POV-Ray : Newsgroups : povray.newusers : rotate object does not seem to work Server Time
20 Nov 2025 01:45:12 EST (-0500)
  rotate object does not seem to work (Message 1 to 4 of 4)
Subject: rotate object does not seem to work
Date: 19 Nov 2005 19:15:01
Message: <web.437fbed72993e19e8bbafa7b0@news.povray.org>
In the snippet below, the object rotate does not rotate when a variable
value but works with a fixed value.  It appears to be always set to zero
(no rotaion0 when a variable is used.  The goal was to create a spiral
series of I-beams.  Can anyone help me with what I am doing wrong?
thanks
      #declare i = 0;
      #declare h = 0;     //elevation
      #declare R = 5;     //outer radius
      #declare a = 0;
      #declare da = 360/40;
      #declare bpi = 40;  //beams per pi
      #declare rrate = 5*2*pi/360; //ramprate
      #declare bspan = 2*pi*R/40;
      #declare dh = bspan*tan(rrate);
      #while (i<40)
        object { I_beam
        texture { Steel_Beam }
        rotate <0,90,0>
        translate <R*cos(a), h, R*sin(a) >
        #local a = a + da;
        #local i = i + 1;
        #local h = h + dh;
Subject: Re: rotate object does not seem to work
Date: 19 Nov 2005 20:25:00
Message: <web.437fcfe7a413c3ef272622110@news.povray.org>
> thanks
>       #declare i = 0;
>       #declare a = 0;
>       #while (i<40)
>         object { I_beam
>         rotate <0,90,0>
>         #local a = a + da;
>         #local i = i + 1;
>         #local h = h + dh;
>       #end
It is somewhat unclear to me what you are trying to achieve.
(But at least I can assure you that rotations do indeed also work with
variables.)
Please have a look at the code below. I don't know if it does what you want,
but I have tried to make the code better and more understandable for
others.
If you need more help, then please post a more complete example that
illustrates your problem. You should make it so that we don't have to add a
lot of lines with camera, light sources, shapes, textures etc in order to
make a test render.
#declare NrOfBeams = 40;
#declare Radius = 5;
// I don't see what you are trying to do within the 3 lines below.
#declare Bspan = Radius*2*pi/NrOfBeams;
#declare RampRate = radians(5);
#declare dHeight = Bspan*tan(RampRate);
#declare dAngle = 360/NrOfBeams;
#declare Angle = 0;
#declare Height = 0;
#declare I = 0;
#while (I < NrOfBeams)
  #declare Height = Height + I*dHeight;
  #declare Angle = Angle + I*dAngle;
  object {
    I_beam
    translate <Radius, Height, 0>
    rotate (90 + Angle)*y
    pigment { color Red }
  #declare I = I + 1;
#end // while
You should avoid using variable names with only lower case letters.
I recommend that you look up the radians() and degrees() keywords in the
manual and also check that you know which keywords expect radians and which
expect degrees as arguments.
Tor Olav
http://subcube.com
Date: 19 Nov 2005 20:36:27
Message: <MKyA9FALM9fDFwe9@econym.demon.co.uk>
>thanks
>        rotate <0,90,0>
You're rotating each beam by the same amount. To rotate each beam
differently you need to use something like this
        rotate <0,90-i*rrate*180/pi,0>
Note that "rotate" uses degrees, but rrate is in radians, hence the
*180/pi.
Mike Williams
Gentleman of Leisure
Date: 19 Nov 2005 21:35:01
Message: <web.437fe0aaa413c3ef8bbafa7b0@news.povray.org>
> >thanks
> >        rotate <0,90,0>
> *180/pi.
> Mike Williams
My confusion arose out of the radians for trig functions, and rotations
being in degrees and needed a negative value to have the radial effect
desired of a spiral stair case.  The snippet also did not include the
variable being used.  I also plan to use upper case variable name for final
version.
The version that seems to work for me follows, thank you all for your help.
      #declare i = 0;
      #declare a = 0;
      #while (i<40)
        object { I_beam
        rotate -a*y
        translate <R*cos(a*pi/180), h, R*sin(a*pi/180) >
        //translate y*h
        #local a = a + da;
        #local i = i + 1;
        #local h = h + dh;
