POV-Ray : Newsgroups : povray.newusers : Make a grid Server Time
20 Nov 2025 01:45:14 EST (-0500)
  Make a grid (Message 1 to 5 of 5)
Subject: Make a grid
Date: 14 Dec 2005 08:40:00
Message: <web.43a01facccf3f7a0666c08b10@news.povray.org>
I try to make a wire fence like those that are around a field in a farm.  I
try this solution :
texture{
    pigment{ brick
             color Gray
             color rgbt<1,1,1,1>
             brick_size <0.1, 0.1, 0.10>
             mortar 0.01
On a very thin box.
Texture is brick with a mortar Gray and the transparent brick color, but the
result is not very acceptable and realistic...
Is there a solution or a library available to do that kind of things?
Thx a lot
Subject: Re: Make a grid
Date: 14 Dec 2005 09:15:00
Message: <web.43a028097bd1a1bdc739b8ad0@news.povray.org>
"djschorn" <nomail@nomail> wrote:
> Hi,
> try this solution :
Perhaps you could try the f_mesh1 isosurface. I haven't tried it myself, but
the documentation makes it sound as though you could get the effect you
want.
Date: 14 Dec 2005 09:36:30
Message: <43a02dee@news.povray.org>
"djschorn" <nomail@nomail> wrote in message
news:web.43a01facccf3f7a0666c08b10@news.povray.org...
> Hi,
> I
> try this solution :
> texture{
>    pigment{ brick
>             color Gray
>             color rgbt<1,1,1,1>
>             mortar 0.01
> On a very thin box.
> the
> Thx a lot
If you want something crude and simple, but quick to render you might want
to try the following texture.
It's just a set of stripes overlayed diagonaly with a little bit of
turbulence to stop it looking too regular.
Chris B
light_source { < -150, 10  ,-80> color rgb 1}
camera {location <0.5,0.5,-2> look_at <0,0.5,0>}
#include "Colors.inc"
#declare FenceTexture =
texture{
  pigment{ gradient y turbulence 0.1
    color_map {
      [0.0 color rgbt<1,1,1,1>]
      [0.92 color rgbt<1,1,1,1>]
      [0.92 color Gray]
      [1.0  color Gray]
  scale 0.05
plane {z,0.4 texture {FenceTexture rotate z*45} texture {FenceTexture
rotate -z*45}}
Date: 14 Dec 2005 10:15:00
Message: <web.43a036de7bd1a1bd6c4803960@news.povray.org>
> Hi,
> On a very thin box.
If you just want it as atexture on boxes to simulate the look (from a
distance) try using layered gradient patterns:
//start
#declare WireThk=5;
#declare XSpac=200;
#declare YSpac=100;
box{<-5000,0,0> <5000,1500+WireThk,0.1>
  texture{
    pigment{
      gradient x
      pigment_map{
        [0.00 rgbt 0]
        [WireThk/XSpac rgbt 0]
        [WireThk/XSpac gradient y colour_map{[0.00 rgbt 0] [WireThk/YSpac
rgbt 0] [WireThk/YSpac rgbt 1] [1.00 rgbt 1]}]
        [1.00 gradient y colour_map{[0.00 rgbt 0] [WireThk/YSpac rgbt 0]
      scale <XSpac,YSpac,1>
//end
If you need a slightly more realistic look, you need to play with textures
and even normals.  However for more realistic close-up, you're better to
use csg (ie, cylinders, tori, etc)
-tgq
Date: 14 Dec 2005 11:00:01
Message: <web.43a041137bd1a1bd666c08b10@news.povray.org>
Indeep, the result with the gradient is trully more realistic...
> -tgq
In a second time, I'll try to do this with CSG, but the rendering time will
increase a lot ?
