use a macro for your lights? That macro take a colour as parameter and
create one small
coloured christmass light with a light_source of the apropriate colour. It can also
include a small
media in it's container. (using emissive madia if prety fase)
In the macro, create the light at the origin, you then rotate it and translate to it's
final place.
Rotation and position can also be passed to the macro as parameters.
No man or woman is worth your tears, and the one
who is, won't make you cry.
Date: 23 Dec 2005 15:45:00
Message: <web.43ac61a9405ec266f3dff1290@news.povray.org>
Thanks guys.  I'll think I'll try two-pass radiosity for this (something I
should learn by now).  I appreciate the time you guys spent on helping me!
And Alain, do you have a link to this macro you speak of?
Date: 23 Dec 2005 15:55:00
Message: <web.43ac6319405ec266f3dff1290@news.povray.org>
create one small
include a small
it's final place.
> Alain
Oh, you're saying to make my own macro.  Gotcha.  Nevermind the link
question, then.
