![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Ross" <rli### [at] everestkc net> wrote:
> "Dave!" <orr### [at] no_spam_please excite com> wrote in message
> news:web.41656793cf25c4f0f0000e6e0@news.povray.org...
> > #declare elusiveobject = union {
> > box {<-40,24,0>,<40,-24,20>
> > pigment {Red}}
> > cylinder {<-40,0,0>,<80,0,0>,1 open
> > scale <1,60,50>
> > translate <0,24,30>
> > clipped_by { plane { x 0
> > rotate <0,0,-17.785>
> > translate <40,24,0>}}
> > clipped_by { plane { -x 0
> > rotate <0,0,17.785>
> > translate <-40,24,0>}}
> > clipped_by {box {<-40,24,-20>,<40,-24,0>}}
> > pigment {Blue}}
> > union {
> > disc {<40,0,0>,<1,0,0>,1}
> > disc {<-40,0,0>,<1,0,0>,1}
> > scale <1,40,50>
> > translate <0,24,30>
> > clipped_by {box {<-40.1,24,-20.1>,<40.1,-24,0>}}
> > pigment {Yellow}}
> > Forgive me if the code isn't as elegant as it could be!
> > I'm trying to create a smooth, curved surface linking the top edge of the
> > Yellow disc to the near edge of the Blue cylinder. I can almost get it,
> > but not quite. The shape I'm looking for seems to be a cylinder with
> > different scaling of the two endcaps, but I can't figure out how to do
> > that.
> > Can someone propose a way to achieve what I'm aiming for here? If
> possible,
> > I'd prefer to do it with basic shapes rather than patches or splines, but
> > I'll be grateful for any suggestions.
> > If the answer is ridiculously simple, please be gentle!
> > Thanks in advance for any help!
> > Dave!
> your subject has it almost. you use a cone with a different radus for each
> end:
> cone {
> <0, 0, 0>, 0.25
> <0, 1, 0>, 0.75
> or something to that effect if I understand your intentions. for more info
> about cones, see 3.3.1.3 in the docs.
Hi Ross!
Thanks for the input, but I think I wasn't clear in my request (it
appears that I deleted the introductory text before the code, go figure).
What I actually want to do is something like this:
cone {
<0,0,0>, 1 scale <1,1,1.5>
<0,1,0>, 1 scale <1,1,2.5>
I know that this isn't proper syntax, but I hope it illustrates what I'm
after. The endcaps each have a different radius, but the scaling for the
two endcaps is different. Can this be done?
Thanks again.
Dave!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:web.416580aeb7d57f05f0000e6e0@news.povray.org...
> Hi Ross!
> cone {
> Thanks again.
> Dave!
ah, i think i understand.
not with cone anyway since the radius isn't a vector value, just a float
value. i'll let someone else step in here and quietly back away from what
will probably be an Isosurface solution ;)
good luck!
-r
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>cone {
I think the proper syntax for that is
#include "shapes.inc"
object{ Supercone(<0,0,0>, 1, 1.5 , <0,1,0>, 1 2.5)}
but I don't think that it actually achieves your objective.
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> >cone {
Hmm--I'll mess around with it this evening. Thanks to you both for your
insight. I'll let you know how things turn out.
Is there a good online tutorial for isosurfaces? I didn't have much luck
with the POV-Ray help docs.
Thanks again.
Dave!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Irregular cone scaling to bridge to curved edges?
Date: 7 Oct 2004 20:16:29
Message: <4165dc5d$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, sure - here's one that Mike has made:
http://www.econym.demon.co.uk/isotut/
And here's an old one that Samuel once made:
http://www.zeropps.uklinux.net/isotut/
Tor Olav
http://subcube.net
http://subcube.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> >cone {
This was one of the rare occasions where I managed to resist immediately
suggesting an isosurface solution. Perhaps this bit of my isosurface
tutorial might help:
<http://www.econym.demon.co.uk/isotut/splines.htm#twolathe>
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Oct 2004 05:25:43
Message: <41665d17@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
A high-school-level math book can be the best isosurface tutorial.
You can't make eg. the supercone shape unless you know your math.
(It was actually me who developed the Supercone macro for inclusion
in POV-Ray. Even though an equivalent isosurface would have done the
job, I felt that I should make it a quartic because then I wouldn't
need to worry about max_gradients nor accuracies and it would always
render properly. Anyways, it was quite an interesting mathematical
exercise to develop the quartic vector.)
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yeah, that's a bummer. I've had to re-learn a lot of Trig that I never
thought I'd use.
I played around with the macro last night, and it's really cool. Thanks for
making that effort in the first place!
However, I sort of accidentally discovered that I could create the surface I
needed more easily through a matrix transformation of a simple cylinder.
I'll post a basic pic to the binaries group if anyone would care to look.
I'm grateful to everyone who offered insights! It was only by working
through the suggestions that I finally hit on the answer.
Thanks again,
Dave!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Oct 2004 10:04:50
Message: <41669e81@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Since you can't turn a cylinder into a conical shape where each end has
a different size with a matrix transformation, and since a transformed
cylinder is exactly what you wanted, your original description of the
problem was not very accurate... :P
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, mis-diagnosis is part of the problem, sure! I'm modelling from a
real-world object, and my initial description was based on my initial
(admittedly incorrect) study of the object. I didn't realize until last
night that the surface I needed was cylindrical rather than conic.
Still, I've received lots of good info about isosurfaces, so it works out
for me either way!
Dave!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
