POV-Ray : Newsgroups : povray.newusers : Getting good glows over high-intensity areas Server Time
20 Mar 2026 00:44:07 EDT (-0400)
  Getting good glows over high-intensity areas (Message 11 to 16 of 16)
Subject: Re: area lights
Date: 20 Jul 2005 12:07:41
Message: <42de76cd$1@news.povray.org>
"ZainAnak" <nomail@nomail> wrote in message
news:web.42de5e3fa93ad1b23b6b98ba0@news.povray.org...
> Bob, thanks for all the help!
Always welcome to any I have.
> sort of area light setup?  All I really want, after all, is the sun lines
> to be a *little* blurrier than normal- I don't want everything bright in
> the scene to glare out, like your sample code would do.  Here is my
> current
> light:
 light_source {
  <-5000, 4000, 15000>
  color rgb <0.8, 0.4, 0.2>*4.1
  area_light 150*x, 150*y, // dimensions, or physical size
  4, 4 // number of sources for each axis (above). integers only
  adaptive 1 // sampling rays (more is slower, but better. integers only)
  jitter // smooth shadows, without this you would get banding
  circular // make it round not square
  orient // turn toward scene objects (works in conjunction with circular)
Ha ha ha! Well, you're right. Why not keep it simple? Heck, I'm just glad
you got me going on Samuel's light-bleed idea, otherwise I might have never
had such a thing here.
When you're dealing with area_light the important things are size of the
array and smoothness of the shadows. I've added in what might be okay with
you're scene but you'll definitely need to adjust the x and y dimensions to
either narrow or widen the resulting shadows.
The number of sources (4 X 4) ultimately determines quality, as well as
speed of the render, so you might also need to increase that even if it
slows the rendering down. But if the shadow edges are only needed to be very
thin you could possibly lower those two numbers (equally and integer only)
to a 3 by 3 array. All depends on what you see in the render as you make
adjustments.
Oh yeah, and area_light does not affect surfaces directly, such as specular
highlights and the diffuse finishes. It's only for shadows.
You would be wise to read up on this in the scene help (docs), section
3.4.7.5  Area Lights, so I'll leave it at that. Unless you have more to ask,
please go ahead and do so.  : )
Date: 20 Jul 2005 14:25:00
Message: <web.42de965ef335b5b53b6b98ba0@news.povray.org>
Bob, this is looking GREAT.  I'm futzing around with the settings, and it's
giving me some nice color ramps where the sun falls.  And I don't even have
to render twice... woohoo!
Thanks!
-ZA
Date: 20 Jul 2005 17:16:14
Message: <42debf1e$1@news.povray.org>
So low! I generally use 17, 17 myself. Maybe I could go lower if I used
jitter more often, but I still recommend using higher numbers than 4; the
jittering with such a low number probably forces otherwise unnecessary
anti-aliasing.
Of course, with such high numbers it's very important to use adaptive (so
that you don't actually shoot a full 17x17=289 shadow rays); adaptive 1 has
always worked best for me.
Finally, I also recommend using a number which is one greater than a power
of 2 (3, 5, 9, 17, 33) because these make the most sense with the adaptive
process (See the second picture at
http://www.povray.org/documentation/view/3.6.1/313/ , which demonstrates why
this makes sense).
 - Slime
 [ http://www.slimeland.com/ ]
Date: 20 Jul 2005 18:29:59
Message: <42ded067$1@news.povray.org>
"Slime" <fak### [at] emailaddress> wrote in message
news:42debf1e$1@news.povray.org...
> anti-aliasing.
To be honest, I actually wrote 5,5 at first and replaced it with 4,4
thinking it might seem too slow. I subconsciously consider shorter render
times to be better than quality of the output. A habit formed during the
days of one-line-at-a-time renderings and hardly ever doing "final" images
left running for hours or days.
> has
Makes sense. Proves you *can* teach an old dog new tricks. I've always
stayed away from the larger arrays just because I worried about longer
render times.
> why
> this makes sense).
I went looking for the example files and read each lights\arealight*.pov, as
well as rendering them in a few different ways to check against my usual way
and what you said. Firstly, I hadn't realized those had 17 by 17 arrays.
Secondly, I'm amazed to find out that circular.pov has only 4 by 4 arrays
and the shadows are awful. But even more amazing is that after changing them
to 9 by 9 the render time only increased from 11.56 to 11.64 seconds! The
shadows look great, too; although, any higher than 5 by 5 array and the idea
behind the example of a circular arealight compared to non-circular gets
lost. ;-)
Apparently I'm going to need to change my mind about arealights and start
giving better advice about them in the future.
Thankyou for jostling my old POVing into new territory! If I can just train
myself not to drop back to 4X4's again I should be okay.
Subject: Re: more to be said
Date: 24 Jul 2005 10:25:01
Message: <web.42e3a3d9a93ad1b2e9d8b2350@news.povray.org>
There might be one more effect in the picture, but the ones you discussed in
this thread, that would cause the line to be blurred: if the wall is
bumped, the bumps in the wall may reflect light, causing the neighboring
bumps to be lit, even that they are not directly lit by the sun. Radiosity
or photon maps might be used for this.
"ZainAnak" <nomail@nomail> wrote:
> I had an idea, though.  If you look at the original picture I posted as a
> reference, you'll notice that it's a pretty small, well-defined bleed that
> occurs at the sun line.  I was wondering- couldn't I achieve this with some
> the scene to glare out, like your sample code would do.  Here is my current
> light:
> light_source {
> how would you turn this into a light with slightly fuzzier lines?
> Thanks!
> -ZA
Date: 24 Jul 2005 10:45:00
Message: <web.42e3a829a93ad1b2e9d8b2350@news.povray.org>
And there might be yet one more effect: the bumps might cause the shadow
line to `wiggle', what may look like a kind of softening from some
distance.
