POV-Ray : Newsgroups : povray.newusers : is pi in any of the standard included fonts? (also, random character stream= Server Time
20 Nov 2025 01:48:22 EST (-0500)
  is pi in any of the standard included fonts? (also, random character stream= (Message 1 to 7 of 7)
Subject: is pi in any of the standard included fonts? (also, random character stream=
Date: 4 Dec 2005 22:55:00
Message: <web.4393b945d8624128b59af090@news.povray.org>
So, I have several questions, and this group has been extremely helpful
before:
1)I was wanting to put the greek letter lowercase "pi" on a sphere, and I
was wondering if any of the ttfs included with POV had anything besides the
standard ASCII. If not, are there free ttfs that do? If so, how would I
reference that character in calling the text object? How can I see what
letters are in a given ttf, anyway?
2)In the same vein, is there an elegant way to get a random text stream? I'm
filling a sphere with text and it would be nice to use this. I thought of
referencing an array with each character as an element, but that seems
tedious to construct (maybe I'm just really lazy).
3)In the course of making this scene, I have hacked together some macros for
writing and engraving text (procedurally) on a sphere in various ways. It
was time-consuming for me, as I am fairly new to programming, but if
there's any interest I would be glad to post it. (For example I have a
version of the colors.inc demo scene that writes the name of the colors on
the spheres :))
Thanks!
Stefan Sittler
Subject: Re: is pi in any of the standard included fonts? (also, random character stream=
Date: 4 Dec 2005 23:17:22
Message: <4393bf52@news.povray.org>
Smws nous apporta ses lumieres en ce 2005-12-04 22:51:
> before:
You can use the ascii code directly.
> the spheres :))
> Thanks!
> Stefan Sittler
The greek leter pi is not in the provided fonts. It is present in some other fonts,
mainly
mathematical themed ones. It's also available in extended unicode fonts, like arial
uni, at a
position well past 256. (that font include all of the windings and other extra
characters sets
besside arabic, chinese and others languages) You need to add charset utf8 in
global_settings to
enable unicode use.
Take a look in the fonts folder to find what font you need.
If one synchronized swimmer drowns, do the rest have to drown too?
Date: 5 Dec 2005 04:37:37
Message: <43940a61@news.povray.org>
"Smws" <smw### [at] poboxcom> wrote in message
news:web.4393b945d8624128b59af090@news.povray.org...
> before:
> the
As Alain says, Pi is not in PoV-Ray included font files, but if you have
MS Windows, you are still in luck.  Pi is in the standard Windows font,
"Symbol".  It is in the same position in the font as the small letter "p",
and you won't need Unicode to get at it.
text {
  ttf  "symbol.ttf", "p",
  0.2,  0
  pigment {rgb <.8,.5,.4>}
  translate <0,0,2>
To access the fonts in Windows without typing full path names, add this
line to your master povray.ini file.
    Library_Path="C:\WINDOWS\Fonts"
You might also need to check your pvengine.ini file to ensure that
%FONTDIR% is included in the [Permitted Input Paths] section, but
I think this is already there by default in the PoV-Ray installation.
> Thanks!
> Stefan Sittler
Cheers!
  Brian
Date: 5 Dec 2005 07:25:28
Message: <439431b8$1@news.povray.org>
>   ... snip ...
> I'm
>   ... snip ...
> Thanks!
> Stefan Sittler
I think it's a little easier to assign the characters you want to use to a
simple string variable and use the substr function to display one of them
each time round your loop.
For example:
#declare CharacterSet =
"ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz%(){}&$'@!*=;:><.,?#~+_0123456789";
#declare MySeed = seed(42);
#local I = 0;
#while (I<1000)
  text {
    ttf  "arial.ttf",
    substr(CharacterSet,rand(MySeed)*strlen(CharacterSet),1),
    0.2,  0
    pigment {rgb <rand(MySeed),rand(MySeed),rand(MySeed)>}
    translate <-0.25,-0.3,-0.1>
    rotate <rand(MySeed),rand(MySeed),rand(MySeed)>*360
    translate z*(1-pow(rand(MySeed),2))*4
  #local I = I + 1;
camera {location <-1,1,-10> look_at <0,0,0>}
light_source { <100, 1000, -2000> color rgb 1}
Chris B.
Date: 5 Dec 2005 07:32:15
Message: <4394334f$1@news.povray.org>
Slight correction to get rid of unpleasant list of warnings in the message
stream:
    substr(CharacterSet,1+(rand(MySeed)*(strlen(CharacterSet)-1)),1),
Chris B.
Subject: Re: is pi in any of the standard included fonts? (also, random character st=
Date: 5 Dec 2005 10:15:01
Message: <web.439458629df7e1d46d4fb94b0@news.povray.org>
> >   ... snip ...
> > I'm
> >   ... snip ...
> > Thanks!
> > Stefan Sittler
> For example:
> #local I = 0;
> #while (I<1000)
>   text {
>     ttf  "arial.ttf",
>     0.2,  0
>   #local I = I + 1;
> #end
> Regards,
> Chris B.
Ah! Of course! Thank you very much.
-Stefan
Message: <web.439458bc9df7e1d46d4fb94b0@news.povray.org>
> > before:
> > the spheres :))
> > Thanks!
> > Stefan Sittler
mainly
uni, at a
characters sets
global_settings to
> enable unicode use.
> Alain
Thank you. In fact I have now made a prism object, but now I could do it
this way too.
-Stefan
