POV-Ray : Newsgroups : povray.newusers : imagemap not covering mesh or hightfield Server Time
14 Oct 2025 07:03:51 EDT (-0400)
  imagemap not covering mesh or hightfield (Message 1 to 8 of 8)
Subject: imagemap not covering mesh or hightfield
Date: 20 Sep 2004 20:05:00
Message: <web.414f6f52ca70dcc8360c6a050@news.povray.org>
why are my imagemaps only covering 1/4 of heightfield or meshes ? i am
modelling in MORAY 3.5 and rendering in PovRay 3.6.1
Subject: Re: imagemap not covering mesh or hightfield
Date: 20 Sep 2004 20:31:30
Message: <ohIWWEARV3TBFwxU@econym.demon.co.uk>
Perhaps you think that imagemaps should cover the square from <-1,-1>
to <1,1> [1], but they don't. They cover the area from <0,0> to <1,1>
[1] Which actually might have been a sensible way to have done it in the
first place, but it's far too late to change things now.
Mike Williams
Gentleman of Leisure
Date: 21 Sep 2004 06:46:18
Message: <4150067a@news.povray.org>
> first place
  Why?
Date: 21 Sep 2004 09:28:16
Message: <UXK57AAFoBUBFwNb@econym.demon.co.uk>
>> first place
>  Why?
For consistency with things that were invented around the same time
(many of which are not used much these days) like Sphere, Cylinder_X,
Cone_Y, Disk_Z, Cube and more recent things like the torus and
Supertorus which all pop into existence centred around <0,0,0> rather
than <0.5,0.5,0>.
I'd guess that even today only a relatively small percentage of image
maps get used without translate <-0.5,-0.5,0> scale 2.
Mike Williams
Date: 21 Sep 2004 14:00:49
Message: <41506c51@news.povray.org>
> than <0.5,0.5,0>.
  How about consistency with other texture-related things, like for
example most patterns which start from <0,0,0> and usually go to some
multiple of <1,1,1> (such as gradient, checker, etc)?
Date: 21 Sep 2004 14:56:38
Message: <41507966@news.povray.org>
Also, heightfield itself goes hand in hand with image mapping once rotated
90*x, so those are mutually compatible as-is.
What might have been a good idea, and could still be, would be to use a
keyword in height_field and image_map to allow automatically centering
them... and anything else that places a corner at <0,0,0>. Except then I'd
think rescaling to double the initial 1 unit size might be something to
consider, too, so that the area covered would be like a unit-sized sphere,
cylinder, cone, etc.
Bob H.
Date: 21 Sep 2004 15:04:29
Message: <kA8qfGAckHUBFwrN@econym.demon.co.uk>
>> than <0.5,0.5,0>.
Most patterns are centred at <0,0,0>, not <.5,.5,0>.
Note that if you paint checker onto "box {<0,0,0><1,1,1>}" all the faces
are single colours, so I claim that's only a quarter of the checker
pattern. The repeat unit of the checker pattern is the unit cube, not
the <0,0,0><1,1,1> cube.
The gradient pattern is a bit of an oddity, particularly now that it has
recently been redesigned.
Mike Williams
Date: 21 Sep 2004 15:24:50
Message: <41508002@news.povray.org>
  I said "to a multiple of <1,1,1>", not "to <1,1,1>".
  The checker pattern actually starts from <0,0,0> (the first cube from
that to positive axes is colored as the first color given).
  The image_map pigment works in the same way as checker (unless you
specify the 'once' keyword), which is consistent and logical.
  Also think how UV-mapping works by default: The texture will be taken
from <0,0,0> to <1,1,0>. If you just create an image_map, it will work
right away with an uv-mapped object.
